MySensors: trying to add Things in WebThings Gateway
  • Ok, here we go. I've had some basic mysensors working with Domoticx for over a year and thought I would give this Gateway a try. I have it installed and everything appears fine (sensor work in Domoticx) but when I try to add 'Things' in the gateway it says that none are found and I get this stuff in the log. (I do have the addin for mysensors added in)
    2019-06-15 00:00:01.174 INFO : mysensors: initialising adapter from class
    2019-06-15 00:00:01.177 INFO : mysensors: IpcClient: Connected to server, registering...
    2019-06-15 00:00:01.180 INFO : mysensors: IpcClient: Received manager message: b'{"messageType":"registerPluginReply","data":{"pluginId":"mysensors-adapter","ipcBaseAddr":"gateway.plugin.mysensors-adapter"}}'
    2019-06-15 00:00:01.182 INFO : mysensors: IpcClient: Registered with PluginServer
    2019-06-15 00:00:01.183 INFO : mysensors: AddonManagerProxy: add_adapter: mysensors-adapter
    2019-06-15 00:00:54.503 ERROR : mysensors: Unexpected source: state=5 source=1 action=5 (src/transports/utils/streamhdr.c:306)
    2019-06-15 00:00:54.509 INFO : Plugin: mysensors-adapter died, code = null restarting...
    2019-06-15 00:00:56.808 INFO : mysensors: initialising adapter from class
    2019-06-15 00:00:56.809 INFO : mysensors: IpcClient: Connected to server, registering...
    2019-06-15 00:00:56.811 INFO : mysensors: IpcClient: Received manager message: b'{"messageType":"registerPluginReply","data":{"pluginId":"mysensors-adapter","ipcBaseAddr":"gateway.plugin.mysensors-adapter"}}'
    2019-06-15 00:00:56.813 INFO : mysensors: IpcClient: Registered with PluginServer
    2019-06-15 00:00:56.815 INFO : mysensors: AddonManagerProxy: add_adapter: mysensors-adapter
    2019-06-15 00:02:13.546 ERROR : mysensors: Unexpected source: state=5 source=1 action=5 (src/transports/utils/streamhdr.c:306)
    2019-06-15 00:02:13.552 INFO : Plugin: mysensors-adapter died, code = null restarting...
    2019-06-15 00:02:15.847 INFO : mysensors: initialising adapter from class
    Can someone help me with this error? I don't know what to even try.
  • Plugin Developer
    It seems the add-on is crashing.
    Some questions:
    • Have you rebooted the device once?
    • What version of the WebThings Gateway are you using?
    • On what operating System are you running it?
    • Under settings, what type of MySensors Gateway have you selected?
    • Under settings, have you checked if the serial port or IP address if ok?
    • Have you enabled the Debugging option? If not, can you enable it and see if you get some additional error messages?
    The error mysensors: Unexpected source: state=5 source=1 action=5 (src/transports/utils/streamhdr.c:306) looks a little like what happened if I had two of the same add-ons running at the same time.
  • I have tried rebooting. It looks like it's version 0.0.7 (the addon that's included with WebThings). Rasp pi with the latest download gateway-0.8.1.img. I'm using Ethernet gateway, the usb device name is blank. I'm using a IP ADDR: 192.168.98:5003 (which is what is working with Domoticz). Question: I've tried it with and without the port, should I have the port in there or not? FYI: Just for fun I added the weather plugin using 'Dark Sky' and it is working so my WebThings Gateway works for that 'thing'. I have turned on debugging and do have some more stuff in the log (I'm not totally sure when to start the cut/paste of the log):
    2019-06-15 21:13:19.062 INFO : mysensors: initialising adapter from class
    2019-06-15 21:13:19.063 INFO : mysensors: IpcClient: Connected to server, registering...
    2019-06-15 21:13:19.067 INFO : mysensors: IpcClient: Received manager message: b'{"messageType":"registerPluginReply","data":{"pluginId":"mysensors-adapter","ipcBaseAddr":"gateway.plugin.mysensors-adapter"}}'
    2019-06-15 21:13:19.070 INFO : mysensors: IpcClient: Registered with PluginServer
    2019-06-15 21:13:19.071 INFO : mysensors: AddonManagerProxy: add_adapter: mysensors-adapter
    2019-06-15 21:14:04.011 INFO : Pairing timeout
    2019-06-15 21:14:04.017 ERROR : Thing was not added
    2019-06-15 21:14:04.019 ERROR : addNewThing cancelled
    2019-06-15 21:14:04.024 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
    2019-06-15 21:14:04.027 INFO : weather: Adapter: WeatherAdapter id weather-adapter pairing cancelled
    2019-06-15 21:14:04.029 INFO : systeminfo: Adapter: SysteminfoAdapter id SysteminfoAdapter pairing cancelled
    2019-06-15 21:17:52.418 INFO : Unloading MySensorsAdapter
    2019-06-15 21:17:52.422 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"unloadAdapter","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
    2019-06-15 21:17:52.426 INFO : mysensors: Shutting down MySensors adapter
    2019-06-15 21:17:52.428 INFO : mysensors: MySensors adapter was unable to cleanly close PyMySensors. This is not a problem.
