relay statue doesn't change
  • hi everyone
    i make a relay sensor this weekend but it doesn t work. The statue never change.
    This the log if someone can help me
    thinks
    send: 136-136-0-0 s=255,c=3,t=15,pt=2,l=2,sg=0,st=ok:0
    send: 136-136-0-0 s=255,c=0,t=18,pt=0,l=5,sg=0,st=ok:1.5.4
    send: 136-136-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-136 s=255,c=3,t=6,pt=0,l=1,sg=0:M
    repeater started, id=136, parent=0, distance=1
    send: 136-136-0-0 s=255,c=3,t=11,pt=0,l=5,sg=0,st=ok:Relay
    send: 136-136-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
    send: 136-136-0-0 s=1,c=0,t=3,pt=0,l=0,sg=0,st=ok:
    read: 0-0-136 s=1,c=1,t=2,pt=0,l=1,sg=0:0
    send: 136-136-0-0 s=1,c=1,t=2,pt=0,l=1,sg=0,st=ok:0
    Incoming change for sensor:1, New status: 0
    Did you use the standard code from the example?
  • @gohan yes standard code
  • @ludoarchi 1.5.4 version
  • nobody have idea ?
    Your only getting 0 sent for the relay so it certainly won't be changing status. Perhaps post the code you are using .
    @ludoarchi said in relay statue doesn't change:
    what version?
  • arduini 1.6.5 + Mysensors libraries 1.5.4
    and relay actuator code come from mysensors 1.5.4 exemple
  • @boots33 i only used code from mysensors exemple. I tried exemples V1 and V2 and i always have only 0 sent. I don't understand.
    1.5.4 is a few versions back now so it will help if you post the code you are using, even if it is the standard version. That will give us a starting point to work from.
    Also what controller are you using.
    @ludoarchi Is there a reason why you don't update arduino to 1.8.5 and mysensors to 2.2?
  • @gohan because i remenber that it used to work in that old version. But i have test yesterday with mysensors 2.2.0 et code V2 and it s ths same problem ... an idea ?
  • @boots33 that s the code V1
    // Example sketch showing how to control physical relays.
    // This example will remember relay state even after power failure.
      gw.sendSketchInfo("Relay", "1.0");
      // Fetch relay status
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, gw.loadState(sensor)?RELAY_ON:RELAY_OFF);
      if (message.type==V_LIGHT) {
         // Change relay state
         // Store state in eeprom
  • @boots33 that s the code V2
     * Version 1.0 - Henrik Ekblad
     * Example sketch showing how to control physical relays.
     * This example will remember relay state after power failure.
     * http://www.mysensors.org/build/relay
    #define MY_REPEATER_FEATURE
    void before()
    		present(sensor, S_BINARY);
    	if (message.type==V_STATUS) {
  • @boots33 i m using mysensor 2.2 with jeedom last version on rpi3 (serial gateway and node with 4.7uf condo).
    i also used my old rpi2 with Mysensors 1.5.4 for test
    are you checking the right relay pin? Pls post a v2 node log
  • @gohan 16 MCO:BGN:INIT REPEATER,CP=RNNRA---,VER=2.2.0
    26 MCO:BGN:BFR
    27 TSM:INIT
    28 TSF:WUR:MS=0
    35 TSM:INIT:TSP OK
    37 TSF:SID:OK,ID=136
    39 TSM:FPAR
    75 TSF:MSG:SEND,136-136-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2083 !TSM:FPAR:NO REPLY
    2085 TSM:FPAR
    2121 TSF:MSG:SEND,136-136-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2568 TSF:MSG:READ,0-0-136,s=255,c=3,t=8,pt=1,l=1,sg=0:0
    2573 TSF:MSG:FPAR OK,ID=0,D=1
    2842 TSF:MSG:READ,5-5-136,s=255,c=3,t=8,pt=1,l=1,sg=0:2
    2851 TSF:MSG:READ,45-45-136,s=255,c=3,t=8,pt=1,l=1,sg=0:1
    4129 TSM:FPAR:OK
    4130 TSM:ID
    4131 TSM:ID:OK
    4133 TSM:UPL
    4136 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=OK:1
    4148 TSF:MSG:READ,0-0-136,s=255,c=3,t=25,pt=1,l=1,sg=0:1
    4153 TSF:MSG:PONG RECV,HP=1
    4156 TSM:UPL:OK
    4157 TSM:READY:ID=136,PAR=0,DIS=1
    4162 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    4169 TSF:MSG:READ,0-0-136,s=255,c=3,t=15,pt=6,l=2,sg=0:0100
    4179 TSF:MSG:SEND,136-136-0-0,s=255,c=0,t=18,pt=0,l=5,sg=0,ft=0,st=OK:2.2.0
    4195 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    4220 TSF:MSG:READ,0-0-136,s=255,c=3,t=6,pt=0,l=1,sg=0:M
    4228 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=11,pt=0,l=5,sg=0,ft=0,st=OK:Relay
    4236 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=OK:1.0
    4244 TSF:MSG:SEND,136-136-0-0,s=1,c=0,t=3,pt=0,l=0,sg=0,ft=0,st=OK:
    4251 MCO:REG:REQ
    4254 TSF:MSG:SEND,136-136-0-0,s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=OK:2
    4261 TSF:MSG:READ,0-0-136,s=255,c=3,t=27,pt=1,l=1,sg=0:1
    4267 MCO:PIM:NODE REG=1
    4269 MCO:BGN:STP
    4271 MCO:BGN:INIT OK,TSP=1
    22720 TSF:MSG:READ,0-0-136,s=1,c=1,t=2,pt=0,l=1,sg=0:0
    22724 TSF:MSG:ACK REQ
    22737 TSF:MSG:SEND,136-136-0-0,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=OK:0
    31295 TSF:MSG:READ,0-0-136,s=1,c=1,t=2,pt=0,l=1,sg=0:0
    31299 TSF:MSG:ACK REQ
    31337 !TSF:MSG:SEND,136-136-0-0,s=1,c=1,t=2,pt=0,l=1,sg=0,ft=0,st=NACK:0
    The last you got was a NACK btw. Have you tried a different controller like domoticz or MyController? Also remember to check your logs on https://www.mysensors.org/build/parser if you meed help decoding it
  • @gohan i think the nack came when i unplleged the node but i will try again.
    there is no nack in the V1log
    i would like to try myscontroler but i m not able to start with it ... i ve configured the COM but nothing happened ... i don't find How To for it 😕
    i also try Double State Relay code V2 and it s the same think ... no statue change
    I am talking about MyController, not MySController
  • @gohan oups ! sorry no i don't have try another controller yet
    try it, it is quite simple to run
