12v Solar battery monitor
    I have made a change to the Sketch. I was saving my data to the same EEPROM positions that MySensors use for their data. So i have now moved well away from that area.
    Edit: No I wasn't so no changes were needed
    Here is a picture of the finished board
    I have used the PCB designed by @sundberg84
    Are you're sure, that 514 and 515 are vaild values? API documentation states, that pos parameter in saveState/loadState must be between 0 and 255. AFAIK data stored by saveState are written into a separate section of EEPROM, which doesn't interfere with MySensors own configuration data.
    @googlyeyz thanks for that info. I should have looked closer at the API. I originally used positions. 0 and 1 and thought that would conflict but I will now change back
  • Hi.
    I'm having some troubles trying to use the project.
    I have the solar pannel that goes directly to the solar regulator. In the solar regulator i have the battery connection and the load connection.
    In the battery connection i have my 12V battery connected and i have connected the arduinos over the load connection.
    My problem is that i dont see were to connect the ACS712 module on the solar regulator.
    At this moment i had connect the ACS712 over the load connection in the solar regulator but the values i'm getting are not correct...
    Can anyone give me a help to fiz this problem.
    The correct hookup for that type of regulator should look something like the picture below.
    Remember in this position the acs712 is reading current to and from the battery only. So if you had a load of 5A and your panel was supplying 3A then your readout would show a discharge of 2A
    If your reading is showing a discharge when it should be showing a charge then just reverse the connections at the acs712.
  • Thanks for the reply, i'm going to make the changes tonight.
    I'm getting readings from 8A to 18A this is not correct.
    How much current were you expecting to see
  • @Boots33 To be honest i just thought the values i was getting were too hight since the battery is 12V 20AH and i only have 4 arduino nano with some sensors using the power from the battery.
    Today with one day having the changes made like you have said to do, i have value from the battery between hight 8.2A and 6.6A low, but the media value is almost always on 7.4A.
    On the voltage side i'm getting high value 8.8V and low value 7.8V.
    Is this good values, correct values for a 12V battery ??
    I don't think those readings are correct. For a 12v battery it should be around 12.7v when full and not being charged. When it is being charged it should be up near 14v. Around 10.9v is considered fully discharged so your readings are way too low for a 12v battery. Your current readings seem too high as well for just a few arduino boards. Can you take some readings with a multimeter to cross check the data. Also check your 5v supply voltage, it is very important for this to be spot on 5v when taking analogue readings.
  • @Boots33 Have check the voltage from the battery and is on 12V at this time is discharging the current i couldn't get but tomorrow i'll make new readings and see the values.
    The 5V supply voltage is set to 5.02V will have to reduce the 0.02V to get just 5V.
    Thanks for your help.
    I should think 5.02v will be close enough. What value resistors are you using for your voltage divider.
    We appear to be operating in different time zones so have posted a couple of things to try.
    The first thing to do is re-check all your wiring, I know you probably have done that already but best to make sure anyway.
    Then you should try and isolate the cause of your problems.
    lets start with the voltage readings.
    This line of code in the sketch
    int voltSenseMax = 25000;
    is where you set the maximum input voltage of your voltage divider. If you are not using the 25v voltage sensor module you will need to change the 25000 to suit your voltage divider, by changing that value up or down you can also make adjustments in the voltage reading to fine tune the output. Your reading seems to be out by a few volts so i think you should take a look at the voltage divider first and see if you can locate the reason.
    I will show the way to check the 25v module and you can use the same method to work out the values if you have used a different divider.
    Because we are using a voltage divider to alter the 12v battery voltage into a 5 volt representation that the Arduino can use we will need to work out what voltage we are expecting to see at pin A0
    the formula we need is
    ArduinoIn = (BatVolts/voltsPerCount25)*voltsPerCount5
    first we need the voltsPerCount25 for the 25v divider, so that will be 25/1024 which = .02441
    then we need the voltsPerCount5 for the Arduino 5v input 5/1024 which = .00488
    BatVolts is the actual battery voltage, you will need to measure this with your multimeter.
    So as an example
    If you measured your battery and it has 11.3v
    (11.3/.02441)*.00488 = 2.26v
    So if the voltage divider is working ok we would expect to see a voltage of around 2.3v at the arduino input. Which would = a count of (2.3/.00488) around 471
    You can also remove the comments from the two Serial.print lines in this part of the sketch to see what the Arduino is producing
    // ------------------ Start voltage readings --------------------
     sample_count = 0;
     sum = 0;
     while (sample_count < NUM_SAMPLES) {                                   // take a number of voltage samples
      sum += analogRead(voltagePin);
      sample_count++;
      delay(10);
    //Serial.print("sum count..."); Serial.println((sum / NUM_SAMPLES));      // print the count result. will be between 0 and 1023
    int voltageI = map(sum/NUM_SAMPLES,0,1023,0,voltSenseMax);              // map the reading and get our result in millivolts
    //Serial.print("mapped volts..."); Serial.println(voltageI / 1000.0, 1);  // convert millivolts back to volts and print. the 1 at the end determines how many decimal places to show
    Here are what my graphs look like. You can see your voltage should be a bit higher if all is well
  • Hi. i have read the post's you have made, one problem i have found its on the voltage sensing module don't now why it's not workin, simply dead, i have already bought 3 other modules and now i'm waiting for them to arrieved hope to get them until friday.
    Have seen your graphs and they are really differents from mine.
    Once again today with the multimeter i've made some readings from the battery and i got values in 13,2V - 12,9V and this values were measured at 19:00
    Once again Thanks for helping me
  • @Boots33 said:
    30k for R1 and 7.5k for R2
    I was going to try to build the voltage sensing but i don't have any 7.5K resistor.... i can put 3 10k Resistors in serie to get the 30k Resistor but i cant make the 7.5K.
    Can i use one 10K resistor in the place of the 7.5K, will this work ?? or will the values i'll get be rong??