    2019-06-15 21:17:52.429 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"unloadPlugin","data":{"pluginId":"mysensors-adapter"}}'
    2019-06-15 21:17:55.944 INFO : Loading add-on: mysensors-adapter
    2019-06-15 21:17:58.235 INFO : mysensors: initialising adapter from class
    2019-06-15 21:17:58.237 INFO : mysensors: IpcClient: Connected to server, registering...
    2019-06-15 21:17:58.240 INFO : mysensors: IpcClient: Received manager message: b'{"messageType":"registerPluginReply","data":{"pluginId":"mysensors-adapter","ipcBaseAddr":"gateway.plugin.mysensors-adapter"}}'
    2019-06-15 21:17:58.243 INFO : mysensors: IpcClient: Registered with PluginServer
    2019-06-15 21:17:58.245 INFO : mysensors: AddonManagerProxy: add_adapter: mysensors-adapter
    2019-06-15 21:18:11.500 INFO : About to call startPairing on SysteminfoAdapter
    2019-06-15 21:18:11.502 INFO : About to call startPairing on WeatherAdapter
    2019-06-15 21:18:11.503 INFO : About to call startPairing on MySensorsAdapter
    2019-06-15 21:18:11.511 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"startPairing","data":{"timeout":60,"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
    2019-06-15 21:18:11.513 INFO : systeminfo: Adapter: SysteminfoAdapter id SysteminfoAdapter pairing started
    2019-06-15 21:18:11.577 INFO : Opened a new things socket
    2019-06-15 21:19:11.505 INFO : Pairing timeout
    2019-06-15 21:19:11.509 ERROR : Thing was not added
    2019-06-15 21:19:11.510 ERROR : addNewThing cancelled
    2019-06-15 21:19:11.514 INFO : weather: Adapter: WeatherAdapter id weather-adapter pairing cancelled
    2019-06-15 21:19:11.516 INFO : systeminfo: Adapter: SysteminfoAdapter id SysteminfoAdapter pairing cancelled
    2019-06-15 21:19:11.518 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
  • Here is a log of another 'thing' Add with the port number on the IP address: (I also disabled the weather and system addon's to try to keep the log cleaner.)
    2019-06-15 21:31:41.231 INFO : mysensors: MySensors adapter was unable to cleanly close PyMySensors. This is not a problem.
    2019-06-15 21:31:41.233 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"unloadPlugin","data":{"pluginId":"mysensors-adapter"}}'
    2019-06-15 21:31:43.097 ERROR : mysensors: Exception in thread Thread-2:
    2019-06-15 21:31:43.099 ERROR : mysensors: Traceback (most recent call last):
    2019-06-15 21:31:43.101 ERROR : mysensors: File "/usr/lib/python3.5/threading.py", line 914, in _bootstrap_inner
    2019-06-15 21:31:43.103 ERROR : mysensors: self.run()
    2019-06-15 21:31:43.105 ERROR : mysensors: File "/usr/lib/python3.5/threading.py", line 862, in run
    2019-06-15 21:31:43.107 ERROR : mysensors: self._target(*self._args, **self._kwargs)
    2019-06-15 21:31:43.108 ERROR : mysensors: File "/home/pi/.mozilla-iot/addons/mysensors-adapter/pkg/mysensors_adapter.py", line 381, in start_pairing
    2019-06-15 21:31:43.110 ERROR : mysensors: if not self.t.is_alive():
    2019-06-15 21:31:43.112 ERROR : mysensors: AttributeError: 'MySensorsAdapter' object has no attribute 't'
    2019-06-15 21:31:43.114 ERROR : mysensors:
    2019-06-15 21:31:43.115 ERROR : mysensors: Exception in thread Thread-4:
    2019-06-15 21:31:43.117 ERROR : mysensors: Traceback (most recent call last):
    2019-06-15 21:31:43.119 ERROR : mysensors: File "/usr/lib/python3.5/threading.py", line 914, in _bootstrap_inner
    2019-06-15 21:31:43.121 ERROR : mysensors: self.run()
    2019-06-15 21:31:43.122 ERROR : mysensors: File "/usr/lib/python3.5/threading.py", line 862, in run
    2019-06-15 21:31:43.129 ERROR : mysensors: self._target(*self._args, **self._kwargs)
    2019-06-15 21:31:43.131 ERROR : mysensors: File "/home/pi/.mozilla-iot/addons/mysensors-adapter/pkg/mysensors_adapter.py", line 381, in start_pairing
    2019-06-15 21:31:43.132 ERROR : mysensors: if not self.t.is_alive():
    2019-06-15 21:31:43.134 ERROR : mysensors: AttributeError: 'MySensorsAdapter' object has no attribute 't'
    2019-06-15 21:31:43.136 ERROR : mysensors:
    2019-06-15 21:31:44.747 INFO : Loading add-on: mysensors-adapter
    2019-06-15 21:31:47.080 INFO : mysensors: initialising adapter from class
    2019-06-15 21:31:47.082 INFO : mysensors: IpcClient: Connected to server, registering...
