  3. 6 Way wall touch switch
25 Posts 13 Posters 20.3k Views 16 Watching
  • ferpandoF Offline
    ferpandoF Offline
    ferpando
    This weekend I've been busy with a prototype for a touch wall switch.
    So far is going pretty well and everything seems to work.
    I still need to integrate it with MySensors, but I hope this will be the easiest part.
    The only problem I found is with the sensitivity of the touch sensors when connected to external power.
    It works perfectly when using USB power, but not quite right then using AC power.
    Here's how it looks so far. Remember this is just a proof of concept and many things where just do as I go and probably will be a better way to do it.
    Any suggestions / comments will be greatly appreciated.
    This is the front plate made with a 2mm methacrylate plastic, with a printed paper behind.
    This is the back side with the touch controller
    And this is the actual node with the led driver and the buzzer
    And this is how it works for now
    c100b.mp4
    • AWIA Offline
      AWIA Offline
      AWI
      I love to hear the details.. Have been waiting for some original projects.
      • hekH Offline
        hekH Offline
        Looks great @ferpando!
        • A Offline
          A Offline
          Atman
          Really impressive! Have you made the tocuh panel by yourself?
          ferpandoF 1 Reply Last reply
          • A Atman
            ferpandoF Offline
            ferpandoF Offline
            ferpando
            @Atman
            Yes it is all hand made.
            Next step would be to make a board to make it smaller and easier to make
            • korttomaK Offline
              korttomaK Offline
              korttoma
              Looking forward to more details about this build, you used the MPR121 right?
              • Tomas
              • korttomaK korttoma
                ferpandoF Offline
                ferpandoF Offline
                ferpando
                @korttoma
                Yes that's the module.
                Maybe i should use just the chip in next versions to integrate better with the rest so the final board could be smaller
                • ferpandoF Offline
                  ferpandoF Offline
                  ferpando
                  This is a rough integration of the code with MySensors.
                  It sends messages back and forth, so if a button is touched it turns on the corresponding device on the controller and if the switch is turned on the controller, the touch leds are updated accordingly
                  #include "mpr121.h"
                  #include <Wire.h>
                  #include "LedControlMS.h"
                  #include <MyBuffer.h>
                  #define CHILD_ID1 1   // first child
                  #define CHILD_NUM 6    // number of switches
                  //define working pins
                   #define BUZZER 7   // buzzer pin
                   #define DIN    6   // pin 6 is connected to the DataIn
                   #define CLK    4   // pin 4 is connected to the CLK
                   #define LOD    8   // pin 8 is connected to LOAD
                   #define IRQ    3   // irq pin for touch control
                   #define BAKLIT 5   // pin PWM for backlight leds
                  // ********* MyBuffer ***********************************************************
                  MyBuffer buffer;               // define a new buffer
                  long previousMillis = 0;       // will store last time buffer was processed
                  long interval = 1000;           // interval at which to check buffer
                  //define a new led control
                  LedControl lc=LedControl(DIN,CLK,LOD,1);
                  //int irqpin = 3;  // Digital pin IRQ
                  boolean touchStates[12]; //to keep track of the previous touch states
                  boolean touchMemory[12]; //to keep track of the touch switch states
                  // correspondence between touch and led pins
                  int mapping[2][6]={{0,1,2,3,4,5}     // touch pins
                                    ,{1,0,2,5,4,3}};   // led pins
                  int sound = 500;
                  int touchDelay=500;
                  void setup(){
                    // init LED backlight
                    pinMode(BAKLIT, OUTPUT);
                    analogWrite(BAKLIT, 5);
                    pinMode(IRQ, INPUT);
                    digitalWrite(IRQ, HIGH); //enable pullup resistor
                    Wire.begin();
                    pinMode(BUZZER, OUTPUT);
                    for (int i=0; i < 12; i++){
                      touchMemory[i]=false;
                    mpr121_setup();
                    //initialize MAX72XX
                    lc.shutdown(0,false);
                    lc.setIntensity(0,15);
                    lc.clearDisplay(0);
                    gw.begin(incomingMessage, AUTO); //do not make relay node
                    gw.sendSketchInfo("WallTouch", "1.0");
                    for (int i=0; i<CHILD_NUM;i++) {
                      gw.present(CHILD_ID1+i, S_LIGHT);
                      // Set touch button leds to last known state (using eeprom storage)
                      touchMemory[i] = gw.loadState(i)?true:false;
                      setLed(mapping[1][i],touchMemory[i]);
                  void loop(){
                    gw.process();
                    //watch for touch events
                    readTouchInputs();
                    //check for buffer items once in a while
                    checkTime();
                  void checkTime(){
                     if(currentMillis - previousMillis > interval) {
                          previousMillis = currentMillis;
                          processBuffer();
                    buffer.push(message.sensor,message.type,message.getString());
                  //gets message from buffer if exists
                  void processBuffer(){
                      if(!buffer.isEmpty()){
                          String msg=buffer.pop();
                          int mIndex = msg.indexOf(';');