    Yes that would work. That would give you a maximum input of 20v so you will need to change relevant line in the sketch from 25000 to 20000
    You can try different values on this web site. http://www.raltron.com/cust/tools/voltage_divider.asp
  • I'm going to try this way and see what values i'll get.
    Once again thanks.
  • I really don't get this.
    Has i can see i did everything correct but i'm still getting weard values.... In the charge regulator that i have the solar30 i'm connecting the ACS712 like you told.
    The voltage dividir i had it connected also on the battery vcc for the 30K resistor and ground on the 10K resistor, over the code i ahd change the "voltSenseMax" to 20000.
    With this changes the House battery went from 8.4V to 16.2V but when i make the reading off the battery with a multimeter i get 13V and also the charge regulator screen shows 13V...
    The charge current is over 0A now but is night at my place ill wait until tomorrow to see if this values change over the morning and day.
    The load current is 9.1A this one i dont get it...
    When you were measuring 13v at the battery what was the voltage at pin A0 on the arduino. You will need to compare the readings to see if the divider is working correctly. Have you removed the comments on the serial print lines , you can then check those results with your other measurements. Also check the resistance of the resistors in your voltage divider with your multimeter to make sure they are close to the values you expect.
    From what I can see in the picture the asc712 looks to be hooked up OK. They are very sensitive to electromagnetic interference so you may want to try it further away from your regulator.
  • Hi.
    Ok i did not measure the pin A0 when i was measuring de 13V over the battery but i can do that.I have removed the comments but i hook up the arduino in the battery box and did not look over the serie monitor on PC, once again i'll do that today.
    I think the voltage divider i ok, i did a check using a 3,7V battery and the values ia had get with the voltage divider were 0,20% differente from the ones i was getting over the multimeter, 3.2V to 3.4V
    I'm going to mak some changes over the place were the asc712 is, i have a box on the wall 40cm to 80cm distance off the batteryes. That's were the ACS712 is going to be.
  • Just took the readings from pin A0 and the values are 3.2V when the battery readins says 13V.
    The house battery is fix at 16V or 16.2V but i could not move the acs712 to the box i wanted it's night now and i can't see well, sow this change will be done tomorrow. While i'm wainting let's see if this 16V changes during the day off tomorrow.
    Well it's being dificult to get this project work like a charm but it's staring to get tune up thank's to your help Boots33.
  • I've a mistake when said 4 arduino nano with some sensors, correcting this mistake:
    1º arduino nano with UV sensor;
    1º arduino nano with lux sensor, pressure sensor, temp/hum sensor and one anemometer; "this is my meteo box sensor"
    1º arduino nano with the acs712, voltage sensor and the dallas temperature sensor
    1º arduino nano controling a rain gauge.
    It's 4 arduino nano with 7 sensors, i don't believe that all this put together are draining 8.6A from the battery. Isn't this a too high value ?
    3.2v at A0 sounds about right for a 20v divider reading 13v at the battery. So your divider seems to be OK. you now need to check the results from those serial print statements and see how they compare.
    The code for the voltage measurement is pretty simple with the map function doing most of the work. Not a lot to go wrong there I think. But we will know more when you get the above results.
    8.6A is too high for the current. if you were drawing that much your 20ah battery would be flat in a couple of hours, so the reading is wrong. Can you check with your multimeter and see how much is being drawn. I would not think it would even be 1 amp with just 4 arduino's connected
    With a 3.2v at A0 you should have a count of around 656 from the serial print
  • Hi once again.
    Today i had to dismount all the solar system my arduino nano just died... don't now why and also the repeater node also dead...
    I had replaced the arduino for the solar system i had also put he battery inside my house to make all the tests.
    here is the serial monitor log:
    Requesting temperatures...
    sum count...511
    mapped volts...10.0
    Milliamps...-95
    sum count...522
    mapped volts...10.2
    send: 6-6-3-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=ok:10.2
    Milliamps...-95
    sum count...506
    mapped volts...9.9
    send: 6-6-3-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=ok:9.9
    Milliamps...-95
    sum count...511
    mapped volts...10.0
    send: 6-6-3-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=ok:10.0
    Milliamps...-95
    sum count...511
    mapped volts...10.0
    Milliamps...-95
    sum count...511
    mapped volts...10.0
    Milliamps...-95
    sum count...511
    mapped volts...10.0
    Milliamps...-95
    One thing i had notice now is that house voltage is 10V but solar regulator and multimeter says 13V, and i had moved the acs712 away from the battery.
    The test i made was one CPU fan connect to the solar regulator load, this fan is 12A - 0.25A.
