Help me build a 6-light-sensor & 2 ch relay node.
  • Hi!
    I am trying to build a 6-light-sensor & 2 ch relay node to control my old dehumidifier. When I disassembled it, I found 2 switches (power & mode) and 6 leds which can be used to control and report status. Also it has 5v output.
    Below is the sketch I came up with. It is showing the light sensor values as below but can't see 2ch relay switches. Am I missing something?
    // Enable debug prints
    #define MY_RADIO_RF24
    //#define MY_RS485
    #define MY_NODE_ID 7
    #define RELAY_PIN 3 // Arduino Digital I/O pin number for power relay (connected to D3)
    #define RELAY_PIN 4 // Arduino Digital I/O pin number for mode relay (connected to D4)
    #define NUMBER_OF_RELAYS 2 // Total number of attached relays (2 in this case)
    #define RELAY_ON 1 // GPIO value to write to turn on attached relay
    #define CHILD_ID_LIGHT_1 0
    #define CHILD_ID_LIGHT_2 1
    #define CHILD_ID_LIGHT_3 2
    #define CHILD_ID_LIGHT_4 3
    #define CHILD_ID_LIGHT_5 4
    #define CHILD_ID_LIGHT_6 5
    #define LIGHT_SENSOR_1_ANALOG_PIN A0
    #define LIGHT_SENSOR_2_ANALOG_PIN A1
    #define LIGHT_SENSOR_3_ANALOG_PIN A2
    #define LIGHT_SENSOR_4_ANALOG_PIN A3
    #define LIGHT_SENSOR_5_ANALOG_PIN A4
    #define LIGHT_SENSOR_6_ANALOG_PIN A5
    MyMessage msgLight1(CHILD_ID_LIGHT_1, V_LIGHT_LEVEL);
    MyMessage msgLight2(CHILD_ID_LIGHT_2, V_LIGHT_LEVEL);
    MyMessage msgLight3(CHILD_ID_LIGHT_3, V_LIGHT_LEVEL);
    MyMessage msgLight4(CHILD_ID_LIGHT_4, V_LIGHT_LEVEL);
    MyMessage msgLight5(CHILD_ID_LIGHT_5, V_LIGHT_LEVEL);
    MyMessage msgLight6(CHILD_ID_LIGHT_6, V_LIGHT_LEVEL);
    void before()
    for (int sensor=1, pin=RELAY_PIN; sensor<=NUMBER_OF_RELAYS; sensor++, pin++) {
    pinMode(pin, OUTPUT);
    void presentation() {
    // Send the presentation to the controller
    sendSketchInfo("Dehumidifier Controller", "1.0");
    present(CHILD_ID_LIGHT_1, S_LIGHT_LEVEL);
    present(CHILD_ID_LIGHT_2, S_LIGHT_LEVEL);
    present(CHILD_ID_LIGHT_3, S_LIGHT_LEVEL);
    present(CHILD_ID_LIGHT_4, S_LIGHT_LEVEL);
    present(CHILD_ID_LIGHT_5, S_LIGHT_LEVEL);
    present(CHILD_ID_LIGHT_6, S_LIGHT_LEVEL);
    present(sensor, S_BINARY);
    // Setup code here if needed
    // Check light levels
    int lightLevel1 = analogRead(LIGHT_SENSOR_1_ANALOG_PIN);
    int lightLevel2 = analogRead(LIGHT_SENSOR_2_ANALOG_PIN);
    int lightLevel3 = analogRead(LIGHT_SENSOR_3_ANALOG_PIN);
    int lightLevel4 = analogRead(LIGHT_SENSOR_4_ANALOG_PIN);
    int lightLevel5 = analogRead(LIGHT_SENSOR_5_ANALOG_PIN);
    int lightLevel6 = analogRead(LIGHT_SENSOR_6_ANALOG_PIN);
    // Invert the light sensor values: Map the range 0 to 1023 to 100 to 0
    lightLevel1 = map(lightLevel1, 0, 1023, 100, 0);
    lightLevel2 = map(lightLevel2, 0, 1023, 100, 0);
    lightLevel3 = map(lightLevel3, 0, 1023, 100, 0);
    lightLevel4 = map(lightLevel4, 0, 1023, 100, 0);
    lightLevel5 = map(lightLevel5, 0, 1023, 100, 0);
    lightLevel6 = map(lightLevel6, 0, 1023, 100, 0);
    Serial.print("Light1: ");
    Serial.println(lightLevel1);
    Serial.print("Light2: ");
    Serial.println(lightLevel2);
    Serial.print("Light3: ");
    Serial.println(lightLevel3);
    Serial.print("Light4: ");
    Serial.println(lightLevel4);
    Serial.print("Light5: ");
    Serial.println(lightLevel5);
    Serial.print("Light6: ");
    Serial.println(lightLevel6);
    send(msgLight1.set(lightLevel1));
    send(msgLight2.set(lightLevel2));
    send(msgLight3.set(lightLevel3));
    send(msgLight4.set(lightLevel4));
    send(msgLight5.set(lightLevel5));
    send(msgLight6.set(lightLevel6));
    // Add any other code for the loop here
    delay(1000); // Adjust the delay as needed to control the update rate of the light sensor values
    if (message.getType()==V_STATUS) {
    // Change relay state
    digitalWrite(message.getSensor()-1+RELAY_PIN, message.getBool()?RELAY_ON:RELAY_OFF);
    // Store state in eeprom
    saveState(message.getSensor(), message.getBool());
    // Write some debug info
    Serial.print(message.getSensor());
  • Hi @airmedic79
    I see several problems in your code. Here, you redefine RELAY_PIN:
    Its both times RELAY_PIN, the same name for the define, so you will end up with RELAY_PIN equals 4. This should yield a warning.
    You never present the binary sensors, because in this line:
    RELAY_PIN is 4, and NUMBER_OF_RELAYS is 2, so the for loop is never executed.
    Also, I think you got a problem with your sensor IDs, i think id 2 and 4 are doubled.
    Regards, Edi
  • Only if you send a correct message from the controller to the node
    the receive function is called. I don't see a receive in your log.
    I think in your case the receive-function is not called (or called with a wrong message type or node id). Put a
     serial.print("receive() is called with type "); serial.println(message.getType());
    on top of the receive function to see if the receive function is called and which type is handed over..
