Irrigation Controller miniboard
  • Hi everyone!! First of all thanks for all the fantastic stuff here with MySensors in general and the Irrigation Controller in particular.
    I've successfully deployed the controller in my garden with a modified version of the original project: I've added a 5V DC mini transformer and a minimal LCD. Hereunder you can see the homemade version of the pcb already installed controlling 7 sprinklers through HomeAssistant
    Now I'm in the process of creating an enhanced version of the board and the v1.0 is already ordered from a professional pcb manufacturer and must be at home in 4-5 days O_O.
    From the code point of view, I've moved to a simple state machine to make the code more easy to understand and extend. The integration between MySensors and HomeAssistant is not the best and it took a while to make them work together. My next move will be to add different programs from HomeAssitant (but I don't know when ;( )
    At the moment I'm releasing the schema and board if it's in the interest of someone:
    EasyEDA jcataluna
    Hope it helps 😉
    home made PCB
  • @jesus-cataluña
    Hi great work!
    Any chance for your sketch? There isn't many working sketches (without many errors in log) for home assistant. Unfortunately I can't write code.
  • 8
  • 1
  • 1
  • 90
