Detect Interrupt / Timer
  • Hello,
    maybe a noob Question but i can´t find an answer:
    I want to combine the Motion and the DS18B20 program. So The Temperature is sending every xx minutes, and the Motion Sensor is sending imedently. So I have to detect if the sleep is ending by the Time or The Interrupt. Is there a simple way to detect? The Code is dirty combined, i Know. I will make it better if its possible. Thanks!
     * Simple binary switch example
     * Connect button or door/window reed switch between
     * digitial I/O pin 3 (BUTTON_PIN below) and GND.
     * http://www.mysensors.org/build/binary
    //#define MY_RADIO_NRF24
    #define MY_RADIO_RFM69
    //#define MY_IS_RFM69HW
    #define MY_NODE_ID      200
    // HW hinten dran = #define MY_IS_RFM69HW wird benötigt
    // BWM WZ     101
    // Test       200
    #include <OneWire.h>
    #define COMPARE_TEMP 0 // Send temperature only if changed? 1 = Yes 0 = No
    #define ONE_WIRE_BUS 4 // Pin where dallase sensor is connected
    #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
    #define INTERRUPT BUTTON_PIN-2
    int BATTERY_SENSE_PIN = A0;
    unsigned long SLEEP_TIME = 600000;
    //12Std = 43200000
    int numSensors=0;
    bool receivedConfig = false;
    bool metric = true;
    int oldValue=-1;
    MyMessage msg(0,V_TEMP);
    MyMessage msg1(3,V_TRIPPED);
    void before()
      sensors.begin();
      // Setup the button
      pinMode(BUTTON_PIN,INPUT);
      // Activate internal pull-down
      digitalWrite(BUTTON_PIN,LOW);
      analogReference(INTERNAL);
    void presentation() {
      sendSketchInfo("BWM Temp", "1.0");
      present(3, S_DOOR);
         present(i, S_TEMP);
      // BWM
      int value = digitalRead(BUTTON_PIN);
      send(msg1.set(value==HIGH));
      // Temp
      sleep(conversionTime);
        float temperature = static_cast<float>(static_cast<int>((getControllerConfig().isMetric?sensors.getTempCByIndex(i):sensors.getTempFByIndex(i)) * 10.)) / 10.;
        #if COMPARE_TEMP == 1
        #else
          send(msg.setSensor(i).set(temperature,1));
          Serial.print(temperature);
          // get the battery Voltage
    #ifdef MY_DEBUG
        Serial.println(sensorValue);
        Serial.println(digitalRead(BUTTON_PIN));
        int batteryPcnt = sensorValue *0.9375 -779.375;
        // Raum       Gain             Offset
        // Terrasse   0.9375          -779.375
    #ifdef MY_DEBUG
        float batteryV  = sensorValue * 0.003363075;
        Serial.print(batteryV);
        Serial.println(" V");
        Serial.print(batteryPcnt);
        Serial.println(" %");
       sleep(INTERRUPT,CHANGE,SLEEP_TIME);
  • Mod
    Welcome to the forum @Dave2526
    Yes. The return value of the sleep call will let you know the reason for waking up. Documentation: https://www.mysensors.org/download/sensor_api_20#sleeping
  • Thats what I think, a really simple thing, Thank You, it works!
    resp_sleep=sleep(INTERRUPT,CHANGE,SLEEP_TIME);
    and then hust a simple if resp_sleep....
    Thanks!
  • 24
  • 10
