Howto trigger a doorbell?
  • Hello guys,
    a want to trigger and notify my phone if the door rings. I already open my intercom and found a 12v ac bell. Now i think its a option to use a diode to transform 12v ac to dc. After that i use a 12v to 3.3v stepdown board and connect this 3.3v line with the arduion interrupt pin.
    Can this work the way I imagine? I am not quite as fit for electrical engineering. Or does someone know a finished solution in the form of a board to realize this?
    The intercom is a SSS Siedle ht 611-01 w
    Thanks 🙂
  • @harrdy You don't have to use a stepdown board, you can just use a resistor divider to lower the voltage.
    With one diode you will still not have a DC signal yet, better to use two diodes or a bridge rectifier. After the rectifier place a capacitor and the resistor divider.
    Felix from https://lowpowerlab.com has an interesting blog post on the subject:
    https://lowpowerlab.com/2015/04/13/doorbell-moteino/
    He uses a zero-crossing detector optocoupler to transform to a 5V DC pulsating signal which he then inverts using a transistor and smooths out to a stable 5V DC using a capacitor.
    @harrdy - as mentioned above some good tips.
    Myself I just used a single diode to rectify the AC and a capacitor to make it smoother. After that Opto-isolator chip with 5v from the Arduino to a inputpin.
  • Glass reed switch and Fibaro Door/window Sensor (before I stumble on to Mysensors) if you have an electromagnetic door bell.
    Battery a bit expensive last more then a year with DS18B20 temperature sensor connected.
  • 87
  • 7
