  3. Node freezing up
Node freezing up
29 Posts 9 Posters 19.6k Views 3 Watching
  • ferpandoF
    ferpandoF
    ferpando
    I have a node that every once in a while just stops responding.
    I have to unplug it to get it back working.
    It is strange because it doesn't appear to be a reason.
    Anyone had issues like this before?
    • korttomaK
      korttomaK
      korttoma
      I had similar behavior when I accidentally feed 5V to the NRF24L01+ so my guess is a power issue like in most cases. Check the voltage on the NRF24L01+.
      • Tomas
      ferpandoF 1 Reply Last reply
      • korttomaK korttoma
        ferpandoF
        ferpandoF
        ferpando
        @korttoma
        Yes I did check the power but maybe is a defective module?
        It only happens when not connected to the console, so it's hard to track down
        • MagiskeM
          MagiskeM
          Magiske
          What are you powering it with ?? 5v usb or battery ??
          • AWIA
            AWIA
            AWI
            wrote on last edited by AWI
            It happened frequently to me when using relays (inductive load). Spikes on the powerline can easily freeze the radio.
            • GuyPG
              GuyPG
              GuyP
              Can you give more details of what your node is? what hardware have you used? do you have a circuit diagram?
              • MagiskeM Magiske
                ferpandoF
                ferpandoF
                ferpando
                @Magiske
                12V power supply
                • AWIA AWI
                  ferpandoF
                  ferpandoF
                  ferpando
                  @AWI
                  Relays are isolated using opto-couplers so it should`t be a problem.
                  The relay board is this or very similar:
                  http://www.ebay.com/itm/Durable-New-16-Channel-12V-Relay-Module-Interface-Board-For-Arduino-PIC-ARM-DSP-/331477749403
                  Power goes to the relay board and then it powers the arduino
                  AWIA 1 Reply Last reply
                  • MagiskeM
                    MagiskeM
                    Magiske
                    And you have added a cap for the radio ?
                    Try to add a blink, just to see if the board crashed/freezes. If not it's properly the radio.
                    • GuyPG GuyP
                      ferpandoF
                      ferpandoF
                      ferpando
                      @GuyP
                      sorry no diagram, but the node is basically an arduino with radio connected to this relay board
                      • MagiskeM Magiske
                        ferpandoF
                        ferpandoF
                        ferpando
                        @Magiske
                        Yes it has a cap on the radio.
                        What do you mean by add a blink?
                        • MagiskeM
                          MagiskeM
                          Magiske
                          wrote on last edited by Magiske
                          Just add blink code or add an ekstra led to see if the code is running..
                          • MagiskeM Magiske
                            ferpandoF
                            ferpandoF
                            ferpando
                            @Magiske
                            Ok got it.
                            I have a led on board, so I'll make it blink to see if it is still alive
                            • ferpandoF ferpando
                              @AWI
                              AWIA
                              AWIA
                              AWI
                              @ferpando The optocoupler takes care of the load on the Arduino outputs. What I tried to say is that the inductive load of the relays on the power lines can be substantiall. I there is any sharing of power (same supply) of the relay and the radio it is very hard to avoid lock-ups.
                              below an excerpt from Jeelabs
                              upload-17c0f15c-c9de-4b00-9e21-80017497b551
                              • AWIA AWI
                                ferpandoF
                                ferpandoF
                                ferpando
                                wrote on last edited by ferpando
                                @AWI
                                I don't have an oscilloscope to test this.
                                I'll try to power both devices separately, but at least they always have a common ground. Could this also affect the radio?
                                Adding some capacitors could improve things?
                                • AWIA
                                  AWIA
                                  AWI
                                  @ferpando A common ground is ok (and necessary).. A capacitor can improve things. Many times it is trial & error. What worked for me is having a seperate regulator and decoupling capacitor of 470uF for the feed to the relay. It is hard to read the schematic of the relay board on e-bay but measures like a diode over the relay-coil need to be in (and probably are). Switching inductive loads with the relay can also introduce EM problems.
                                  It's science... using Solid State relays is a long term reliable (short term expensive) alternative. ... good luck, there may be experts around on the forum.
                                  • AWIA AWI
                                    ferpandoF
                                    ferpandoF
                                    ferpando
                                    @AWI
                                    Looks like it has a regulator and a 1000uF capacitor plus a smaller one.
                                    I'll try to add a second regulator with capacitor just for the arduino and see what happens
                                    AWIA vladimirV 2 Replies Last reply
                                      @AWI
                                      AWIA
                                      AWIA
                                      AWI
                                      @ferpando That certainly looks like a power supply. Please keep me informed.
                                      • T
                                        TimO
                                        I have exactly the same Problem. But I'm not sure the relays are the problem.
                                        I've added a keep alive message to know when it stops working and implemented a watchdog.
                                        ferpandoF AWIA 2 Replies Last reply
                                        • T TimO
                                          ferpandoF
                                          ferpandoF
                                          ferpando
                                          @TimO
                                          Could you elaborate a bit more about the watchdog?
                                          MagiskeM 1 Reply Last reply