    2019-06-15 21:31:47.085 INFO : mysensors: IpcClient: Received manager message: b'{"messageType":"registerPluginReply","data":{"pluginId":"mysensors-adapter","ipcBaseAddr":"gateway.plugin.mysensors-adapter"}}'
    2019-06-15 21:31:47.088 INFO : mysensors: IpcClient: Registered with PluginServer
    2019-06-15 21:31:47.090 INFO : mysensors: AddonManagerProxy: add_adapter: mysensors-adapter
    2019-06-15 21:31:53.398 INFO : About to call startPairing on MySensorsAdapter
    2019-06-15 21:31:53.411 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"startPairing","data":{"timeout":60,"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
    2019-06-15 21:31:53.515 INFO : Opened a new things socket
    2019-06-15 21:32:53.402 INFO : Pairing timeout
    2019-06-15 21:32:53.405 ERROR : Thing was not added
    2019-06-15 21:32:53.407 ERROR : addNewThing cancelled
    2019-06-15 21:32:53.410 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
  • Here is a log where I rebooted, went directly to 'Things' and '+' to add/discover new things: (One thing is strange is that I don't seem to be getting that 'original' error where you said it was like two instances where running so maybe that was the case for that error.)
    2019-06-15 21:41:16.559 INFO : About to call startPairing on MySensorsAdapter
    2019-06-15 21:41:16.569 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"startPairing","data":{"timeout":60,"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
    2019-06-15 21:41:16.876 INFO : Opened a new things socket
    2019-06-15 21:42:16.565 INFO : Pairing timeout
    2019-06-15 21:42:16.570 ERROR : Thing was not added
    2019-06-15 21:42:16.572 ERROR : addNewThing cancelled
    2019-06-15 21:42:16.575 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
  • I was just thinking, my MySensors gateway was built using version 2.2 mysensors code, I am sort of wondering if that is my problem. This addon was probably never tested against older MySensor version gateway's I'm assuming? At this point I'm thinking I should build a new MS gateway and try that. The WebThings Gateway seems to be working and I know my MySensors sensors are working fine in Domoticz so that really just leaves the MySensors gateway at Version 2.2 as a possible issue. This addon seems to be working for others so I guess that's the most logical thing for me to try. I really would like to get the WebThings gateway working because it really fits what I need for the stuff I have around here!
  • Plugin Developer
    The add-on was never tested with the ethernet gateway option. It should work theoretically.. so it might just be that. I will test it when I get a chance.
    You could try running the serial gateway version. If that works, then we know what the issue is.
  • Hardware Contributor
    @alowhum said in MySensors: trying to add Things in WebThings Gateway:
    It's not the problem I'm using an ethernet gateway on an ESP8266 and it's running great now.
    @rmalbers said in MySensors: trying to add Things in WebThings Gateway:
    Are you trying to run both Domoticz and Things Gateway in parallel connecting to the same MySensors gateway ?
  • Plugin Developer
    @nca78 Thanks, that saves me some test work 🙂
    @rmalbers I believe you cannot have two controllers ingest the data at the same time. One of them will 'win', or both will get some of the messages.
    A possible future feature could be the re-broadcast the incoming messages on another port (e.g. 5004), so that Domoticz could ingest those. Then you could have two controllers both getting the same MySensors data.
  • Ok, I think I tried it with domoticz shutdown but I'll try that again. Thanks to the other reply that they have this working, that gives my hope! Na78: What version of mysensor gateway code are you running? Mine is at V2.2 and I'm wondering if that might be my problem. Thanks for the help on this BTW!
  • Ok, with Domoticz shutdown I get the same stuff in the log. I'm going to see if I can tell more what's going on with wireshark. I'm thinking it has to be something stupid that I have going on, I know my MySensors gateway is good because it's working with Domoticz, the Mozilla WebThings gateway is working because it works with Dark sky weather, so I would think it's something going on with the comm between the two gateways.
  • Ok, I built a new serial USB MySensor gateway. (The old GW is unplugged and Domoticz is shutdown.) The new MS gateway is working because under the IDE I can turn on the com serial port debug and see it going, communicating with the sensors.) I move the USB serial gw to the rasp pi WebThings gateway and set the addon to: /dev/ttyUSB0 and to USB serial gateway. I get the same messages as above. I'm also seeing this in a couple of log files on the WebThings gateway: cat: /tmp/gateway.addonManager: No such device or address
    cat: /tmp/gateway.plugin.mysensors-adapter: No such device or address
    So it sure sounds like in this case it's not seeing or able to open that USB device. That is the device name that appears when I plug the usb serial gateway USB cable into the WebThings gateway rasp pi.
  • Plugin Developer
    @rmalbers Great work, that narrows things down a lot.
    It seems the add-on was crashing. Based on your reporting I dove into the issue and I think I may have found a bug in how it loaded settings.
    I'm uploading version 0.0.8 now. It should take a day or two before the Mozilla teams accepts the new version.
  • Wow, that sounds great! At first I was thinking it might be a permissions issue with opening the USB port but I opened permissions up and found that didn't seem to be the issue.
  • Plugin Developer
    @rmalbers It's been accepted. You should already automatically have the new version.