    Running the fan the solar regulator shows a Load off 0.1A and the arduino shows values between 0A and 0.3A
    send: 6-6-3-0 s=255,c=0,t=17,pt=0,l=5,sg=0,st=ok:1.5.1
    send: 6-6-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:3
    sensor started, id=6, parent=3, distance=2
    send: 6-6-3-0 s=255,c=3,t=11,pt=0,l=21,sg=0,st=ok:Battery Status Sensor
    send: 6-6-3-0 s=255,c=3,t=12,pt=0,l=1,sg=0,st=ok:1
    send: 6-6-3-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=fail:
    send: 6-6-3-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=fail:
    send: 6-6-3-0 s=3,c=0,t=38,pt=0,l=0,sg=0,st=fail:
    send: 6-6-3-0 s=4,c=0,t=39,pt=0,l=0,sg=0,st=fail:
    send: 6-6-3-0 s=5,c=0,t=39,pt=0,l=0,sg=0,st=fail:
    sum count...511
    mapped volts...10.0
    send: 6-6-3-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=fail:10.0
    find parent
    send: 6-6-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,st=bc:
    Milliamps...52
    send: 6-6-3-0 s=4,c=1,t=39,pt=7,l=5,sg=0,st=ok:0.1
    send: 6-6-3-0 s=5,c=1,t=39,pt=2,l=2,sg=0,st=fail:0
    send: 6-6-3-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:30.3
    send: 6-6-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=fail:-127.0
    sum count...517
    mapped volts...10.1
    send: 6-6-3-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=ok:10.1
    Milliamps...200
    send: 6-6-3-0 s=4,c=1,t=39,pt=7,l=5,sg=0,st=ok:0.2
    send: 6-6-3-0 s=5,c=1,t=39,pt=2,l=2,sg=0,st=ok:0
    send: 6-6-3-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:29.9
    sum count...511
    mapped volts...10.0
    Milliamps...126
    OK that is good you can now see the serial print lines. The voltage conversion seems to look ok .... a count of 511 shows a voltage of 10. So now I need you to get all the readings at once
    measure battery voltage
    measure pin A0 voltage
    and show the serial data as you have above
    then we can see where the trouble lies
  • Battery Voltage - 13.09
    pin A0 - 1.055
    send: 6-6-3-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=fail:3
    send: 6-6-3-0 s=255,c=3,t=12,pt=0,l=1,sg=0,st=fail:1
    send: 6-6-3-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
    send: 6-6-3-0 s=4,c=0,t=39,pt=0,l=0,sg=0,st=ok:
    sum count...532
    mapped volts...10.4
    send: 6-6-3-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=fail:10.4
    Milliamps...347
    send: 6-6-3-0 s=4,c=1,t=39,pt=7,l=5,sg=0,st=fail:0.3
    send: 6-6-3-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:29.5
    send: 6-6-3-0 s=1,c=1,t=0,pt=7,l=5,sg=0,st=ok:-127.0
    sum count...513
    mapped volts...10.0
    Milliamps...347
    send: 6-6-3-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:29.4
    sum count...519
    mapped volts...10.1
    Milliamps...421
    send: 6-6-3-0 s=4,c=1,t=39,pt=7,l=5,sg=0,st=ok:0.4
    sum count...511
    mapped volts...10.0
    Milliamps...347
    send: 6-6-3-0 s=4,c=1,t=39,pt=7,l=5,sg=0,st=ok:0.3
    send: 6-6-3-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:29.4
    sum count...511
    mapped volts...10.0
    Milliamps...347
    send: 6-6-3-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:29.5
    sum count...511
    mapped volts...10.0
    Milliamps...200
    sum count...485
    mapped volts...9.5
    send: 6-6-3-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=ok:9.5
    Milliamps...273
    sum count...510
    mapped volts...10.0
    Milliamps...347
    sum count...501
    mapped volts...9.8
    send: 6-6-3-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=ok:9.8
    Milliamps...347
    sum count...511
    mapped volts...10.0
    Milliamps...347
    Once again i had connect the 12v fan to the load of the charge regulator
    If you are still using the 20v divider, with a battery voltage of 13.09 you should have a voltage of 3.27 at pin A0
    1.055v is way too low, check you connections to make sure they are tight. measure the voltage at the divider input to make sure the 13v is there as well.
    post results again
  • 3.29v It's the value i'm getting at the end off the 20v divider but at pin A0 i have 1.23V
    sum count...198
    mapped volts...3.9
    send: 6-6-3-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=ok:3.9
    Milliamps...200
    sum count...511
    mapped volts...10.0
    Milliamps...126
    sum count...511
    mapped volts...10.0
    Milliamps...-21
    send: 6-6-3-0 s=4,c=1,t=39,pt=2,l=2,sg=0,st=ok:0
    send: 6-6-3-0 s=5,c=1,t=39,pt=7,l=5,sg=0,st=fail:0.0
    sum count...520
    mapped volts...10.2
    Milliamps...126
    sum count...533
    mapped volts...10.4
    send: 6-6-3-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=ok:10.4
    Milliamps...52
    sum count...511
    mapped volts...10.0
    Milliamps...-21
    send: 6-6-3-0 s=5,c=1,t=39,pt=7,l=5,sg=0,st=ok:0.0
    sum count...511
    mapped volts...10.0
    Milliamps...200
    then that is where the problem may be. the output of the divider should be connected to A0 so they should be the same. look at the diagram below
  • I think the problem is fix now.
    bad cable between ground from 20v divider and arduino ground.
    now i'm getting the same value at pin a0
    here are the new logs
    send: 6-6-3-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
    send: 6-6-3-0 s=5,c=0,t=39,pt=0,l=0,sg=0,st=ok:
    sum count...715
    mapped volts...14.0
    send: 6-6-3-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=ok:14.0
    Milliamps...-21
    send: 6-6-3-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:29.3
    sum count...710
    mapped volts...13.9
    send: 6-6-3-0 s=3,c=1,t=38,pt=7,l=5,sg=0,st=ok:13.9
    Milliamps...52
    sum count...713
    mapped volts...13.9
    Milliamps...-21
    sum count...711
    mapped volts...13.9
    Milliamps...200
    sum count...712
    mapped volts...13.9
    Milliamps...200
    sum count...709
    mapped volts...13.9
    Milliamps...126
    sum count...713
    mapped volts...13.9
    Milliamps...126
    still using the cpu fan 12v 0.25A pin A0 3.28V
    Mapped volts 13.9 it's very near the 13.2V the multimeter gives at the battery.
    This is the best results i had until now.
    Thanks boots33 for all your help.
    Great to hear you have found the problem. If the voltages are not quite correct you can adjust the 20000 value up or down a bit as needed to fine tune the output result.
    You can use these to check for the problem
    for a 20v divider
    20/1024 = .019531
    to get the count that should be shown by serial print...: batteryvoltage / .019531
    so with your reading 13.09 / .019531 = 670
    That means you should see a count of 670 from the serial print
    to get the voltage that should be at pin A0...: count * .00488
    670 * .00488 = 3.27v
    to get the map result
    20000/1024 = 19.531mv or .01953v
    so 670 * .01953 = 13.1v
    The best way to setup the acs712 is to put it where it is going to be mounted but have no current going through it. (you can just disconnect one power lead) it should show a reading close to zero.
    If not push the button and hold till the led flashes (may take a while depending on how much delay you are using) once the led flashes you can let go of the button and the offset to zero the reading will be applied. This offset will also be saved in the arduino eeprom so it will be reloaded if the arduino is rebooted etc.
    then the readings should be very close to zero.
    you can now reconnect and it should give you the correct reading.
  • Hallo
    Mein Englisch ist nicht so gut.
    Ich habe versucht das Projekt nach zu bauen. Den Button brauche ich (denke ich) nicht, dafür habe ich das script jedoch um 2 weitere current und voltage Sensoren erweitert. Das Ziel ist 3 mal Current und 3 mal Volt als Ergebnis zu bekommen. Ich habe 30A Sensoren und einen 30A Laderegler. Dazwischen sind jeweils 30A Sicherungen.
    Leider kommt in Domoticz aber nur ein mal Volt und 2 mal Current an. Leider habe ich auch nicht wirklich viel Ahnung vom Programmieren. Könnte hier mal jemand über den Sketch gucken um zu sehen ob ich einen Fehler darin habe?
    /*Sketch for a MySensor node to monitor a 12v battery with a solar panel for charging
     * The node monitors battery voltage,current into and out of the battery, ambient temperature and battery temperature.
     * 2 x DS18b20 dallas temperature ic's their data pins connected to arduino digital pin 3
     * 1 x ACS712 current sensor module connected to  arduino analog pin A4
     * 1 x 25v voltage sensor module connected to arduino analog pin A0
     * 1 x nRF24L01+  2.4ghz tranceiver connected as per the MySensors web site.
     * 1 x LED connected via a 330 ohm resistor to pin 6
     * 1 x push button connected to pin 5
    #include <OneWire.h>
    #define ONE_WIRE_BUS 3                       // Ds18b20 data wire is connected to digital pin 3 on the Arduino
    #define ID_S_TEMPA 0                         // First temp device
    #define ID_S_TEMPB 1                         // second temp device
    #define ID_S_MULTIMETERV1 3                   // Multimeter device for voltage measurement
    #define ID_S_MULTIMETERC1 4                   // Multimeter device for positive current measurement
    #define ID_S_MULTIMETERC11 5                  // Multimeter device for negative current measurement
    #define ID_S_MULTIMETERV2 3                   // Multimeter device for voltage measurement
    #define ID_S_MULTIMETERC2 4                   // Multimeter device for positive current measurement
    #define ID_S_MULTIMETERC12 5                  // Multimeter device for negative current measurement
    #define ID_S_MULTIMETERV3 6                   // Multimeter device for voltage measurement
    #define ID_S_MULTIMETERC3 7                   // Multimeter device for positive current measurement
    #define ID_S_MULTIMETERC13 8
    #define NUM_SAMPLES 10                       // number of analog voltage samples to take per reading
    int ledPin = 6;                               // the pin for the LED
    int buttonPin = 5;                            // the input pin for offset pushbutton
    int buttonState = 0;                          // variable for reading the pin status
    unsigned long SLEEP_TIME = 30000;            // Sleep time between reads (in milliseconds)
    int lastmilli1 = 25000;                       // set to an arbitary number outside of expected current sensor range to ensure a change when first run
    int lastmilli2 = 25000;                       // set to an arbitary number outside of expected current sensor range to ensure a change when first run
    int lastmilli3 = 25000;                       // set to an arbitary number outside of expected current sensor range to ensure a change when first run
    float sensitivity = 66 ;                    //change this to 185 for ACS712-5 or to 100 for ACS712-20A or to 66 for ACS712-30A
    int VQ = 0;                                  //Placeholder for quiescent voltage calculations
    int ACSPin1 = A4;                             // Analog pin number the ACS712 data pin connects to
    int ACSPin2 = A5;                             // Analog pin number the ACS712 data pin connects to
    int ACSPin3 = A3;                             // Analog pin number the ACS712 data pin connects to
    float lastTemperature[2];                    //Array to hold the last temp readings sent to gateway, only send new data if different
    int sum = 0;                                 // sum of voltage samples taken
    unsigned char sample_count = 0;              // current sample number
    int lastVoltage1 = 30000;                     // set to an arbitary number outside of expected voltage sensor range to ensure a change when first run
    int lastVoltage2 = 30000;                     // set to an arbitary number outside of expected voltage sensor range to ensure a change when first run
    int lastVoltage3 = 30000;                     // set to an arbitary number outside of expected voltage sensor range to ensure a change when first run
    int voltagePin1 = A0;                         // analog pin voltage sensor or voltage divider is connected to
    int voltagePin2 = A1;                         // analog pin voltage sensor or voltage divider is connected to
    int voltagePin3 = A2;                         // analog pin voltage sensor or voltage divider is connected to
    int voltSense1Max = 25000;                    // set to the maximum input voltage in millivolts of your voltage divider input
    int voltSense2Max = 25000;                    // set to the maximum input voltage in millivolts of your voltage divider input
    int voltSense3Max = 25000;                    // set to the maximum input voltage in millivolts of your voltage divider input
    OneWire oneWire(ONE_WIRE_BUS);               // Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
    DallasTemperature sensors(&oneWire);         // Pass our oneWire reference to Dallas Temperature.
