Your suggestions to choose naming for "sensor" and "variable"
  • Plugin Developer
    MyController 2.0 is in the development stage. I hope we can do a pre-release soon.
    I do not want to limit MyController usage not only to the sensors world. can be used for another use case too.
    Example:
    • monitor stock market and act based on that
    • monitor GitHub issues, JIRA issues act based on that
    • Monitor an application on a computer
    • We have many use cases...
    The names should be generic and can be adaptable for all use cases.
    So we need a better common name for the sensor and variable.
    Current approach (In Version 1.x): Gateway >> Node >> Sensor >> Variable
    Sensor:
    • The sensor will be renamed as element
    • I need better naming here if this is not looking good
    Variable:
    • We cannot use the name variable, it is more confusing.
    • The Variable will be renamed as field (inputs are welcome)
    Please respond back with your suggestions
    between, Current work of MyController 2.0 deployed at https://demo-v2.mycontroller.org (Username:admin Password: admin)
  • Hello @jkandasa
    This is looking very good. Nomenclarture wise - I am of the opnion that users adapt but if you ask me I like sensor over element (but I can live with element as well).
    In future will it be possible port this to mobile apps for iOS and Android?
    One integration I would request is for HomeKit.
    Thank you
  • Plugin Developer
    @Puneit-Thukral Thanks for your suggestions
    Mobile app is a long pending work for MyContorller. Yes, in future we have to develop.
    Sure, I add it in the note. Thanks!
  • Gateway >> Node >> Device >> Metrics
    Nodes have devices attached and each device has metrics.