  • Ok, when I went into the WT GW the first time the addon was at V0.0.7 but there was an new 'Update' tab that I hit and the new addon version installed. With the USB gateway I get this (I think I started the cut/paste at the right spot):
    2019-06-19 15:49:54.172 INFO : Loading add-on: mysensors-adapter
    2019-06-19 15:49:56.494 INFO : mysensors: initialising adapter from class
    2019-06-19 15:49:56.496 INFO : mysensors: IpcClient: Connected to server, registering...
    2019-06-19 15:49:56.500 INFO : mysensors: IpcClient: Received manager message: b'{"messageType":"registerPluginReply","data":{"pluginId":"mysensors-adapter","ipcBaseAddr":"gateway.plugin.mysensors-adapter"}}'
    2019-06-19 15:49:56.503 INFO : mysensors: IpcClient: Registered with PluginServer
    2019-06-19 15:49:56.505 INFO : mysensors: AddonManagerProxy: add_adapter: mysensors-adapter
    2019-06-19 15:50:13.088 INFO : About to call startPairing on MySensorsAdapter
    2019-06-19 15:50:13.096 INFO : mysensors: -Connection status was present in the config data.
    2019-06-19 15:50:13.098 INFO : mysensors: -Gateway choice: USB Serial gateway
    2019-06-19 15:50:13.099 INFO : mysensors: Error extracting settings from config object: local variable 'ip_address' referenced before assignment
    2019-06-19 15:50:13.101 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"startPairing","data":{"timeout":60,"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
    2019-06-19 15:50:18.322 INFO : Opened a new things socket
    2019-06-19 15:51:13.092 INFO : Pairing timeout
    2019-06-19 15:51:13.095 ERROR : Thing was not added
    2019-06-19 15:51:13.113 ERROR : addNewThing cancelled
    2019-06-19 15:51:13.118 INFO : mysensors: PAIRING INITIATED
    2019-06-19 15:51:13.120 INFO : mysensors: Error re-requesting node ID's from devices in the MySensors network:'MySensorsAdapter' object has no attribute 't'
    2019-06-19 15:51:13.121 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
  • This log is from an attempt (with the new addon) using 'Ethernet' GW and the IP address of the GW that I've been using with Domoticz for the last year or so, (it's at mysensor v2.2) This looks like it was communicating with the gw and thus the sensors but still didn't work. This could be because I am at V2.2 of mysensors(?).:
    2019-06-19 15:33:17.874 INFO : Loading add-on: mysensors-adapter
    2019-06-19 15:33:20.227 INFO : mysensors: initialising adapter from class
    2019-06-19 15:33:20.229 INFO : mysensors: IpcClient: Connected to server, registering...
    2019-06-19 15:33:20.233 INFO : mysensors: IpcClient: Received manager message: b'{"messageType":"registerPluginReply","data":{"pluginId":"mysensors-adapter","ipcBaseAddr":"gateway.plugin.mysensors-adapter"}}'
    2019-06-19 15:33:20.236 INFO : mysensors: IpcClient: Registered with PluginServer
    2019-06-19 15:33:20.238 INFO : mysensors: AddonManagerProxy: add_adapter: mysensors-adapter
    2019-06-19 15:33:20.314 ERROR : mysensors: DEBUG:mysensors.persistence:Loading sensors from persistence file /home/pi/.mozilla-iot/config/mysensors-adapter-persistence.json
    2019-06-19 15:33:20.319 ERROR : mysensors: DEBUG:mysensors.persistence:Saving sensors to persistence file /home/pi/.mozilla-iot/config/mysensors-adapter-persistence.json
    2019-06-19 15:33:20.330 ERROR : mysensors: INFO:mysensors.gateway_tcp:Trying to connect to ('192.168.1.98', 5003)
    2019-06-19 15:33:20.393 ERROR : mysensors: INFO:mysensors:Connected to <_SelectorSocketTransport fd=14 read=idle write=<idle, bufsize=0>>
    2019-06-19 15:33:20.425 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;3;0;14;Gateway startup complete.
    2019-06-19 15:33:20.434 ERROR : mysensors: INFO:mysensors.handler:n:0 c:255 t:3 s:14 p:Gateway startup complete.
    2019-06-19 15:33:20.436 ERROR : mysensors: DEBUG:mysensors:Sending 255;255;3;0;20;
    2019-06-19 15:33:20.438 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;0;0;18;2.2.0
    2019-06-19 15:33:20.442 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;26;0
    2019-06-19 15:33:27.927 ERROR : mysensors: DEBUG:mysensors:Receiving 1;0;1;0;0;22.6
    2019-06-19 15:33:27.932 ERROR : mysensors: WARNING:mysensors:Node 1 is unknown
    2019-06-19 15:33:27.934 ERROR : mysensors: INFO:mysensors:Requesting new presentation for node 1
    2019-06-19 15:33:27.935 ERROR : mysensors: DEBUG:mysensors:Sending 1;255;3;0;19;
    2019-06-19 15:33:29.635 INFO : About to call startPairing on MySensorsAdapter
    2019-06-19 15:33:29.642 INFO : mysensors: -Connection status was present in the config data.