    // ------ Initialize  messages -------
    MyMessage msg(0,V_TEMP);
    MyMessage msg_S_MULTIMETERv1(ID_S_MULTIMETERV1,V_VOLTAGE);
    MyMessage msg_S_MULTIMETERc1(ID_S_MULTIMETERC1,V_CURRENT);
    MyMessage msg_S_MULTIMETERc11(ID_S_MULTIMETERC11,V_CURRENT);
    MyMessage msg_S_MULTIMETERv2(ID_S_MULTIMETERV2,V_VOLTAGE);
    MyMessage msg_S_MULTIMETERc2(ID_S_MULTIMETERC2,V_CURRENT);
    MyMessage msg_S_MULTIMETERc12(ID_S_MULTIMETERC12,V_CURRENT);
    MyMessage msg_S_MULTIMETERv3(ID_S_MULTIMETERV3,V_VOLTAGE);
    MyMessage msg_S_MULTIMETERc3(ID_S_MULTIMETERC3,V_CURRENT);
    MyMessage msg_S_MULTIMETERc13(ID_S_MULTIMETERC13,V_CURRENT);
    sensors.begin();                                    // Start up the onewire library
    gw.begin();                                         // Startup and initialize MySensors library. Set callback for incoming messages.
    gw.sendSketchInfo("Battery Status Sensor", "1");    // Send the sketch version information to the gateway and Controller
    // ------ Present all sensors to controller ------
    gw.present(ID_S_TEMPA, S_TEMP);
    gw.present(ID_S_TEMPB, S_TEMP);
    gw.present(ID_S_MULTIMETERV1,V_VOLTAGE);
    gw.present(ID_S_MULTIMETERC1,V_CURRENT);
    gw.present(ID_S_MULTIMETERC11,V_CURRENT);
    gw.present(ID_S_MULTIMETERV2,V_VOLTAGE);
    gw.present(ID_S_MULTIMETERC2,V_CURRENT);
    gw.present(ID_S_MULTIMETERC12,V_CURRENT);
    gw.present(ID_S_MULTIMETERV3,V_VOLTAGE);
    gw.present(ID_S_MULTIMETERC3,V_CURRENT);
    gw.present(ID_S_MULTIMETERC13,V_CURRENT);
    pinMode(buttonPin, INPUT_PULLUP);                     // Set buttonPin as input and turn on internal pull up resistor
    pinMode(ledPin, OUTPUT);                              // Set ledPin as output
    digitalWrite(ledPin, LOW);                            // Make sure ledPin is off
    // ------ load offset for current sensor
    int validCheck = gw.loadState(0);
    if (validCheck == 120){                          // check to see if valid data exists
      VQ = gw.loadState(1);                               // Load count offset into VQ
    //  Serial.print(" positive VQ offset loaded..."); Serial.println(VQ);
     else if (validCheck == 125) {
      VQ = -abs(gw.loadState(1));
    //  Serial.print(" negative VQ offset loaded..."); Serial.println(VQ);
    else {
    // Serial.println("VQ offset not set");
    delay(500);
    buttonState = digitalRead(buttonPin);
    //Serial.print("buttonstate..."); Serial.println(buttonState);
     if (buttonState == LOW) {
        VQ = determineVQ(ACSPin1);                           //Returns the offset count needed to show zero with no load
      if (VQ >= 0 && VQ < 255) {                              //check for valid data. VQ is positive number
        gw.saveState(0, 120);                               // Store 120 value  in eeprom position 0. use this to check for valid data at boot
        gw.saveState(1, VQ);                                // Store offset count in eeprom. in case of re-boot
      else if (VQ < 0 && VQ > -255) {                              // VQ is a negative number. negatives cannot be stored in eeprom
        gw.saveState(0, 125);                               // Store 125 value  in eeprom position 0. use this to check for valid data at boot
        gw.saveState(1, abs(VQ));                                // convert VQ to positive and  Store offset count in eeprom. in case of re-boot
    // ------------------ Start voltage 1 readings --------------------
     sample_count = 0;
     sum = 0;
      sum += analogRead(voltagePin1);
      sample_count++;
      delay(10);
    int voltage1I = map(sum/NUM_SAMPLES,0,1023,0,voltSense1Max);              // map the reading and get our result in millivolts
    if ( voltage1I != lastVoltage1) {                                         // check if we have a new value. only send data if it is different
     gw.send(msg_S_MULTIMETERv1.set(voltage1I / 1000.0, 1));                  // voltagel is in millivolts so we divide by 1000 to convert back to volts and
        // send voltage message to gateway with 1 decimal place
     lastVoltage1 = voltage1I;                                                // copy the current voltage reading for testing on the next loop
    //--------------------Start Current 1 readings---------------------------------
    int milli1 = readCurrent(ACSPin1);                                       // take a reading from the ACS712 and send to the readcurrent function
    //Serial.print("Milliamps..."); Serial.println(milli);                   // print the value (in milliamps) returned
    if ( milli1 != lastmilli1)                                               // check if value has changed
     if ( milli1 > 0)                                                       // Battery is charging
      gw.send(msg_S_MULTIMETERc1.set(milli1/1000.0, 1));                     // Send new data to charging amp device
      gw.send(msg_S_MULTIMETERc11.set(0));                                  // set the dis-charging amp device to zero
      lastmilli1 =  milli1;
     else if (milli1 < 0)                                                  // Battery is discharging
      gw.send(msg_S_MULTIMETERc1.set(0));                                  // set the charging amp device to zero
      gw.send(msg_S_MULTIMETERc11.set(abs(milli1)/1000.0, 1));             //  use abs(milli) to Send a positive number  to dis-charging amp device
    else        // No current flowing, set both to zero
    //----------------------Teperature readings start------------------------
      Serial.println(" Requesting temperatures...");
      sensors.requestTemperatures();                  // call sensors.requestTemperatures() to issue a global temperature request to all devices on the bus
      // ------- query conversion time and sleep until conversion completed ------
      gw.sleep(conversionTime);
     for (int i=0; i<2; i++) {
    //  Serial.print("Temperature for Device: ");Serial.print(i);Serial.print(" is: ");
     // Serial.println(sensors.getTempCByIndex(i)); // Why "byIndex"?
        // You can have more than one IC on the same bus.
