Portable RFM69 Signal Scanner
    Just wanted to share my tonight creation
    0_1508188047036_upload-ad843227-d291-4f19-874f-5437afd020c8
    It shows Send and Receive RSSI and vcc (that btw is measured via voltage divider and is spot on with my multimeter)
    Nice job! Looks very dapper.
    Alternatively, you may (?) be able to plug your screen directly into the I2C connector used for the TH sensor on:
    https://www.openhardware.io/view/268/Arduino-Pro-Mini-Shield-for-RFM69HW
    Depends on the pinout, of course.
    I thought about it but Vin and GND are swapped
  • Hi great work. Could you give us more details please?
    Which version of mysensors do you use ? RF power report seems only availble in dev branch isn't it?
    Yes, I'm using latest version in dev branch. I also figured I can show both power level and power percentage ( I removed the "VCC" from lcd as it is not really necessary 🙂 )
    Here is the new code that uses the TX power readings. I think that RSSI values and tx power values could be useful to be reported by nodes every once and a while, at least to provide a feedback on how they are doing.
    #include <U8glib.h>
    //#define MY_DEBUG  // Enable debug prints
    U8GLIB_SSD1306_128X64 lcd(U8G_I2C_OPT_DEV_0 | U8G_I2C_OPT_NO_ACK | U8G_I2C_OPT_FAST);	// Fast I2C / TWI
    #define MY_RADIO_RFM69
    #define MY_RFM69_FREQUENCY RFM69_433MHZ
    #define MY_RFM69_NEW_DRIVER
    #define MY_TRANSPORT_WAIT_READY_MS 10000
    //#define MY_NODE_ID 240
    //#define VBAT_VCC
    #define CHILD_ID_VBAT 201						 // Battery voltage
    	unsigned long SLEEP_TIME = 2000; // Sleep time between reads (in milliseconds)
    #define SKETCH_NAME "Signal Monitor"                // Change to a fancy name you like
    #define SKETCH_VERSION "1.0"                    // Your version
    MyMessage msgVBat(CHILD_ID_VBAT, V_VOLTAGE);
    int Send_rssi, Rec_rssi;                                    // RSSI RFM69 chip
    #define CHILD_ID_RSSI_HIGH  7                // RSSI received signal level
    #define CHILD_ID_RSSI_LOW   8                // RSSI background noise level
    MyMessage msgRSSI1(CHILD_ID_RSSI_HIGH, V_LEVEL);
    MyMessage msgRSSI2(CHILD_ID_RSSI_LOW, V_LEVEL);
    #define VMIN 2.8                                  //  Vmin (radio Min Volt)=1.9V (564v)
    #define VMAX 3.44                                 //  Vmax = (2xAA bat)=3.0V (892v)
    float Vbat;
    #ifdef VBAT_VCC
    #include <Vcc.h>
    const float VccCorrection = 1.0 / 1.0;  // Measured Vcc by multimeter divided by reported Vcc
    Vcc vcc(VccCorrection);
    #endif // VBAT_VCC
    	lcd.setFont(u8g_font_unifont);
    	present(CHILD_ID_RSSI_HIGH, S_SOUND);
    	present(CHILD_ID_RSSI_LOW, S_SOUND);
    	present(CHILD_ID_VBAT, S_MULTIMETER);
    	Send_rssi = RFM69_getSendingRSSI();             // read RSSI in RFM69. Measure reception signal from gw
    	send(msgRSSI1.set(Send_rssi));                  // send RSSI level
    	wait(500);                                 // wait to get idle
    	Rec_rssi = RFM69_getReceivingRSSI();           // read RSSI in RFM69. Wait and measure background noise
    	send(msgRSSI2.set(Rec_rssi));                  // send RSSI level
    	wait(200);                                 // wait for next send
    	batM();
    	lcd.firstPage();
    	do {
    		UpdateDisplay();
    	} while (lcd.nextPage());
    void UpdateDisplay()
    	lcd.setPrintPos(0, 20);
    	String row;
    	row = (String)"S/R: " + Send_rssi + "/"+ Rec_rssi +"db";
    	lcd.print(row);
    	lcd.setPrintPos(0, 42);
    	row = (String)"Pwr%: " + RFM69_getTxPowerPercent() + "%";
    	lcd.print(row);
    	lcd.setPrintPos(0, 64);
    	row = (String)"PWR: " + RFM69_getTxPowerLevel() + "db";
    	lcd.print(row);
    	delay(500);
    	int batteryPcnt;
    	// Battery monitoring reading
    #ifdef VBAT_VCC
    	Vbat = vcc.Read_Volts();
    	batteryPcnt = vcc.Read_Perc(VMIN, VMAX);
    	Vbat = sensorValue * VBAT_PER_BITS;
    	// Calculate the battery in %
    	batteryPcnt = static_cast<int>(((Vbat - VMIN) / (VMAX - VMIN))*100.);
    	delay(500);
    	send(msgVBat.set(Vbat, 2));
    	if (batLoop > 2) {
    		if (batteryPcnt > 100) {
    			batteryPcnt = 100;
    		batLoop = 0;
    		batLoop++;
  • Nice clean signal scanner build! I must have one.
    Is that an open source proto board you used? I couldn't find it poking around a bit.
    Thanks for sharing it!
  • @mfalkvidd
    Thanks, it looks like the Rev 9?, where the older pic you posted looks like a smaller version. I didn't realize the board was rearranged between Rev9 and recent R10.
    Yes, that was Rev 9, but the sketch would work with anything you have