    2019-06-19 15:33:29.644 INFO : mysensors: -Gateway choice: Ethernet gateway
    2019-06-19 15:33:29.646 INFO : mysensors: Selected IP address and port: 192.168.1.98
    2019-06-19 15:33:29.648 INFO : mysensors: >> incoming message > internal > id: 0; child: 255; subtype: 14; payload: Gateway startup complete.
    2019-06-19 15:33:29.649 INFO : mysensors: >> incoming message > presentation > id: 0; child: 255; subtype: 18; payload: 2.2.0
    2019-06-19 15:33:29.651 INFO : mysensors: RECREATING DEVICES FROM PERSISTENCE
    2019-06-19 15:33:29.652 INFO : mysensors: Re-requesting presentation of all nodes on the network
    2019-06-19 15:33:29.654 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"startPairing","data":{"timeout":60,"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
    2019-06-19 15:33:29.656 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;26;0
    2019-06-19 15:33:29.695 INFO : Opened a new things socket
    2019-06-19 15:33:30.333 ERROR : mysensors: DEBUG:mysensors.persistence:Saving sensors to persistence file /home/pi/.mozilla-iot/config/mysensors-adapter-persistence.json
    2019-06-19 15:33:30.495 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;2;
    2019-06-19 15:33:30.558 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;3;0;2;2.2.0
    2019-06-19 15:33:34.611 ERROR : mysensors: DEBUG:mysensors:Receiving 2;0;1;0;0;23.2
    2019-06-19 15:33:34.614 ERROR : mysensors: WARNING:mysensors:Node 2 is unknown
    2019-06-19 15:33:34.617 ERROR : mysensors: INFO:mysensors:Requesting new presentation for node 2
    2019-06-19 15:33:34.618 ERROR : mysensors: DEBUG:mysensors:Sending 2;255;3;0;19;
    2019-06-19 15:33:40.597 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;2;
    2019-06-19 15:33:40.689 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;3;0;2;2.2.0
    2019-06-19 15:33:50.699 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;2;
    2019-06-19 15:33:50.820 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;3;0;2;2.2.0
    2019-06-19 15:34:00.595 ERROR : mysensors: DEBUG:mysensors:Receiving 1;0;1;0;0;22.6
    2019-06-19 15:34:00.599 ERROR : mysensors: WARNING:mysensors:Node 1 is unknown
    2019-06-19 15:34:00.601 ERROR : mysensors: INFO:mysensors:Requesting new presentation for node 1
    2019-06-19 15:34:00.602 ERROR : mysensors: DEBUG:mysensors:Sending 1;255;3;0;19;
    2019-06-19 15:34:00.801 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;2;
    2019-06-19 15:34:00.875 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;3;0;2;2.2.0
    2019-06-19 15:34:09.359 ERROR : mysensors: DEBUG:mysensors:Receiving 2;0;1;0;0;23.2
    2019-06-19 15:34:09.362 ERROR : mysensors: WARNING:mysensors:Node 2 is unknown
    2019-06-19 15:34:09.365 ERROR : mysensors: INFO:mysensors:Requesting new presentation for node 2
    2019-06-19 15:34:09.366 ERROR : mysensors: DEBUG:mysensors:Sending 2;255;3;0;19;
    2019-06-19 15:34:10.903 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;2;
    2019-06-19 15:34:10.980 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;3;0;2;2.2.0
    2019-06-19 15:34:21.005 ERROR : mysensors: DEBUG:mysensors:Sending 0;255;3;0;2;
    2019-06-19 15:34:21.112 ERROR : mysensors: DEBUG:mysensors:Receiving 0;255;3;0;2;2.2.0
    2019-06-19 15:34:29.646 INFO : Pairing timeout
    2019-06-19 15:34:29.651 ERROR : Thing was not added
    2019-06-19 15:34:29.653 ERROR : addNewThing cancelled
  • FWIW: I was just thinking I should mention, after the 'Update' of the addon the first time I tired it I got the same/similar messages as I had in my OP. I rebooted at that point and those messages went away so I'm thinking that after addon install or update a reboot is probably a good idea.
  • I noticed something with the Ethernet GW: On the addon configure page under the 'IP address' the text has an IP address example that includes the port. When I include the port I get this data in the log file: 2019-06-19 17:47:34.750 ERROR : mysensors: INFO:mysensors.gateway_tcp:Trying to connect to ('192.168.1.98:5003', 5003)
    2019-06-19 17:47:34.758 ERROR : mysensors: ERROR:mysensors.gateway_tcp:Failed to connect to socket at ('192.168.1.98:5003', 5003)
    and it doesn't seem to connect.
    When I leave off the port number I get this in the log file:
    2019-06-19 17:49:44.095 ERROR : mysensors: INFO:mysensors.gateway_tcp:Trying to connect to ('192.168.1.98', 5003)
    2019-06-19 17:49:44.111 ERROR : mysensors: INFO:mysensors:Connected to <_SelectorSocketTransport fd=14 read=idle write=<idle, bufsize=0>>
    and it seems to connect. If I'm interpreting this correctly you have to leave the port number off the IP string for it to work properly, not sure which way it really should be, just pointing this out in case it hadn't been noticed.