        // 0 refers to the first IC on the wire
     float temperature = static_cast<float>(static_cast<int>((sensors.getTempCByIndex(i)) * 10.)) / 10.;  // Fetch and round temperature to one decimal in celcius
    if (lastTemperature[i] != temperature)               // check for a changed temperature reading
       gw.send(msg.setSensor(i).set(temperature,1));     // Send in the new temperature
       lastTemperature[i]=temperature;                   // Save new temperatures for next compare
    // ------------------ Start 2 voltage readings --------------------
     sample_count = 0;
     sum = 0;
      sum += analogRead(voltagePin2);
      sample_count++;
      delay(10);
    int voltage2I = map(sum/NUM_SAMPLES,0,1023,0,voltSense2Max);              // map the reading and get our result in millivolts
    if ( voltage2I != lastVoltage2) {                                         // check if we have a new value. only send data if it is different
     gw.send(msg_S_MULTIMETERv2.set(voltage2I / 1000.0, 1));                  // voltagel is in millivolts so we divide by 1000 to convert back to volts and
     lastVoltage2 = voltage2I;                                                // copy the current voltage reading for testing on the next loop
    //--------------------Start Current 2 readings---------------------------------
    int milli2 = readCurrent(ACSPin2);                                       // take a reading from the ACS712 and send to the readcurrent function
    if ( milli2 != lastmilli2)                                               // check if value has changed
     if ( milli2 > 0)                                                       // Battery is charging
      gw.send(msg_S_MULTIMETERc2.set(milli2/1000.0, 1));                     // Send new data to charging amp device
      gw.send(msg_S_MULTIMETERc12.set(0));                                  // set the dis-charging amp device to zero
      lastmilli2 =  milli2;
      gw.send(msg_S_MULTIMETERc2.set(0));                                  // set the charging amp device to zero
      gw.send(msg_S_MULTIMETERc12.set(abs(milli2)/1000.0, 1));             //  use abs(milli) to Send a positive number  to dis-charging amp device
    // ------------------ Start voltage 3 readings --------------------
     sample_count = 0;
     sum = 0;
      sum += analogRead(voltagePin3);
      sample_count++;
      delay(10);
    int voltage3I = map(sum/NUM_SAMPLES,0,1023,0,voltSense3Max);              // map the reading and get our result in millivolts
    if ( voltage3I != lastVoltage3) {                                         // check if we have a new value. only send data if it is different
     gw.send(msg_S_MULTIMETERv3.set(voltage3I / 1000.0, 1));                  // voltagel is in millivolts so we divide by 1000 to convert back to volts and
     lastVoltage3 = voltage3I;                                                // copy the current voltage reading for testing on the next loop
    //--------------------Start Current 3 readings---------------------------------
    int milli3 = readCurrent(ACSPin3);                                       // take a reading from the ACS712 and send to the readcurrent function
    if ( milli3 != lastmilli3)                                               // check if value has changed
     if ( milli3 > 0)                                                       // Battery is charging
      gw.send(msg_S_MULTIMETERc3.set(milli3/1000.0, 1));                     // Send new data to charging amp device
      gw.send(msg_S_MULTIMETERc13.set(0));                                  // set the dis-charging amp device to zero
      lastmilli3 =  milli3;
     else if (milli3 < 0)                                                  // Battery is discharging
      gw.send(msg_S_MULTIMETERc3.set(0));                                  // set the charging amp device to zero
      gw.send(msg_S_MULTIMETERc13.set(abs(milli3)/1000.0, 1));             //  use abs(milli) to Send a positive number  to dis-charging amp device
    gw.sleep(SLEEP_TIME);
    /*-------------- Function to get the offset required for ACS712 to show zero with no current flowing -----------------*/
    int determineVQ(int PIN)
      digitalWrite(ledPin, HIGH);                                      // Turn on LED to indicate offset being calculated
      delay(500);                                                      // Delay to hold LED on
      digitalWrite(ledPin, LOW);                                       // Turn off LED
      delay(150);                                                      // Delay to let readings stabilise
    //  Serial.print("estimating avg. quiscent voltage:");
      long acsCount = 0;
      for (int i=0; i<5000; i++)                                       //read 5000 samples to stabilise value
        acsCount += analogRead(PIN);                                   // read the count value between 0 and 1023 and add it to acsCount
        delay(1);
      acsCount /= 5000;                                                      // acsCount now eaquals the average of the 5000 readings taken
    //  Serial.print(map(acsCount, 0, 1023, 0, 5000));Serial.println(" mV");   //Print the avg in millivolts
    //  Serial.print("acsCount:");Serial.println(acsCount);                               //Print the actual count value
      return int(acsCount - 512);                                            // return the count difference. 512 is the count for 2.5v which is what the reading should be with no current flow
     /*--------------- Function to read current flowing ------------------*/
    int readCurrent(int PIN)
     int count = 0;
     for (int i=0; i<5; i++)                                        //read 5 analog count samples to stabilise value
       count += analogRead(PIN) - VQ;                               //subtract the offset count VQ to improve accuracy
       delay(1);
     //  Serial.print("raw count..."); Serial.println(count);
     /* Notes on the conversion below
      *  .00488 is the volt value per count of the arduino adc. The analog pin measures from 0 to 5 volt and then assigns the result to
      *  a count from 0 to 1023, thats 1024 counts including zero. If we devide 5v by 1024 we get .oo488 volts for each count.
      *  The (count/5) just gets us the average of our 5 count samples.
      *  So after the first part of the equation  (.00488 * (count/5) is complete we have converted our count reading into volts.
      *  The ACS712 can measure current flow in both directions so it outputs a voltage of  2.5v as it's center point (when no current is flowing).
      *  To allow for this offset we must subtract the 2.5v to center our voltage reading.
      * Thats what the next part does (.00488 * (count/5)) - 2.5) After this is complete we are left with either a negative or  positive voltage
      * reading or a reading of zero for no current flow.