                          int secondmIndex = msg.indexOf(';', mIndex+1);
                          String firstValue = msg.substring(0, mIndex);
                          String secondValue = msg.substring(mIndex+1, secondmIndex);
                          String thirdValue = msg.substring(secondmIndex+1);
                          int sensor = firstValue.toInt();
                          int type = secondValue.toInt();
                          String data = thirdValue;
                          Serial.println("    >> Process MSG: s:"+ firstValue +", t:"+secondValue+", d:"+thirdValue);
                          processMsg(sensor, type, data);
                  //process message from queue
                  void processMsg(int sensor, int type, String data){
                    boolean msg;
                     switch(type){
                          case V_LIGHT:
                             //comando para 1 rele
                             msg=data.toInt()?1:0;
                             // Store state in eeprom
                             gw.saveState(sensor, msg);
                             // Write some debug info
                             Serial.print("--> Incoming change for child:");
                             Serial.print(sensor-1);
                             Serial.println(msg);
                             setTouchButton(sensor-1);
                            break;
                  void setTouchButton(int pressed){
                        MyMessage msg(CHILD_ID1+pressed,V_LIGHT);
                        Serial.print("pin ");
                        Serial.print(pressed);
                        Serial.print(" was just touched");
                        Serial.print(", turning: ");
                        touchMemory[pressed]=touchMemory[pressed]?false:true;
                        gw.saveState(pressed, touchMemory[pressed]);
                        Serial.println(touchMemory[pressed]?"ON":"OFF");
                        setLed(mapping[1][pressed],touchMemory[pressed]?true:false);
                        gw.send(msg.set(touchMemory[pressed] ? 1 : 0));
                        touchSound();
                  void setLed(int led, boolean lit){
                    lc.setLed(0,0,led,lit);
                  void readTouchInputs(){
                    if(!checkInterrupt()){
                      //read the touch state from the MPR121
                      Wire.requestFrom(0x5A,2);
                      byte LSB = Wire.read();
                      byte MSB = Wire.read();
                      uint16_t touched = ((MSB << 8) | LSB); //16bits that make up the touch states
                      for (int i=0; i < 12; i++){  // Check what electrodes were pressed
                        if(touched & (1<<i)){
                          if(touchStates[i] == 0){
                             //pin i was just touched
                            setTouchButton(i);
                            delay(touchDelay);
                            }else if(touchStates[i] == 1){
                              //pin i is still being touched
                          touchStates[i] = 1;
                        }else{
                         /* if(touchStates[i] == 1){
                            Serial.print(i);
                          Serial.println(" is no longer being touched");
                            //pin i is no longer being touched
                          touchStates[i] = 0;
                  void touchSound(){
                    tone(BUZZER, sound, 3);
                  void mpr121_setup(void){
                    set_register(0x5A, ELE_CFG, 0x00);
                    // Section A - Controls filtering when data is > baseline.
                    set_register(0x5A, MHD_R, 0x01);
                    set_register(0x5A, NHD_R, 0x01);
                    set_register(0x5A, NCL_R, 0x00);
                    set_register(0x5A, FDL_R, 0x00);
                    // Section B - Controls filtering when data is < baseline.
                    set_register(0x5A, MHD_F, 0x01);
                    set_register(0x5A, NHD_F, 0x01);
                    set_register(0x5A, NCL_F, 0xFF);
                    set_register(0x5A, FDL_F, 0x02);
                    // Section C - Sets touch and release thresholds for each electrode
                    set_register(0x5A, ELE0_T, TOU_THRESH);
                    set_register(0x5A, ELE0_R, REL_THRESH);
                    set_register(0x5A, ELE1_T, TOU_THRESH);
                    set_register(0x5A, ELE1_R, REL_THRESH);
                    set_register(0x5A, ELE2_T, TOU_THRESH);
                    set_register(0x5A, ELE2_R, REL_THRESH);
                    set_register(0x5A, ELE3_T, TOU_THRESH);
                    set_register(0x5A, ELE3_R, REL_THRESH);
                    set_register(0x5A, ELE4_T, TOU_THRESH);
                    set_register(0x5A, ELE4_R, REL_THRESH);
                    set_register(0x5A, ELE5_T, TOU_THRESH);
                    set_register(0x5A, ELE5_R, REL_THRESH);
                    set_register(0x5A, ELE6_T, TOU_THRESH);
                    set_register(0x5A, ELE6_R, REL_THRESH);
                    set_register(0x5A, ELE7_T, TOU_THRESH);
                    set_register(0x5A, ELE7_R, REL_THRESH);
                    set_register(0x5A, ELE8_T, TOU_THRESH);
                    set_register(0x5A, ELE8_R, REL_THRESH);
                    set_register(0x5A, ELE9_T, TOU_THRESH);
                    set_register(0x5A, ELE9_R, REL_THRESH);
                    set_register(0x5A, ELE10_T, TOU_THRESH);
                    set_register(0x5A, ELE10_R, REL_THRESH);
                    set_register(0x5A, ELE11_T, TOU_THRESH);
                    set_register(0x5A, ELE11_R, REL_THRESH);
                    // Section D
                    // Set the Filter Configuration
                    // Set ESI2
                   set_register(0x5A, FIL_CFG, 0x12);  //12 mas  menos
                     //set_register(0x5A, FIL_CFG, 0x24);  //segundo filtro
                   // set_register(0x5A, 0x5C, 0x28);    // primer filtro (mio)
                    //ajuste de la corrente de carga de cada pin
