requesting data from controller (Domoticz)
  • Hi All,
    I have a battery node, which I wish to poll the latest data from the controller.
    I am using a presentation
    present(CHILD_ID_WATERTIME1, S_HEATER, "Water Time1 Min", false);
    I request data
    request( CHILD_ID_WATERTIME1, V_HVAC_SETPOINT_HEAT);
    The returned and actioned result has no data payload
    119631 TSF:MSG:SEND,33-33-0-0,s=11,c=2,t=47,pt=0,l=0,sg=0,ft=0,st=OK:
    119676 TSF:MSG:READ,0-0-33,s=11,c=2,t=47,pt=0,l=0,sg=0:
    the true data is 13
    I have tried V_VAR1, indeed, in a loop I have tried types "0" to "50"
    I have gotten round this by having the node set a value of a child item, and then run a script to "push" the values to the node, which works fine,
    The code in the "command" and "request" functions is identical, one returns a data value, one does not.
    I realise I must be doing something fundamentally wrong.
    Does Domoticz have issues with requests? It all seems fine on the controller page on this website.
    The code is a bit of a mess at the moment, as I have been trying to get the request working.
    Regards and thanks, Nigel
    Got a work around, used S_INFO and V_TEXT.
    THE CONTROLLER page definitely shows Thea requests are supported for almost all types, so something isn't right.
  • 15
  • 10