      * NOTE: While the ACS712 is a 5v device it does not use the full 0 to 5v for it's output. The datasheet shows the 20A version has a sensitivity of
      *  100mv per amp, so if we multiply 100mv by 20 we get 2v.  That means the 20A ACS712 has an output range from .5v to 4.5v.
      * So to convert our reading in volts to a reading in amps we need to add the last part ((.00488 * (count/5)) - 2.5)/(sensitivity/1000).
      * The variable sensitivity is defined at the begining of the sketch and holds the ACS712 sensitvity amount, it is stored in millivolts.
      * That is 66mv for the 30amp,  100mv for the 20amp and 185mv for the 5amp. As sensitivity is in millivolts we need to devide it by 1000
      * to convert it back to volts so we can use it in the equation.
      * Now we have our Amps value stored in the float amps. Integers are much easier to work with when checking for zero so we multiply by 1000
      * to convert it to milliamps and return it as an integer.
    //Serial.print("VQ = ..."); Serial.println(VQ);
    //Serial.print("current count..."); Serial.println(count/5);
    //Serial.print("map  milliamps..."); Serial.println(map((count/5), 102, 922, -20000, 20000));
     float amps = ((.00488 * (count/5)) - 2.5) / (sensitivity/1000);
    // Serial.print("float amps..."); Serial.println(amps, 1);
      return int (amps * 1000);                                         // convert to milliamps and return as an integer
    Insert Code Here
    English:
    Hello
    My English is not that good.
    I tried to build the project. The button I need (I think) not, but I have extended the script, however, by 2 more current and voltage sensors. The goal is to get 3 times Current and 3 times Volt as a result. I have 30A sensors and a 30A charger. In between are 30A fuses.
    Unfortunately in Domoticz but only one time Volt and 2 times Current. Unfortunately I have not really much idea of ​​the programming. Could someone here over the sketch look around to see if I have a mistake in it?do i
    @aDm1N
    Do you have a log of the data being sent from the node? What mysensors library version are you using?
  • Hi. i have been working on this solar code and have made the changes to work over mysensors 2.1.1
    I'm now triyng to add a line code to monitor the voltage from the solar panels. Can anyone give me a help on this?
    I want to now the voltage watts or kws produce over my pannels. The idea is to have domoticz monitoring all data produce over the solar pannel.
    #define MY_REPEATER_FEATURE
    #define ID_S_TEMP_A 0                             // First temp device
    #define ID_S_TEMP_B 1                             // Second temp device
    #define ID_S_MULTIMETERV 3                        // Multimeter device for voltage measurement
    #define ID_S_MULTIMETERC 4                        // Multimeter device for positive current measurement
    #define ID_S_MULTIMETERC1 5                       // Multimeter device for negative current measurement
    int lastmilli = 25000;                            // set to an arbitary number outside of expected current sensor range to ensure a change when first run
    float sensitivity = 66 ;                          // change this to 185 for ACS712-5 or to 100 for ACS712-20A or to 66 for ACS712-30A
    int VQ = 0;                                       // Placeholder for quiescent voltage calculations
    int ACSPin = A4;                                  // Analog pin number the ACS712 data pin connects to
    float lastTemperature[2];                         // Array to hold the last temp readings sent to gateway, only send new data if different
    int lastVoltage = 30000;                          // set to an arbitary number outside of expected voltage sensor range to ensure a change when first run
    int voltagePin = A0;                              // analog pin voltage sensor or voltage divider is connected to
    int voltSenseMax = 25000;                         // set to the maximum input voltage in millivolts of your voltage divider input
    // ------ Initialize  messages ------- //
    MyMessage msg_S_MULTIMETERv(ID_S_MULTIMETERV,V_VOLTAGE);
    MyMessage msg_S_MULTIMETERc(ID_S_MULTIMETERC,V_CURRENT);
      sendSketchInfo("Battery Status Sensor", "2.1.1");
      present(ID_S_TEMP_A, S_TEMP);
      present(ID_S_TEMP_B, S_TEMP);
      present(ID_S_MULTIMETERV,V_VOLTAGE);
      present(ID_S_MULTIMETERC,V_CURRENT);
      int validCheck = loadState(0);
      if (validCheck == 120)                                // check to see if valid data exists
        VQ = loadState(1);                                  // Load count offset into VQ
        //Serial.print(" positive VQ offset loaded..."); Serial.println(VQ);
        VQ = -abs(loadState(1));
        //Serial.print(" negative VQ offset loaded..."); Serial.println(VQ);
        //Serial.println("VQ offset not set");
      delay(500);
        VQ = determineVQ(ACSPin);                           // Returns the offset count needed to show zero with no load
        {                                                   // check for valid data. VQ is positive number
        else if (VQ < 0 && VQ > -255)                       // VQ is a negative number. negatives cannot be stored in eeprom
    //-------------------------------------------- Start voltage readings ----------------------------------------------------
      sample_count = 0;
      sum = 0;
      while (sample_count < NUM_SAMPLES)                     // take a number of voltage samples
        sample_count++;
        delay(10);
      if ( voltageI != lastVoltage)                                               // check if we have a new value. only send data if it is different
        send(msg_S_MULTIMETERv.set(voltageI / 1000.0, 1));                        // voltagel is in millivolts so we divide by 1000 to convert back to volts and send voltage message to gateway with 1 decimal place
        lastVoltage = voltageI;                                                   // copy the current voltage reading for testing on the next loop
    //---------------------------------------- Start Current readings ---------------------------------------------------------
      int milli = readCurrent(ACSPin);                                            // take a reading from the ACS712 and send to the readcurrent function
      if ( milli != lastmilli)                                                    // check if value has changed
        if ( milli > 0)                                                           // Battery is charging
          send(msg_S_MULTIMETERc.set(milli/1000.0, 1));                           // Send new data to charging amp device
          send(msg_S_MULTIMETERc1.set(0));                                        // set the dis-charging amp device to zero
          lastmilli =  milli;
        else if (milli < 0)                                                       // Battery is discharging
          send(msg_S_MULTIMETERc.set(0));                                         // set the charging amp device to zero
          send(msg_S_MULTIMETERc1.set(abs(milli)/1000.0, 1));                     //  use abs(milli) to Send a positive number  to dis-charging amp device
          lastmilli =  milli;
          lastmilli =  milli;
    //--------------------------------------- Temperature readings start ------------------------------------------------------------
        //Serial.print("Temperature for Device: ");Serial.print(i);Serial.print(" is: ");
        //Serial.println(sensors.getTempCByIndex(i)); // Why "byIndex"?
