measuring VCC (internal) to percentage
  • I managed to measure the Vcc with the atmega with this script:
    long readVcc() {
      #if defined(__AVR_ATmega32U4__) || defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
        ADMUX = _BV(REFS0) | _BV(MUX4) | _BV(MUX3) | _BV(MUX2) | _BV(MUX1);
      #elif defined (__AVR_ATtiny24__) || defined(__AVR_ATtiny44__) || defined(__AVR_ATtiny84__)
        ADMUX = _BV(MUX5) | _BV(MUX0);
      #elif defined (__AVR_ATtiny25__) || defined(__AVR_ATtiny45__) || defined(__AVR_ATtiny85__)
        ADMUX = _BV(MUX3) | _BV(MUX2);
      #else
      long result = (high<<8) | low;
    I have currently this formula to set it to percentage:
      float batteryV  = readVcc();
      int batteryPcnt = (((batteryV - 2000) / 1200) * 100 );
    readVcc outputs the vcc voltage. I want to set it to percentage. @ what voltage should I cut it off to 0%? What is the best formula?
    Full AA alkalines are around 1.6V?
11.3k
