  3. Multi Button Relay Sketch
69 Posts 12 Posters 38.7k Views 18 Watching
  • SGiS
    SGiS
    SGi
    Has anyone made a multi (at least 4) relay version of the relay with button sketch? the basic relay example sketch allows for multiple relays but the relay with button sketch only allows for 1. I am sure it would not be difficult for an experienced Arduino/MySensors programmer to modify the example sketch for me? Any takers?
    Boots33B 1 Reply Last reply
    • SGiS SGi
      Boots33B
      Boots33B
      Boots33
      wrote on last edited by Boots33
      @SGi I have used two buttons in my Mains controller project. I have posted just the relay code below to show you what you need to do. I have not used the eeprom to store the state but you could soon add that back in. The main thing you need to do is check to see which sensor the incoming message is for.
         DESCRIPTION
         Based on the RelayWithButtonActuator sketch
      // Enabled repeater feature for this node
      //#define MY_REPEATER_FEATURE
      #include <Bounce2.h>
      #define RELAY_ON 1
      #define RELAY_OFF 0
      #define SSR_A_ID 1   // Id of the sensor child
      #define SSR_B_ID 2   // Id of the sensor child
      const int buttonPinA = 3;
      const int buttonPinB = 4;
      const int relayPinA = 5;
      const int relayPinB = 6;
      int oldValueA = 0;
      int oldValueB = 0;
      bool stateA = false;
      bool stateB = false;
      Bounce debouncerA = Bounce();
      Bounce debouncerB = Bounce();
      MyMessage msgA(SSR_A_ID, V_STATUS);
      MyMessage msgB(SSR_B_ID, V_STATUS);
        pinMode(buttonPinA, INPUT_PULLUP); // Setup the button Activate internal pull-up
        pinMode(buttonPinB, INPUT_PULLUP); // Setup the button Activate internal pull-up
        pinMode(relayPinA, OUTPUT);
        pinMode(relayPinB, OUTPUT);
        // After setting up the buttons, setup debouncer
        debouncerA.attach(buttonPinA);
        debouncerA.interval(5);
        debouncerB.attach(buttonPinB);
        debouncerB.interval(5);
        digitalWrite(relayPinA, RELAY_OFF);
        digitalWrite(relayPinB, RELAY_OFF);
      void presentation()  {
        sendSketchInfo("Mains Controller", "1.0");
        present(SSR_A_ID, S_LIGHT);
        present(SSR_B_ID, S_LIGHT);
         Example on how to asynchronously check for new messages from gw
        debouncerA.update();
        // Get the update value
        int valueA = debouncerA.read();
        if (valueA != oldValueA && valueA == 0) {
          send(msgA.set(stateA ? false : true), true); // Send new state and request ack back
        oldValueA = valueA;
        debouncerB.update();
        int valueB = debouncerB.read();
        if (valueB != oldValueB && valueB == 0) {
          send(msgB.set(stateB ? false : true), true); // Send new state and request ack back
        oldValueB = valueB;
          switch (message.sensor) {
            case 1:
              stateA = message.getBool();
              digitalWrite(message.sensor + 4, stateA ? RELAY_ON : RELAY_OFF);
              break;
            case 2:
              stateB = message.getBool();
              digitalWrite(message.sensor + 4, stateB ? RELAY_ON : RELAY_OFF);
              break;
            // Write some debug info
          Serial.println(message.sensor);
          Serial.print("from node:");
          Serial.println(message.sender);
      rayanR SGiS 3 Replies Last reply
      • Boots33B Boots33
           DESCRIPTION
        #define RELAY_ON 1
        #define RELAY_OFF 0
        int oldValueA = 0;
        int oldValueB = 0;
          oldValueA = valueA;
          oldValueB = valueB;
              case 1:
                break;
              case 2:
                break;
        rayanR
        rayanR
        rayan
        @Boots33
        if i want use an up/down switch (no push switch) that with each change (up or down) , relay state change . for example if relay is "on" and switch is "down" , with change switch to "up" relay to be "off" OR if relay is "off" and switch is "down" , with change switch to "up" relay to be "on"
        in sketch , what am i do ?
        • Boots33B
          Boots33B
          Boots33
          Haven't tried it but this might work
          move the line _____ oldValueA = valueA; ____up into the if statement
          and remove ______ && valueA == 0 ____ from the if conditional
            if (valueA != oldValueA ) {
             oldValueA = valueA;
          rayanR 1 Reply Last reply
          • Boots33B Boots33
               oldValueA = valueA;
            rayanR
            rayanR
            rayan
            wrote on last edited by rayan
            @Boots33
            this is great
            but have a tiny problem
            with power off/on , relay state is unstable every time . i could not fix this . can you fix ? with power off/on relay to be high every time . different state of relay and button have influence on relay state after power off/on . often with power off/on , there are a change state low to high or high to low quickly.
            in other means , in startup if switch be down or up , dont Make sure relays are off when starting up
            also state in web is not correct
            • rayanR rayan
              @Boots33
              this is great
              Boots33B
              Boots33B
              Boots33
              @rayan It might be easier if you post your code so we can see where the changes need to be made.
              • Boots33B Boots33
                rayanR
                rayanR
                rayan
                @Boots33
                this is your code :)
                #define RELAY_ON 1
                #define RELAY_OFF 0
                const int buttonPinA = 18;
                const int buttonPinB = 19;
                int oldValueA = 0;
                int oldValueB = 0;
                  if (valueA != oldValueA) {
                  oldValueA = valueA;
                  if (valueB != oldValueB) {
                  oldValueB = valueB;
                      case 1:
                        break;
                      case 2:
                        break;
                • rayanR
                  rayanR
                  rayan
                  you are set value for relay in code
                  but i dont know why after start up . . .