  • Plugin Developer
    Thank you for the logs.
    Perhaps this is a point where it crashes and reboots the add-on:
    I also noticed that it keeps re-requesting the presentation of your nodes:
    This could mean:
    • You have created a node that somehow has the same node-ID as an earlier but different node. Although in theory the add-on handles this case now.
    • Some data is missing that is required to actually create the device. This could be the name.
    Can you share the Arduino Code? Could it be that your presentation function does not send names? Your presentation should look something like this:
    sendSketchInfo(F("Sensor name"), F("1.1"));
    present(CHILD_ID, S_BINARY, F("Button name"));
    Here's another example sketch:
    https://forum.mysensors.org/topic/10342/mozilla-webthings-mysensors-add-on-adapter/14
    // By the way, I don't think using v2.2 should matter. Internally the PyMySensors library actually uses 2.2.
  • I need to keep better track of what software is running on a given cpu/sensor, sorry about that but I didn't think of it at the time! I 'think' this is what is running on the office sensor. I should probably build a new sensor using this code and make sure it works the same, (log files match what I've been giving you):
    //#define MY_DEBUG
    #include <MyConfig.h>
    #include <OneWire.h>
    int numSensors = 0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0, V_TEMP);
    void before()
    sensors.begin();
    void presentation() {
    sendSketchInfo("Temperature Sensor", "1.1");
    for (int i = 0; i<numSensors && i<MAX_ATTACHED_DS18B20; i++) {
    	present(i, S_TEMP);
    sleep(conversionTime);
    	float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric ? sensors.getTempCByIndex(i) : sensors.getTempFByIndex(i)) * 10.)) / 10.;
    #if COMPARE_TEMP == 1
    #else
    		send(msg.setSensor(i).set(temperature, 1));
    		lastTemperature[i] = temperature;
    sleep(SLEEP_TIME);
  • Plugin Developer
    When you create a new post, click on the 'code' button when you want to insert code.
    Back on topic, I don't think that's the actual code, since the log showed that no sketch name was sent. Receiving the sketch name is what triggers the creation of the thing, so it's kind of important.
    For example, here's a node presentation from my own logs:
    2019-06-20 10:20:03.441 ERROR  : mysensors: DEBUG:mysensors:Receiving 33;255;3;0;11;Fireplace
    2019-06-20 10:20:03.446 ERROR  : mysensors: DEBUG:mysensors:Receiving 33;255;3;0;12;1.2
    ...Yet I don't see "Temperature Sensor" anywhere in your logs.
    Also in your errors I can see this strange situation where the add-on keeps requesting node 0 to present itself.
    Node 0 should theoretically be the MySensors gateway. It only responds with it's version, and not a name. Perhaps that's also an issue (although theoretically it shouldn't be, since node 0 is never turned into a thing).
    Come to think of it, I don't see any messages being handled by the add-on other than the initial two messages from the Gateway.
    You should see all kinds of things with >> like:
    2019-06-20 10:30:34.498 INFO   : mysensors: << Requesting presentation from 35
    2019-06-20 10:30:34.500 INFO   : mysensors: >> incoming message > presentation > id: 35; child: 255; subtype: 17; payload: 2.3.1
    2019-06-20 10:30:34.501 INFO   : mysensors: >> incoming message > internal > id: 35; child: 255; subtype: 11; payload: Anemone
    2019-06-20 10:30:34.503 INFO   : mysensors: >> incoming message > internal > id: 35; child: 255; subtype: 12; payload: 1.0
    2019-06-20 10:30:34.505 INFO   : mysensors: >> incoming message > set > id: 35; child: 1; subtype: 2; payload: 1
  • Ok, I'll look at this and probably just start rebuilding my sensor's and gateway making sure I get those names in there. When I built this over a year ago I was playing with different boards and different sensors and once I got things working in Domoticz I moved on. That's why I have so much program source code out there. This time I'll put a unique, my version number in there so I can keep better track. I think I'll even physically label the sensors this time! Thanks for all your time on this, I really like the looks of the WebThings GW and it's really a good fit for the stuff I'm doing/trying to do. Oh, thanks for that about the code button, didn't know about that.
  • Plugin Developer
    @rmalbers Wait one second. I've been playing with the code and I have a suspicion about what's going on. I'm uploading a new version of the add-on, try that first.
  • @alowhum Wow, ok, that's sounds great. I'll watch here for word.
  • Plugin Developer
    Version 0.1.0 has been accepted. Try it and let me know how it goes?
  • Ok ,updated addon and rebooted GW. This test was in Ethernet mode. No luck but the log sure looks different:
    2019-06-21 14:32:15.079 INFO : Opened a new things socket
    2019-06-21 14:32:15.185 INFO : About to call startPairing on MySensorsAdapter
    2019-06-21 14:32:15.197 INFO : mysensors: -Connection status is present in the config data.
