[SOLVED] call of overloaded 'sleep(int, int)' is ambiguous
    I have an older sketch which I modified and want to upload again now to my Arduino. I am using Lib 2.2.0 now, but I am getting this error at this line:
    sleep(BUTTON_PIN - 2, CHANGE);
    The code worked very well in the past, so whats wrong here now?
    edit: I´m using Arduino IDE 1.8.5
    edit2: I can compile using lib 2.0.0. So there must have been a change in the meantime.
    I think you need to add ,0 in your parameters (that's 0 milliseconds = infinite delay)
  • Hi, thanks for your help, that´s the solution!!
  • 24
28
