Setup problem
  • Hi there,
    I have MyController running on RASPI with NRF24 Serial Module. This seems to work correct. Now I try to add a sensor to the system. I have tried several scripts from the MySensors Library. On the debug interface of the sensor I get this:
     __  __       ____
            |___/                      2.3.2
    16 MCO:BGN:INIT NODE,CP=RNNNA---,FQ=8,REL=255,VER=2.3.2
    28 TSM:INIT
    28 TSF:WUR:MS=0
    36 TSM:INIT:TSP OK
    38 TSF:SID:OK,ID=100
    40 TSM:FPAR
    45 ?TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    2054 !TSM:FPAR:NO REPLY
    2056 TSM:FPAR
    2060 ?TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    4069 !TSM:FPAR:NO REPLY
    4071 TSM:FPAR
    4075 ?TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    6084 !TSM:FPAR:NO REPLY
    6086 TSM:FPAR
    6090 ?TSF:MSG:SEND,100-100-255-255,s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=OK:
    8099 !TSM:FPAR:FAIL
    8101 TSM:FAIL:CNT=1
    8103 TSM:FAIL:DIS
    8105 TSF:TDI:TSL
    On MyController the gateway-setup is as follows:
    Is it correct, that I can connect a sensor to the gateway without node? Or can I use a sensor as a node, too?
  • @Skysurfer14 I am not totally sure what you have done, so this might help you get more help.
    1. The sensor is connected to what?
    2. Post the gateway code so we can see what is happening there.
    3. Your debug shows that the node cannot find the parent (gateway) and therefore fails. Again, how it is all connected (drawing, photo) would help.