    2019-06-21 14:32:15.199 INFO : mysensors: RECREATING DEVICES FROM PERSISTENCE
    2019-06-21 14:32:15.200 INFO : mysensors:
    2019-06-21 14:32:15.202 INFO : mysensors: #0
    2019-06-21 14:32:15.203 INFO : mysensors: -Gateway choice: Ethernet gateway
    2019-06-21 14:32:15.205 INFO : mysensors: Selected IP address and port: 192.168.1.98
    2019-06-21 14:32:15.206 INFO : mysensors:
    2019-06-21 14:32:15.208 INFO : mysensors: >> incoming message > internal > id: 0; child: 255; subtype: 14; payload: Gateway startup complete.
    2019-06-21 14:32:15.209 INFO : mysensors: Re-requesting presentation of all nodes on the network
    2019-06-21 14:32:15.211 INFO : mysensors: Re-request thread created
    2019-06-21 14:32:15.218 INFO : mysensors:
    2019-06-21 14:32:15.220 INFO : mysensors: >> incoming message > presentation > id: 0; child: 255; subtype: 18; payload: 2.2.0
    2019-06-21 14:32:15.221 INFO : mysensors:
    2019-06-21 14:32:15.222 INFO : mysensors: >> incoming message > internal > id: 0; child: 255; subtype: 14; payload: Gateway startup complete.
    2019-06-21 14:32:15.224 INFO : mysensors:
    2019-06-21 14:32:15.225 INFO : mysensors: >> incoming message > presentation > id: 0; child: 255; subtype: 18; payload: 2.2.0
    2019-06-21 14:32:15.227 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"startPairing","data":{"timeout":60,"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
    2019-06-21 14:32:15.465 ERROR : mysensors: Node 2 is unknown
    2019-06-21 14:32:36.851 ERROR : mysensors: Node 1 is unknown
    2019-06-21 14:32:50.254 ERROR : mysensors: Node 2 is unknown
    2019-06-21 14:33:09.496 ERROR : mysensors: Node 1 is unknown
    2019-06-21 14:33:15.190 INFO : Pairing timeout
    2019-06-21 14:33:15.196 ERROR : Thing was not added
    2019-06-21 14:33:15.198 ERROR : addNewThing cancelled
    2019-06-21 14:33:15.201 INFO : mysensors: PAIRING INITIATED
    2019-06-21 14:33:15.204 INFO : mysensors: Thread already existed
    2019-06-21 14:33:15.205 INFO : mysensors: Re-requesting presentation of all nodes on the network
    2019-06-21 14:33:15.207 INFO : mysensors: Re-request of node presentation restarted
    2019-06-21 14:33:15.208 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
    2019-06-21 14:33:25.022 ERROR : mysensors: Node 2 is unknown
  • @rmalbers Just to add, this a log using USB GW, it seems to looks slightly different:
    2019-06-21 14:46:04.725 INFO : Unloading MySensorsAdapter
    2019-06-21 14:46:04.729 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"unloadAdapter","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
    2019-06-21 14:46:04.734 INFO : mysensors: Shutting down MySensors adapter
    2019-06-21 14:46:04.736 INFO : mysensors: MySensors adapter was unable to cleanly close PyMySensors loop. This is not a problem.
    2019-06-21 14:46:04.737 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"unloadPlugin","data":{"pluginId":"mysensors-adapter"}}'
    2019-06-21 14:46:05.497 INFO : mysensors: MySensors add-on has succesfully loaded the configuration.
    2019-06-21 14:46:08.255 INFO : Loading add-on: mysensors-adapter
    2019-06-21 14:46:10.552 INFO : mysensors: initialising adapter from class
    2019-06-21 14:46:10.555 INFO : mysensors: IpcClient: Connected to server, registering...
    2019-06-21 14:46:10.559 INFO : mysensors: IpcClient: Received manager message: b'{"messageType":"registerPluginReply","data":{"pluginId":"mysensors-adapter","ipcBaseAddr":"gateway.plugin.mysensors-adapter"}}'
    2019-06-21 14:46:10.561 INFO : mysensors: IpcClient: Registered with PluginServer
    2019-06-21 14:46:10.564 INFO : mysensors: AddonManagerProxy: add_adapter: mysensors-adapter
    2019-06-21 14:46:17.198 INFO : About to call startPairing on MySensorsAdapter
    2019-06-21 14:46:17.205 INFO : mysensors: -Connection status is present in the config data.
    2019-06-21 14:46:17.207 INFO : mysensors: RECREATING DEVICES FROM PERSISTENCE
    2019-06-21 14:46:17.209 INFO : mysensors:
    2019-06-21 14:46:17.210 INFO : mysensors: #0
    2019-06-21 14:46:17.212 INFO : mysensors: -Gateway choice: USB Serial gateway
    2019-06-21 14:46:17.214 INFO : mysensors: Selected USB device address: /dev/ttyUSB0
    2019-06-21 14:46:17.215 INFO : mysensors:
    2019-06-21 14:46:17.217 INFO : mysensors: >> incoming message > internal > id: 0; child: 255; subtype: 14; payload: Gateway startup complete.
