queuing and sending messages
  • I have several battery powered nodes. I want to be able to issue commands (reboot, firmware update, etc) and when they wake up to transmit via motion or timed sending of data. they receive and execute whatever command i have sent. so far i can't get this to work. if i send a reboot command from the controller during the OTA wait period. the node receives the request and reboots.. if the OTA period is over, then the node never follows the command. even after waking up. it still never executes said command.
    so it seems the gateway is not queuing up the command or it's not sending when the node wakes up.
    what is the correct approach to implement this and how can i troubleshoot if the GW is receiving, queuing and sending commands for a sleeping node?
    running lib 2.2.0
    and the gw is 2.2.0 on a RPI3
  • @mvader said in queuing and sending messages:
    can anyone point me in the right direction?
    @mvader MySensors currently does not support queuing commands.
25