                     /*  set_register(0x5A, 0x5F, CDC_sensor[0]);   //el 0
                        set_register(0x5A, 0x60, CDC_sensor[1]);   //el 1
                        set_register(0x5A, 0x61, CDC_sensor[2]);   //el 2
                        set_register(0x5A, 0x62, CDC_sensor[3]);   //el 3
                        set_register(0x5A, 0x63, CDC_sensor[4]);   //el 4
                        set_register(0x5A, 0x64, CDC_sensor[5]);   //el 5
                    // Section E
                    // Electrode Configuration
                    // Set ELE_CFG to 0x00 to return to standby mode
                    set_register(0x5A, ELE_CFG, 0x0C);  // Enables all 12 Electrodes
                    // Section F
                    // Enable Auto Config and auto Reconfig
                    /*set_register(0x5A, ATO_CFG0, 0x0B);
                    set_register(0x5A, ATO_CFGU, 0xC9);  // USL = (Vdd-0.7)/vdd*256 = 0xC9 @3.3V   set_register(0x5A, ATO_CFGL, 0x82);  // LSL = 0.65*USL = 0x82 @3.3V
                    set_register(0x5A, ATO_CFGT, 0xB5);*/  // Target = 0.9*USL = 0xB5 @3.3V
                  boolean checkInterrupt(void){
                    return digitalRead(IRQ);
                  void set_register(int address, unsigned char r, unsigned char v){
                      Wire.beginTransmission(address);
                      Wire.write(r);
                      Wire.write(v);
                      Wire.endTransmission();
                  • ferpandoF Offline
                    ferpandoF Offline
                    ferpando
                    I got it finally installed.
                    This is what it looks like.
                    https://youtu.be/2AEMxA0ZxUc
                    I'm working on a pcb smaller version. I'll keep you posted.
                    • Q Offline
                      Q Offline
                      quocanhcgd
                      @ferpando said:
                      LedControlMS
                      Can you share to me your project, pls?
                      How to cônnect 6 buttons with 6 leds?
                      sorry i newbie.
                      • TotcheT Offline
                        TotcheT Offline
                        Totche
                        This post is deleted!
                        • Q quocanhcgd
                          @ferpando said:
                          LedControlMS
                          sorry i newbie.
                          ferpandoF Offline
                          ferpandoF Offline
                          ferpando
                          @quocanhcgd
                          I'll post the project when I finish the PCB and everything is a bit more mature.
                          I already uploaded the sketch I used here.
                          I made it with a max7219 led driver but you could also use a shift register to control the leds with minimal modifications
                          G 1 Reply Last reply
                          • ferpandoF ferpando
                            @quocanhcgd
                            G Offline
                            G Offline
                            gizzmo
                            Hi ferpando,
                            I'm also very interested in your project ... so if you can share your full setup that would be very cool. And keep up the good work.
                            BWT. your sketch looks very advanced, this is not your first time ... right :-)
                            • Frank HerrmannF Offline
                              Frank Herrmann
                              Any News?
                              • D Offline
                                Dirk_H
                                I also built a 6way wall switch. It does not have lights but is battery powered and very well documented. It is kind of rocket science because it has a 3d printed housing and a self etched pcb but maybe it helps anyway at least for the (very easy) source code:
                                http://forum.mysensors.org/topic/1018/
                                • V Offline
                                  V Offline
                                  Vince
                                  This looks very nice. Love the led to see what's still on
                                  • D Dirk_H
                                    ferpandoF Offline
                                    ferpandoF Offline
                                    ferpando
                                    @Dirk_H
                                    Yes I saw it before and served as inspiration.
                                    Now I'm making a more compact version with a custom PCB.
                                    I'm new to smc so let's see how it goes :-)
                                    • V Vince
                                      ferpandoF Offline
                                      ferpandoF Offline
                                      ferpando
                                      @Vince
                                      I left some light in the leds because when it's dark/night, you can still find the buttons.
                                      Now it has 2 leds per button, but the plan is to use an RGB led so it can be further customized.
                                      • DidiD Offline
                                        DidiD Offline
                                        Didi
                                        Is there a chance that you can share your full setup? I like your wall touch switch very much. :smile:
                                        if (knowledge == 0) { use BRAIN; use GOOGLE;use SEARCH; } else {make POST;}
                                        • DidiD Didi
                                          ferpandoF Offline
                                          ferpandoF Offline
                                          ferpando
                                          @Didi
                                          YesI will when I have the second version ready.
                                          This is a bit messy :-)
                                          DidiD 2 Replies Last reply
