Battery life for Motion Sensor
  • New to Arduino!
    I have built motion sensors following the example found on the site, based on Arduino Nano. I want to power them with a 9V battery.
    After a few days, the remaining voltage is 5.56V and the sensor does not detect any more the movements. Plugged back on my laptop, everything works well. Back to the battery, no detection.
    Is there something to do in the software, beside the sleeping time parameter to increase the life time of the battery. My last attempt is to push the sleeping time to 600000 ms. Waiting to see improvement
    Thank you for any help.
  • Hi!
    Sorry to say, but the Arduino Nano may not be the best choice for battery operation and maybe the Motion Detector also is not the most power economic application. I guess, to start with you have not done any modification to the Nano like removing the power LED? There goes a few milliamps the whole time.
    The PIR need rather high voltage to be stable and not generate random detects. I run mine on 8V. But the Nano needs only 5V so you burn off a bit of power in the voltage regulator chip, even if the sleep current of the Nano is very low. Of course, the more detections there are, the more power is used during the day.
    The Arduino ProMini is a better choice for battery operation. Please see Battery Powering in the left-hand column on the MySensors site. There are a few tricks there to really bring down power consumption. Then again the PIR needs more than 5V so you will have to use a power booster if you use the ProMini 8 MHz version that runs on 3.3 V.
    I think sleeping for 600000 mS will only marginally improve battery economy. I went through the same ordeal as you and I run my Motion Detector on a 9 V wall-wart.
    For sensors that really work well on battery I would suggest Light, Temperature and Humidity. I have a few of these built around ProMini 8 MHz and they typically run for 9 months or more on 2 x AA reporting every 2 minutes, but if you look at the link above, people achieve much better results. But I'm happy with 9 months.😀
    Best of luck and keep experimenting!
    You should also have a look at this thread on how to modify a commonly used motion detector to run off 3v3.
    https://forum.mysensors.org/topic/1088/battery-powered-pir
    And use 2xAA instead of 9v 👍
  • @bgunnarb Thank you for your quick answer! I have to investigate Arduino Mini (Uno was my first choice, apparently wrong). I really need to operate those sensors for a one year period without replacing batteries, and having a wired power (5V from AC 220 does not seem to be a viable solution).
    I'll keep working on it.👍
  • @hek Interesting but may be a bit too complicated for my knowledge level. Thanks👍
  • @sundberg84 Noted. Thanks👌
    There are also am 312 pir sensors that work at 3.3v, but the have some blind spots. Or just buy the xiaomi gateway and motion sensors if you don't want to modify things, since making something battery friendly means removing all those components that consume energy.
  • You can also use 3 AA batteries in a configuration like this:
    I have noted values for rechargeable batteries as these have a nominal value of 1.2 volts vs 1.5 volts for an alkaline battery. The 4.5v side would be to power the PIR and the 3V side to power the pro mini.
  • @gohan Thanks for the info, but I would like to build my own sensors. So i'll study the Pro Mini on 3.3V further.
  • @popsyann and get yourself a good current meter. It is almost imposible to make low power node without the current meter.
  • @rozpruwacz What do you mean by "good current meter"? Can you be a bit more specific? Have some knowledge of electricity and electronics domain but that does not ring a bell to me. Thanks in advance for your answer.
  • @dbemowsk Thank you for the info. I have made some progress and I have one sensor working on Pro Mini, with 2 x AA batteries. I am facing an issue with radio range. Apparently everything works well within close range but if I put the sensor some 8-10 meters from the gateway, I do not have accurate update of the sensor state (on-off). I though the NRF24 was able to cover such range.....
    Use a multimeter that can measure uA or build your own (there is a project on openhardware).
    If your nrf24 are clones it is normal, also the material of your house affects range.
  • @popsyann Poor RF issues can be a sign power issues (GW) or an indication of a low quality nrf24l01+
    I have 3 PIRs. One of them have been working for 1.5 years on 2xAA batteries (Arduino Pro Mini modified + nrf24l01+). Some nodes are very remote from the gateway.
  • @alexsh1 Hi, maybe you can help me with the following:
    I have built motion sensors with Arduino mini 3.3V and they have been working well, integrated in Home Assistant. However, the battery life is far from being satisfactory (I am looking for at least a year, and currently I reach a month, at most).
    While replacing batteries, I have discovered (because the sensor was not working well after battery replacement) that the sensor component works well (3V when motion detected, 0V when no motion) when not connected to the Arduino Mini. As soon as I connect the output to pin 3 (as defined in the sketch), I get 3V when there is motion, and 1.1V when no motion (which results in no status update). Do you have any clue on what could be the reason of this 1.1V once connected (instead of 0V with no motion)?
    Help appreciated.
  • @popsyann you have to provide more info :
    • did you modify arduino pro mini for batteries life?
    • what PIRs do you have?
    • post your sketch please
  • @popsyann
    In your sketch, please check that you have defined the input pin for the PIR pin as pinMode (PIR_PIN, INPUT) and not pinMode (PIR_PIN, INPUT_PULLUP). If you have activated the internal pullup in the arduino this will prevent the PIR from pulling the input low when there is no motion.
  • @alexsh1
    Hi
    1. I did not modify the Arduino Pro Mini for Batteries life. What is there that I should do? Did not read anything about it.
    2. I use either the standard PIR Motion sensor (with two potentiometers on board the module to adjust sensitivity and timer) (Seems to be HC-SR501), or the mini version of this sensor .
    3. The code I use is the one given in the MySensors
     * Version 1.0 - Henrik Ekblad
    // Enable debug prints
    // #define MY_DEBUG
    //#define MY_RADIO_NRF5_ESB
    //#define MY_RADIO_RFM95
    uint32_t SLEEP_TIME = 120000; // Sleep time between reports (in milliseconds)
    // Initialize motion message
    	present(CHILD_ID, S_MOTION);
    	// Read digital motion value
    	bool tripped = digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
    	Serial.println(tripped);
  • @popsyann
    1. https://www.mysensors.org/build/battery
    2. OK
    3. This is a standard sketch. Cannot see anything wrong.
  • @alexsh1 Indeed, I saw the batteries life page but I did not want to cut into my Pro Minis (and I believe that the LED provides a good info as to the sensor is well powered).
    Even if I make this modification, that does not explain the 3V to 1V instead of 3V to 0V phenomenon. Does it?
  • @popsyann I de-soldered power LEDs and power regulators. You do not need them for battery powered nodes and this is reversible. Otherwise you wont get low uA.
    This is about power.
    Talking about voltage - did you measure it? How do you know if goes to 1V?
    Did you double-triple check all wires and everything is correct?
    FYG - HR-SR501 has to be modified as well for 3.3V (remove regulator)
    http://www.instructables.com/id/Convert-a-5v-PIR-Motion-Sensor-to-33v-for-ESP8266/
  • @alexsh1 Noted for the de-soldering info. I get it.
    For voltage measurements, yes I did measure the voltage between the ground and the output pin of the motion sensor: when the pin is not connected to Arduino, I get 3V when motion is detected and 0V when no motion.
    Then I connect the output pin of the PIR to the Arduino (pin 3) and I measure on Arduino pin 3: I get 3V when motion is detected and 1.2V when no motion.
    As for the modification of the PIR: noted. But I mainly use the mini PIR, where such modification cannot be applied (as the circuitry is very different and very simple).
    For the cabling: when I load on the Arduino the Serial Gateway sketch, everything works well, the Gateway starts properly, meaning the radio is well connected.
    When I load the motion sensor sketch, it start properly, finding the right "parent" and immediately after this, there is a flow of info going out of the Arduino+sensor, sending 0s or 1s, constantly (like if there was an issue with the interrupt process).
    And what I do not understand is that this (these) sensor(s) has(have) been working well for a while.
  • @popsyann said in Battery life for Motion Sensor:
    Please search for sleep() function - it has changed the way it works at some stage in MySensors 2.*
    https://forum.mysensors.org/topic/5807/interrupt-and-sleep/26
    https://forum.mysensors.org/topic/5552/pin-change-interrupt-not-firing-with-mysensors/28
    Another reason could you that your PIR is not settling properly - this is why it sends out 1s and 0s to the GW. Try to insert sleep(20000); into void setup() at the end to settle the PIR
