Cant figure out how to implement DS18b20 to 8266gateway directly
  • I am a bit confused how to work with sketches and libraries. I tried to read up at Mysensors.com but i just cant grasp it.
    I want to have a DS18b20 and a relay connected to be able to make a thermostat directly connected to the gateway. but i get errors compiling the code.
    I am sorry for this completely noob question but im been trying for 2days to find examples and copy paste and trying to patch it together to no avail.
    If someone could point out the errors i made i will be on my way building 😃
    Arduino:1.8.11 Hourly Build 2019/12/16 10:04 (Mac OS X), Kort:"Generic ESP8285 Module, 80 MHz, Flash, Legacy (new can return nullptr), All SSL ciphers (most compatible), dtr (aka nodemcu), 26 MHz, 1MB (FS:64KB OTA:~470KB), 2, v2 Lower Memory, Disabled, None, Only Sketch, 115200"
    /var/folders/j1/1s10733x6b1fgwcmf1mk0cf00000gp/T/arduino_modified_sketch_627661/GatewayESP8266.ino: In function 'void presentation()':
    GatewayESP8266:143:1: error: a function-definition is not allowed here before '{' token
    GatewayESP8266:149:1: error: a function-definition is not allowed here before '{' token
    GatewayESP8266:154:21: error: a function-definition is not allowed here before '{' token
     void presentation() {
    GatewayESP8266:203:1: error: expected '}' at end of input
    exit status 1
    option enabled in File -> Preferences.
    Below are my sketch
    #define MY_BAUD_RATE 9600
    #define MY_RADIO_RF24
    //#define MY_RADIO_RFM95
    #define MY_GATEWAY_ESP8266
    #define MY_WIFI_SSID "MySSID"
    #define MY_WIFI_PASSWORD "MyVerySecretPassword"
    // Enable UDP communication
    //#define MY_USE_UDP  // If using UDP you need to set MY_CONTROLLER_IP_ADDRESS or MY_CONTROLLER_URL_ADDRESS below
    #define MY_HOSTNAME "ESP8266_GW"
    #define MY_PORT 5003
    //#define MY_CONTROLLER_URL_ADDRESS "my.controller.org"
    // Enable inclusion mode
    //#define MY_INCLUSION_MODE_BUTTON_PIN D1
    // Set blinking period
    //#define MY_DEFAULT_LED_BLINK_PERIOD 300
    // Flash leds on rx/tx/err
    // Led pins used if blinking feature is enabled above
    #include <OneWire.h>
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    MyMessage msg(0,V_TEMP);
    void before()
      sensors.begin();
      sendSketchInfo("Temperature Sensor", "1.1");
         present(i, S_TEMP);
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msg.setSensor(i).set(temperature,1));
      sleep(SLEEP_TIME);
  • @tjog From an initial glance, can recommend not touching any alcohol for a few days 😂 , and spend some time re-reading the basic intro, outline of sketches, and why they are sequenced the way they are, it is all in the guide here...
    Follow that methodically, throwing pistons, crankshaft, etc. randomly into a box has never yet made a working engine....
    You have SETUP, PRESENTATION, BEFORE, SETUP, PRESENTATION, LOOP, LOOP... There should only be one of each void in a logical sequence, BEFORE, PRESENTATION, SETUP, LOOP.
    Defines, libraries and variables do not belong in PRESENTATION rather than before any voids are called.
    If you look again at the original sketch you copied, it's sequence and contents will be logically laid out and working, the only difference in your case is that it is a Gateway not a Node. The clue lies in the last LOOP "// Send locally attached sensors data here"....
    Start slowly and methodically using the guide, and move the instructions to their correct places, but importantly understand why, it will help later...
  • Hahah regarding the alcohol i think thats the problem!
    I will check everything again with your pointers, thanks for the answer
    I actually had a second look after i posted and made some changes, i got a lot less errors but still wasnt able to compile. I will have a new pass
