Node to Node communication
  • Hello
    Is it possible for two nodes to directly talk to each other?
    If so can someone point me to an example of how to do this if it exists?
    I am have just a few sensors that I have manually assigned sensor ids to and I would like to have them talk to each other without necessarily needing a controller.
    Yes, messages follow this routing:
    Just use setDestination on the MyMessage before sending.
    On the receiving node you have to add a callback method for incoming messages and call gw.process() in loop().
  • @hek
    But you'd always need a gateway, correct?
    boozz
    Gateway or Repeater node (in a two sensor setup).
    In the picture above two leaf sensors (in the same "leaf") can talk to each other just via the repeater node.
  • @hek
    Ok, thanks!. For some reason I thought that always an gateway had to be involved. Good to know.
  • @hek does it mean that the radio in repeater side has to be always in awake position?
    @funky81
    Yes, that is probably best. 🙂
  • @hek noted... Thanks
  • I made a sketch that sends a V_VAR1 from node 7 to node 8
    send sketch
    int cval_use, cval_gen;#define CHILD_ID_WATT 0
    MyMessage msgVar1(CHILD_ID_WATT,V_VAR1);
    MyMessage msgVar2(CHILD_ID_WATT,V_VAR2);
    gw.send(msgVar1.setDestination(8).set(cval_use) );
    gw.send(msgVar2.setDestination(8).set(cval_gen) );
    receive sketch
    void incomingMessage(const MyMessage &message)
    if (message.isAck())
    //read: 7-0-8 s=1,c=1,t=25,pt=2,l=2:486
    if (message.type==V_VAR1)
    int Var1;
    Var1= atoi(message.data);
    Serial.println("#########V_VAR1#########");
    Serial.println("Var1");
    Serial.println(Var1);
    Serial.println("##########V_VAR1########");
    if (message.type==V_VAR2)
    int Var2;
    Var2 = atoi(message.data);
    Serial.println("########V_VAR2##########");
    Serial.println("Var2");
    Serial.println(Var2);
    My problem:
    Var1 and var2 ia alway 0.
    send sketch serial
    send: 7-7-0-8 s=1,c=1,t=24,pt=2,l=2,st=ok:580
    send: 7-7-0-8 s=1,c=1,t=25,pt=2,l=2,st=ok:0
    receiver sketch
    read: 7-0-8 s=1,c=1,t=24,pt=2,l=2:580
    Var1: 0
    read: 7-0-8 s=1,c=1,t=25,pt=2,l=2:0
    Var2: 0
    You'll probably have to use message.getInt() in the receiving node (because this data is transmitted in binary format).
  • Earlier today, I was fiddling with using setDestination() and always got st=fail showing up on the gateway, and the message never got to the node I wanted it to... And all the nodes were in my office at the time. I was running trunk for all libs.
    Any ideas what to look at? The gateway's error led never flashed, either.
    @krayola
    How did your network topology look like?
    Possible to show the debug log on gateway/repeater node (that should relay message)?
  • It seems #define DEBUG is on by default in master 🙂
    https://github.com/mysensors/Arduino/blob/9192da3a7d99171c2f42436a0a4ab8c72463119d/libraries/MySensors/MyConfig.h
    My topology seems to be flat right now. I only have 3 nodes + gateway at present.
    I did try having combination repeater+sensor nodes, but they were using sleep() which may have been part of the problem.
    When I use gw.request() I'm able to get messages from the gateway to the node in question (with appropriate controller logic).
    Here's the code on the test sensor:
    gw.send(msg.setSensor(i).set(temperature, 2).setDestination(1));
    Here's the sensor connecting and trying to send a message to node 1 (which is
    <- 0;0;3;0;9;send: 0-0-2-2 s=255,c=3,t=6,pt=0,l=1,st=fail:M
    <- 0;0;3;0;9;read: 2-2-0 s=255,c=3,t=11,pt=0,l=18:Temperature Sensor
    <- 2;255;3;0;11;Temperature Sensor
    <- 0;0;3;0;9;read: 2-2-0 s=255,c=3,t=12,pt=0,l=3:1.0
    <- 2;255;3;0;12;1.0
    <- 0;0;3;0;9;read: 2-2-0 s=0,c=0,t=6,pt=0,l=5:1.4.1
    <- 2;0;0;0;6;1.4.1
    <- 0;0;3;0;9;read: 2-2-1 s=0,c=1,t=0,pt=7,l=5:24.00
    <- 0;0;3;0;9;send: 2-0-1-1 s=0,c=1,t=0,pt=7,l=5,st=fail:24.00
    Node 1 was initialized:
    gw.begin(incomingMessage, AUTO, false);
    and uses
    gw.sleep(SLEEP_TIME);
    I thought I'd mention that having a request in the code makes it so i can reliably receives up to 2 messages from the gw (via the controller). Any more than that get lost.
    gw.request(outdoorTempSensorId, V_TEMP, outdoorTempNodeId);
    I clearly need to go read all the code 🙂 There's not that much of it.
    If your node expects messages you cannot sleep it. It must call gw.process() as often as possible.
  • I figured that out from the other thread 🙂
    I added this little helper to my copy of MySensors.cpp:
        void MySensor::wait(unsigned long ms) {
                bool slept_enough = false;
                unsigned long start = millis();
                unsigned long now;
                // Let serial prints finish (debug, log etc)
                Serial.flush();
                while (!slept_enough) {
                        MySensor::process();
                        now = millis();
                        if (now - start > ms) {
                                slept_enough = true;
    In theory it'll handle the millis() rollover, but I haven't verified yet.
    I'm now able to send messages between nodes with and without being in repeater mode. I have yet to test repeater mode, as i haven't convinced a sensor it can't see the gw yet 🙂
