  3. My Outdoor Motion Humidity Sensor
12 Posts 5 Posters 9.9k Views 3 Watching
    Ok, finally has some time to put together my first outdoor sensor.
    It will be used to increase outdoor-light level when someone moves around our house. Also reports temperature and humidity level. Got 24V where it will be placed.
    Final test:
    And the sketch:
    https://codebender.cc/sketch:88192
    • funky81F
      funky81F
      funky81
      which power supply method are you using?
      Battery, or AC voltage? looks like interesting
        wrote on last edited by hek
        I have added a AC->AC converter to reduce the 24VAC (i have for led-lightning) to something 12V-ish which is feed to the Arduino.
        • funky81F
          funky81F
          funky81
          Well, this looks good. but i still confused.
          arduino only support VDC right? not VAC. mind to explain how you supply arduino with VAC?
          thanks @hek
            @funky81
            No wonder you are confused.
            Of course I meant DC->DC converter and 24VDC.
            funky81F 1 Reply Last reply
            • bjornhallbergB
              bjornhallbergB
              bjornhallberg
              I have a pretty good experience using the motion sensor outdoors. Been running mine since October on 2xAA batteries (no regulator) and the damn thing is still alive despite cold weather and being triggered 4-5 times a day (not counting the false positives). What is sort of tricky is avoiding is the false positives, e.g. magpies exploring the porch (I have the sensor at about knee level), sunlight rising and falling quickly on a day with spotty clouds and fireworks at New Years Eve. Bottom line, avoid incoming direct light at all cost and put it in a shaded place. Now it is possible that one might filter out those false positives using the sensitivity setting, I don't really know. I also suspect that having dry leaves and stuff get right up close and blow by the sensor is a source of some false positives.
              AnticimexA 1 Reply Last reply
                AnticimexA
                AnticimexA
                Anticimex
                @bjornhallberg If the reading is analog, you perhaps could "weight" the sample. A relatively big change rules out sunlight cycles and perhaps even clouds.
                EDIT: See now that the motion sensor is digital. So that would not be possible. But perhaps if combined with a light sensor.
                  @bjornhallberg
                  I wlll put it on the eaves (takfot) without any direct sunlight.
                  RJ_MakeR 1 Reply Last reply
                    @bjornhallberg
                    RJ_MakeR
                    RJ_MakeR
                    RJ_Make
                    @hek I noticed you are sleeping the sensor? Is the 24v not constant?
                    RJ_Make
                    hekH 1 Reply Last reply
                    • RJ_MakeR RJ_Make
                      @ServiceXp
                      Just an old habit...
                        @ServiceXp
                        RJ_MakeR
                        RJ_MakeR
                        RJ_Make
                        @hek Ah ok. I thought you might be up to something. :-)
                        RJ_Make
                          @funky81
                          funky81F
                          funky81F
                          funky81
                          @hek Thanks for the clarification :+1:
