My new project : texboard pcb
  • Hello
    I want to share with you my new little project. It's a pcb board (designed with eagle/produced by pcbway) for an easy integration of my future mysensors nodes.
    the functionalities are :
    • socket for atmega328p-pu
      -socket for nrf24l01
      -isp socket for programming the board
      -power supply : 3v - 20v
      -support for mesuring and reporting the battery level to the gateway
      -i2c socket
      -digital i/o for the sensor
    Some pictures of the board :
    I'm actually working on a v2 of the board with a micro usb port and smd mounting with atmega328p-au (to save place)
    @linkos nice work! One small suggestion is that you move the antenna on the radio outside the pcb. All the metal in traces and components might interfere with the signal.
  • Thanks for your answer.
    Yes it's a good idea to move the nrf because I've allready experienced reception problems. It's possible that's the cause was the position of the antenna. Thanks for the tip
    I agree with @sundberg84 suggestion. I think turning the radio around (180°) should be enough: no traces below antenna and no ISP header right in front. I would try to move the capacitor closer to the VCC/GND pins of the radio, too.
    Good job anyway, compact and clean looking sensor !
  • Thanks for your answer. I'll keep them in mind for the future version of my board.
    However thanks for the compliments
  • Hi
    I just finish the box for my new sensors. Just want to share it with you 🙂
    Very clean, now you can make a v2 with button cell to make the same with a tiny size 😉
  • Yes. you're right
    I just buy some CR2032 supports for pcb on ebay. I hope it will drain enouth power to run the node
    @linkos you need to include a capacitor (100-200uF) in parallel to the battery to help it during peak load. And if possible in your sketch add short sleeps between successive TX/RX to let capacitor recharge.
  • 90
  • 29
