433mhz keyfob remote
  • hi there,
    i'm here to share my project, it's just a simple keyfob programming/receiver to be connected to our mysensors net. I use this to control my surveillance sistem (activation/deactivation).
    i wrote this sketch for mysensors 1.5, so maybe it need to be translated for latest version.
    my coding it's so rude, so i hope someone can also improve it.
    later i will post schematic and the used component list.
    cheers
    #include <RCSwitch.h>
    #include <EEPROMEx.h>
    #define STATIC_ID 4
    #define CHILD_ID 1
    RCSwitch RFKey = RCSwitch();
    const byte progSwitch = 4;                  // Prgram button
    const byte ledGreen = 6;                  // green led
    const byte ledRed = 7;                  // red led
    unsigned long lastAvailable = 0;
    unsigned long previousMillis = 0;
    int timeout = 3000;               // set unlock timeout here
    int oldValue=-1;
    unsigned long code1, code2, code3;
      gw.begin(NULL, STATIC_ID, false);
      pinMode(progSwitch, INPUT_PULLUP);      // Prog button
      pinMode(ledGreen, OUTPUT);              // unlock/learning
      pinMode(ledRed, OUTPUT);                // invalid code/stop learnig
      RFKey.enableTransmit(3);     // Transmitter is connected to Arduino Pin #3
      RFKey.enableReceive(0);  // Receiver on inerrupt 0 => that is pin #2
      gw.sendSketchInfo("Ricevitore 433 MHZ", "1.0");
      gw.present(CHILD_ID, S_DOOR);
      code1 = EEPROM.readLong( 50 );
      code2 = EEPROM.readLong( 100 );
      code3 = EEPROM.readLong( 150 );
      if ( !digitalRead(progSwitch) ) {                    // check button
        unsigned long lastMillis = 0;
        previousMillis = millis();
        while ( !digitalRead(progSwitch) ) {
          lastMillis = millis();
        if ( (lastMillis - previousMillis) > 10000 ){                 // press button 10sec
          updateCode();                                               // change remote codes
        else if ( (lastMillis - previousMillis) > 200 ){              // debounce
          progRemote();                                               // send radio code to remotes learn
      if ( RFKey.available() ) {       // multicode control
        blinkLed(ledRed, 1, 50);
        unsigned long receivedCode = RFKey.getReceivedValue();
        RFKey.resetAvailable();
       Serial.println (receivedCode);
        if ( receivedCode == code1 ){       // check first code
          unsigned long checkTime = millis();
          receivedCode = 0;
          boolean flag = false;
          while ( millis() < (checkTime + timeout) ) {
              if ( receivedCode == code2 ){                //check second code
                Serial.println ("*** UNLOCKED ***");
                digitalWrite( ledGreen, HIGH);
                digitalWrite( ledRed, LOW);
                gw.send(msg.set(0==HIGH ? 1 : 0));             // send unlock code
                flag = true;
                break;
          if (flag == false){
            gw.send(msg.set(1==HIGH ? 1 : 0));
            blinkLed(ledGreen, 1, 100);
            Serial.println ("*** LOCKED ***");
            digitalWrite( ledGreen, LOW);
            digitalWrite( ledRed, HIGH);
            receivedCode = 0;
        else if ( receivedCode == code3 ) {                // CODICE AUX
            gw.send(msg.set(2));
            Serial.println ("*** AUX ***");
            delay(3000);
            receivedCode = 0;
        else{
          delay (1000);
          Serial.println("*** invalid code ***");
          Serial.print("received code: ");
          Serial.println(receivedCode);
          receivedCode = 0;
    void progRemote(){                                    // keyfob programming
      unsigned long code1 = EEPROM.readLong( 50 );
      unsigned long code2 = EEPROM.readLong( 100 );
      unsigned long code3 = EEPROM.readLong( 150 );
      Serial.println("--- CODE 1 ---");
      sendCode(code1);
      Serial.println("terminated");
      blinkLed(ledRed, 1, 1000);
      Serial.println("--- CODE 2 ---");
      sendCode(code2);
      Serial.println("--- CODE 3 ---");
      sendCode(code3);
    void sendCode ( unsigned long sendCode) {
      Serial.print("Sending code (20sec): ");
      Serial.println( sendCode );
      unsigned long lastLedBlink = millis();
      boolean ledStatus = false;
      while ( millis() < ( previousMillis + 20000 ) ) {
        RFKey.send( sendCode, 24 );
        blinkLed(ledGreen, 1, 50);
    void updateCode() {                                          // chandge radio code
      Serial.println("change radio code");
      //unsigned long randomCode1 = random (1000000,9999999);
      unsigned long randomCode1 = random (1000,4094);          // 12 bit
     // randomCode1 = 3618;
      Serial.print ("Codice random1 : ");
      Serial.println(randomCode1);
      //unsigned long randomCode2 = random (1000000,9999999);
      unsigned long randomCode2 = random (1000,4094);          // 12 bit
     // randomCode2 = 2769;
      Serial.print ("Codice random2 : ");
      Serial.println(randomCode2);
      //unsigned long randomCode3 = random (1000000,9999999);
      unsigned long randomCode3 = random (1000,4094);          // 12 bit
     // randomCode3 = 1720;
      Serial.print ("Codice random3 : ");
      Serial.println(randomCode3);
      EEPROM.writeLong( 50 , randomCode1 );
      EEPROM.writeLong( 100 , randomCode2 );
      EEPROM.writeLong( 150 , randomCode3 );
      blinkLed(ledGreen, 1, 3000);
    void checkCode() {                                            // check received code
        Serial.println ("first code unlocked");
        receivedCode = 0;
        while ( millis() < (checkTime + 3000) ) {
          //    Serial.println ("while");
              // Serial.println ("second code unlocked");
              Serial.println("*** valid code received ***");
              //          ALstatus = !ALstatus;
              //          return true;
      else{
        delay (1000);
        //  return false;
    void blinkLed(byte ledPin, byte times, int Delay){
      for ( int i = 0; i < times; i++){
        digitalWrite (ledPin, HIGH);
        delay (Delay);
        digitalWrite (ledPin, LOW);
        delay (Delay);
    Instruction
     press PROG button to send code for keyfob programming
     hold PROG about 10 sec. to reset and generate new code for keyfob programming
  • 8
  • 90
  • 1
  • 1