    2019-06-21 14:46:17.218 INFO : mysensors: Re-requesting presentation of all nodes on the network
    2019-06-21 14:46:17.220 INFO : mysensors: Re-request thread created
    2019-06-21 14:46:17.221 INFO : mysensors:
    2019-06-21 14:46:17.223 INFO : mysensors: >> incoming message > presentation > id: 0; child: 255; subtype: 18; payload: 2.3.0
    2019-06-21 14:46:17.225 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"startPairing","data":{"timeout":60,"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
    2019-06-21 14:46:17.245 INFO : Opened a new things socket
    2019-06-21 14:46:44.848 ERROR : mysensors: Node 2 is unknown
    2019-06-21 14:47:17.202 INFO : Pairing timeout
    2019-06-21 14:47:17.206 ERROR : Thing was not added
    2019-06-21 14:47:17.208 ERROR : addNewThing cancelled
    2019-06-21 14:47:17.211 INFO : mysensors: PAIRING INITIATED
    2019-06-21 14:47:17.213 INFO : mysensors: Thread already existed
    2019-06-21 14:47:17.215 INFO : mysensors: Re-requesting presentation of all nodes on the network
    2019-06-21 14:47:17.216 INFO : mysensors: Re-request of node presentation restarted
    2019-06-21 14:47:17.218 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
    2019-06-21 14:47:18.140 ERROR : mysensors: Node 1 is unknown
  • Plugin Developer
    Very strange.
    I notice you press the pairing button immediately. You don't have to press the pairing button for it to scan for devices. But it shouldn't affect things either.
    The only device in your persistence file seems to be your gateway (which it does not turn into a thing, but maybe it should. But that's another matter.)
    Have you restarted your devices after starting the gateway? Otherwise they won't show up. Also make sure your devices send actual values when they boot or shortly after, otherwise those won't show up as properties.
    I think it's time to have a look at your Arduino code.
  • @alowhum Sorry, I forgot about rebooting the sensor - SUCCESS! (Now I just have to find the other sensors to reboot them, LOL! This is with the ethernet gateway:
    2019-06-21 15:03:33.639 INFO : Opened a new things socket
    2019-06-21 15:04:08.145 ERROR : mysensors: Node 2 is unknown
    2019-06-21 15:04:25.229 ERROR : mysensors: Child 0 is unknown
    2019-06-21 15:04:33.108 INFO : Pairing timeout
    2019-06-21 15:04:33.111 ERROR : Thing was not added
    2019-06-21 15:04:33.113 ERROR : addNewThing cancelled
    2019-06-21 15:04:33.117 INFO : mysensors: PAIRING INITIATED
    2019-06-21 15:04:33.118 INFO : mysensors: Thread already existed
    2019-06-21 15:04:33.120 INFO : mysensors: Re-requesting presentation of all nodes on the network
    2019-06-21 15:04:33.121 INFO : mysensors: << Requesting presentation from 1
    2019-06-21 15:04:33.123 INFO : mysensors: Re-request of node presentation restarted
    2019-06-21 15:04:33.124 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
    2019-06-21 15:04:35.520 INFO : Successfully created new thing MySensors_1
    2019-06-21 15:04:42.920 ERROR : mysensors: Node 2 is unknown
    2019-06-21 15:04:57.864 ERROR : mysensors: Child 0 is unknown
  • @rmalbers Success with second sensor in garage: (Posting log for informational purposes only)
    2019-06-21 15:11:18.780 INFO : Opened a new things socket
    2019-06-21 15:11:22.651 INFO : Successfully created new thing Temperature Sensor
    2019-06-21 15:11:24.864 ERROR : Thing was not added
    2019-06-21 15:11:24.865 ERROR : addNewThing cancelled
    2019-06-21 15:11:24.869 INFO : mysensors: PAIRING INITIATED
    2019-06-21 15:11:24.871 INFO : mysensors: Thread already existed
    2019-06-21 15:11:24.872 INFO : mysensors: Re-requesting presentation of all nodes on the network
    2019-06-21 15:11:24.874 INFO : mysensors: << Requesting presentation from 1
    2019-06-21 15:11:24.875 INFO : mysensors: Re-request of node presentation restarted
    2019-06-21 15:11:24.877 INFO : mysensors: << Requesting presentation from 2
    2019-06-21 15:11:24.878 INFO : mysensors: AddonMangerProxy: recv: b'{"messageType":"cancelPairing","data":{"adapterId":"mysensors-adapter","pluginId":"mysensors-adapter"}}'
    2019-06-21 15:11:25.829 INFO : getValue for property 2-0-0 for: Temperature Sensor returning 24.1
  • BTW: I know I have to rebuild my sensors, but at least now I have 'things' sort of working and can see better what's going on.
  • Plugin Developer
    Oh my god 😄
  • @alowhum I guess I should sum it up: I have V2.2 and V2.3 sensors running using the Ethernet GW addon config and using the MySensors original, not rebuilt gateway, so the MS gateway is running unchanged, yet does work with the addon and WebThings GW. (I do have to rebuild sensors again for the 'imperial' config setting. domoticz didn't care but it looks like the WebThings GW does use it. (I have mixtures of F degrees, C degrees, etc.)
  • Plugin Developer
    I've updated the first post of the Gateway Addon thread to indicate that devices must be restarted to initially connect them.
  • 6
  • 4
  • 55
29