                  • rayanR rayan
                    Boots33B
                    Boots33B
                    Boots33
                    @rayan so are you saying that when the node is first booted up you want the relay to always to be turned on?
                    • Boots33B Boots33
                      rayanR
                      rayanR
                      rayan
                      @Boots33
                      i want if power of home be off and after time on again , so all of relay ( with switch up/down with each state) to be off. now in this code after startup relay is unstable for 1s and my light is on and aff quickly :)
                      also if lights are off , if power off/on , so some of relay go to ON in startup !
                      • rayanR rayan
                        @Boots33
                        Boots33B
                        Boots33B
                        Boots33
                        @rayan So if the house looses power you want the relays to be turned off when power is restored?
                        • Boots33B Boots33
                          rayanR
                          rayanR
                          rayan
                          @Boots33
                          yes, all of lights are on or off (some on some off) so when looses power and power is restored , i want all of lights be off also in web and app light = off , so with key in app or change state of switch turn on again ...
                          • rayanR
                            rayanR
                            rayan
                            but this app , every time after the restored power and startup, relay ( related to state of up/down switch) have different state
                            • rayanR rayan
                              Boots33B
                              Boots33B
                              Boots33
                              @rayan yes it was meant to be used with push buttons not toggle switches. It will need a few tweaks to make it work. I am at work now so will take a look when I get home.
                              • Boots33B Boots33
                                rayanR
                                rayanR
                                rayan
                                ok thank you
                                • rayanR rayan
                                  ok thank you
                                  Boots33B
                                  Boots33B
                                  Boots33
                                  @rayan Ok had a quick look and I don't think we need to do a lot for this to work.
                                  The only extra change I have made is to add four new lines at the end of the setup function
                                     /*--------------------- Added these lines for toggle switch-------------------------*/
                                    oldValueA = digitalRead(buttonPinA);  // set oldValueA to the current status of the toggle switch
                                    oldValueB = digitalRead(buttonPinB);  // set oldValueB to the current status of the toggle switch
                                    send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
                                    send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
                                  As you can see the oldValue variables are now set to represent the current state of the toggle switches when the node boots up. this should stop any changes in state being made in the main loop until a switch is toggled.
                                  The other two lines just send a message to the controller to tell it the switches are off. this should make the controller icons show the correct state
                                  Below is the full sketch, I have nothing to test it on so give it a try and see how it goes
                                  #define RELAY_ON 1
                                  #define RELAY_OFF 0
                                  int oldValueA = 0;
                                  int oldValueB = 0;
                                    oldValueA = valueA;
                                    oldValueB = valueB;
                                        case 1:
                                          break;
                                        case 2:
                                          break;
                                  rayanR SGiS 2 Replies Last reply
                                  • Boots33B Boots33
                                    #define RELAY_ON 1
                                    #define RELAY_OFF 0
                                    int oldValueA = 0;
                                    int oldValueB = 0;
                                      oldValueA = valueA;
                                      oldValueB = valueB;
                                          case 1:
                                            break;
                                          case 2:
                                            break;
                                    rayanR
                                    rayanR
                                    rayan
                                    @Boots33 said:
                                    i test your code and this is excellent . but there is another tiny problem :)
                                    when relay is ON then loses power so in app relay is ON (icon) , when power is restored and relay go to OFF in app icon is ON and dont Ack for go to show Off .
                                    you are best in programming :)
                                    • rayanR rayan
                                      Boots33B
                                      Boots33B
                                      Boots33
                                      @rayan maybe trying to send the off message before the presentation stops it from sending
                                      try this , have moved the messages to the main loop where they will only be sent once in the first loop
                                      #define RELAY_ON 1
                                      #define RELAY_OFF 0
                                      int oldValueA = 0;
                                      int oldValueB = 0;
                                      int trigger = 0;
                                       // send(msgA.set(false)); // Send off state for relayA to ensure controller knows the switch is off
                                       // send(msgB.set(false)); // Send off state for relayB to ensure controller knows the switch is off
                                      if (trigger == 0){
                                        trigger = 1;
                                        oldValueA = valueA;
                                        oldValueB = valueB;
                                            case 1:
                                              break;
                                            case 2:
                                              break;
                                      rayanR pepsonP 4 Replies Last reply
                                      • Boots33B Boots33
                                        #define RELAY_ON 1
                                        #define RELAY_OFF 0
                                        int oldValueA = 0;
                                        int oldValueB = 0;
                                        int trigger = 0;
                                        if (trigger == 0){
                                          trigger = 1;
                                          oldValueA = valueA;
                                          oldValueB = valueB;
                                              case 1:
                                                break;
                                              case 2:
                                                break;
                                        rayanR
                                        rayanR
                                        rayan
                                        @Boots33
                                        great.
                                        so this is best sketch :)
                                        thank you
                                        • Boots33B Boots33
                                          #define RELAY_ON 1
                                          #define RELAY_OFF 0
                                          int oldValueA = 0;
                                          int oldValueB = 0;
                                          int trigger = 0;
                                          if (trigger == 0){
                                            trigger = 1;
                                            oldValueA = valueA;
                                            oldValueB = valueB;
                                                case 1:
                                                  break;
                                                case 2:
                                                  break;
                                          rayanR
                                          rayanR
                                          rayan
                                          @Boots33
                                          oh , after added this device , happen a Event ! node id of motion sensor and this device is 1 ! and after sense of motion light on in dashborad ! why both Catch node id 1 .
                                          i dont add #define node id for motion and for this. but both take id 1 and Interference
