PI gateway + rfm69 - unable to connect door switch
  • Hello,
    I am not able to make the gateway and the switch communicate when gateway is RPI (meaning RFM69 is directly plugged onto the pi GPIOs)
    It seems that both the gateway and the switch are setup correctly (see code and logs below).
    (My radio modules are functional because everything is working fine when I use an ardouino gateway.)
    gateway : pi 3 + rfm69cw
    switch: ardouino pro-mini + rfm69cw
    MySensors: 2.3.1 on both gateway and switch
    I am able to setup the PI serial GW properly: (same result if I set direct port ttyAMA0)
    ./configure --my-transport=rfm69 --my-rfm69-frequency=868 --my-gateway=serial --my-serial-port=/dev/ttyMySensorsGateway --my-serial-baudrate=115200 --my-serial-is-pty
    INFO Starting gateway...
    INFO Protocol version - 2.3.1
    DEBUG Serial port /dev/ttyMySensorsGateway (115200 baud) created
    DEBUG MCO:BGN:INIT GW,CP=RPNGL---,REL=255,VER=2.3.1
    DEBUG TSF:LRT:OK
    DEBUG TSM:INIT
    DEBUG TSF:WUR:MS=0
    DEBUG TSM:INIT:TSP OK
    DEBUG TSM:INIT:GW MODE
    DEBUG TSM:READY:ID=0,PAR=0,DIS=0
    DEBUG MCO:REG:NOT NEEDED
    DEBUG MCO:BGN:STP
    DEBUG MCO:BGN:INIT OK,TSP=1
    DEBUG TSM:READY:NWD REQ
    DEBUG TSF:MSG:SEND,0-0-255-255,s=255,c=3,t=20,pt=0,l=0,sg=0,ft=0,st=OK:
    switch setup:
    #define MY_PARENT_NODE_ID 0
    #define MY_NODE_ID 1
    #define CHILD_ID 3
    #define MY_RFM69_NEW_DRIVER
    #define MY_RADIO_RFM69
    #define RFM69_868MH
    #define MY_PASSIVE_NODE
    #include <Bounce2.h>
    MCO:BGN:INIT NODE,CP=RPNPA---,REL=255,VER=2.3.1
    TSM:INIT
    TSF:WUR:MS=0
    TSM:INIT:TSP OK
    TSM:INIT:TSP PSM
    TSM:INIT:STATID=1
    TSF:SID:OK,ID=1
    TSM:FPAR
    TSM:FPAR:STATP=0
    TSM:ID
    TSM:ID:OK
    TSM:UPL:DISABLED
    TSM:READY:ID=1,PAR=0,DIS=1
    TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=OK:0100
    TSF:MSG:SEND,1-1-0-0,s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=OK:2.3.1
    TSF:MSG:SEND,1-1-0-0,s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=OK:0
    TSF:MSG:SEND,1-1-0-0,s=3,c=0,t=0,pt=0,l=0,sg=0,ft=0,st=OK:
    MCO:REG:NOT NEEDED
    MCO:BGN:STP
    PUSHED
    TSF:MSG:SEND,1-1-0-0,s=3,c=1,t=16,pt=2,l=2,sg=0,ft=0,st=OK:0
    I am running out of ideas to debug this...
    Thank you.
  • 15
11.3k