      sleep(SLEEP_TIME);
      //Serial.print("estimating avg. quiscent voltage:");
      long acsCount = 0;
      for (int i=0; i<5000; i++)                                              // read 5000 samples to stabilise value
        delay(1);
      //Serial.print(map(acsCount, 0, 1023, 0, 5000));Serial.println(" mV");  // Print the avg in millivolts
      //Serial.print("acsCount:");Serial.println(acsCount);                   // Print the actual count value
     int count = 0;
     for (int i=0; i<5; i++)                                                  // read 5 analog count samples to stabilise value
       count += analogRead(PIN) - VQ;                                         // subtract the offset count VQ to improve accuracy
       delay(1);
      //Serial.print("raw count..."); Serial.println(count);
    //Serial.print("float amps..."); Serial.println(amps, 1);
  • I'm working again on this system but i'm having some troubles... The code has you caan see i have already adapted it to version 2.1.1 Now on the hardware i'm building i have this:
    • 1 solar panel 10w connected to the LM2596 that converts the 12v to 5.5v that goes to the LiPo Enhanced Charger Module, here i have the 3,7v bat connected and the arduinos connected to the other power out.
    My problem is that when i have the system online the values i'm getting are not right. For the battery voltage i get 5,5v when i believe i should be getting 3,7v or 4,1v maximum.
    The charge and load are always on 0,2A or 0,0A
    I have the acs712 connected to the negative side off the battery and the Voltage sensor connected to the negative and positive side off the battery.
    What i'm i doing rong here ????
    @mrc-core From your code it looks like you are using a 30A acs712 and you are still using the 25v sensor to measure the expected 4v. With only a 10w panel you might be better off with a 5A acs712 and also a voltage divider that maxes out at around 10v. This will give you a better resolution to work with right from the start.
    How are you powering the arduino? Perhaps you can do a drawing of how your project is wired together. Remember the arduino needs to have a stable 5v supply to have any chance of giving a good result.
  • Hi. sorry for my late replay....
    Here's the way i'm powering things up.
    I don't have a solar charge since last summer we had a big fire on my island and all my arduino and sensors that were outside were all damage from the fire and hot temperatures. So to fiz this problem i'm using the LM2596 to reduce the 12V from the solar panels to 5.5V so that the lipo charger can work. Above the 5v this charger will get damage.
    Some data from this charger:
    LED: Red = Charging, Green = Complete
    Input Voltage: 4.5 to 5.5V
    Battery Max Charge Voltage: 4.2V - charges a 1S Lithium Ion Polymer Battery
    This outputs a 4.2V on the load and batt connections.
    My arduino and sensors are connected to the load pins from the lipo charger as you can see on the picture.
    Thanks for your replay and help.
    @mrc-core The original circuit/sketch was designed for a 5v arduino and was measuring a 12v system . From your drawing it looks like you will be using a 3v arduino so at the very least you will need to change the voltage divider to give you a better resolution. As to the acs712 it is a 5v device so most likely will not even work on 3v so you may need to source some other device for current measurement. Again you would want a low current device if you are to have any chance of measuring the few milliamps you would be seeing. perhaps a google search for acs712 on 3v will produce a result.
  • @Boots33 I'm going to change the arduino mini for an arduino nano to have the 5V still have one in the house.
    Acs712 have already buy 2 off them just in case if i have to go back to arduino mini.
    I was thinking on booting all my outside arduinos from this solar panel i have 2 more off them that i can connect.
  • @Boots33 I have change to an arduino nano but still get some strange values. I'm going to make some changes over this project and see again what ill get.
    Thanks for all the help.
    @mrc-core Ok, let me know how you get on.
    I think solar powering the nodes is a great idea, I have several nodes and three raspberry pi's running on my house solar system at the moment.
  • I just finished setting up this sensor to monitor my solar panels. The voltage sensors is reporting correct, but i'm not sure if the current sensor is right or wired correctly.
    This is how it is currently wired.
    Is this going to give me both charge and discharge?
    @unfadingpyro I can't see your wiring diagram.
    Me neither. This is what it looks like to me:
  • How about now?
    Yes i can see your wiring now and no you are not likely to get any sort of reading with that circuit. You have the 712 wired in parallel with the charge wire, it needs to be in series instead. The load needs to be connected to the same side that the charge wire is on. So a quick re-draw of your circuit would look like this.
    Don't forget to add a fuse at the battery positive.
    The original drawing from earlier in this thread would also be ok
  • Okay. I will rewire it this weekend. Thanks!
  • Get the sensor rewired yesterday and i am now getting the correct readings! Thanks again for the help.
    @unfadingpyro Great to hear you got it all working. Always a good feeling when a project comes together 🙂
  • @Boots33 hi. Now, i'm working on this project for my final year project. I dont really used your overall project, i just used the concept which monitor the solar battery. I used your circuit diagram without using the transceiver and use my own code to run the project. In your opinion, is that make sense to you ?
    @nurul-amira Yes that should all work fine. That circuit has been running 24/7 for around 4 years now without any issues.
  • @Boots33 thank you for your time to reply me 😁.
  • 44
  • 90
