  3. Vera
  4. Upgrading Plugin and Libraries
22 Posts 4 Posters 11.2k Views 1 Watching
  • B
    B
    bluman
    Hi there,
    Is there any recommended approach when upgrading the Vera plugin and Arduino library files?
    For example, when upgrading the plugin files is it best to remove the existing files from the Vera shell before uploading the new ones rather than copying over the top of the existing files?
    Could you provide a sort of guide showing the minimum Arduino library version required to support a certain plugin version or is it irrelevant?
    I'm still happily running version 1.2 on my gateway (still on my breadboard!) and two sensors and now wish to upgrade the gateway radio to the external antenna version. I'll also need to upgrade both sensors to support the newer gateway version.
    If anyone could share their experience I would be very grateful.
    Thanks to all for contributing to such a great project.
    Bluman
      Just upload/overwrite the Vera files. No need to remove anything.
      Keep Arduino library in sync with Vera files (download them at the same time).
      • ferpandoF
        ferpandoF
        ferpando
        I guess you have to reprogram all arduinos with the new code right?
        hekH 1 Reply Last reply
        • ferpandoF ferpando
          @ferpando
          Between versions where over-the-air protocol has changed, yes. But we try to only change this between major version updates.
            @ferpando
            BulldogLowellB
            BulldogLowellB
            BulldogLowell
            @hek
            so, what is the 'latest' library version? Is it 1.2?
              Latest public version is 1.3b3 (xxxxxx)
              There should also be a hash value after version. We auto-update this hash value each time a library file is modified to keep track of the exact version used when someone needs support etc.
              https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/Version.h
                BulldogLowellB
                BulldogLowellB
                BulldogLowell
                so forgive me if I am being thick, but I updated the latest from the links here and here. I installed them and I still have Lib Version 1.2+?
                wrong places?
                  wrong places?
                  @BulldogLowell
                  Those links should work fine.
                  Double check the path where the Arduino libraries should be copied. Follow the guide how to locate library path on the page you linked.
                    @BulldogLowell
                    BulldogLowellB
                    BulldogLowellB
                    BulldogLowell
                    @hek
                    I did that, got it in my Arduino folder, restarted the IDE, updated a device and it still shows old Lib Version.
                    I also downloaded and updated the latest Vera files.
                    So, must I recompile and upload the Gateway to show the updated version number in the the gateway and all the nodes?
                      Yes, update both gateway and nodes. If you just updated one of the nodes (and not gateway) communication might be broken thus new version for node is not showing up.
                        BulldogLowellB
                        BulldogLowellB
                        BulldogLowell
                        hmmm... I updated the gateway, with the files I just downloaded and no luck.
                        ferpandoF 1 Reply Last reply
                          ferpandoF
                          ferpandoF
                          ferpando
                          @BulldogLowell
                          Take a look at mine
                            @BulldogLowell
                            Take a look at mine
                            BulldogLowellB
                            BulldogLowellB
                            BulldogLowell
                            @ferpando said:
                            @BulldogLowell
                            Take a look at mine
                            I cannot understand what is happening here
                              Check the Version.h file of your downloaded library files and assure it contains the newer version before building/uploading the sketch.
                                BulldogLowellB
                                BulldogLowellB
                                BulldogLowell
                                Now I'm more perplexed.
                                I am going to try to recompile and upload the Gateway, again.
                                • BulldogLowellB
                                  BulldogLowellB
                                  BulldogLowell
                                  wrote on last edited by BulldogLowell
                                  This post is deleted!
                                  • B
                                    B
                                    bluman
                                    I've just built a new Ubuntu 1404 64 bit environment and installed the Arduino IDE 1.05 as per the instructions on Arduino Playground here.
                                    I downloaded the Arduino libraries from the MySensors website and followed the guide unzipping into the sketchbook directory (/home/<myuser>/sketchbook) as detailed here.
                                    After restarting the IDE I am presented with the attached error stating that there is a problem with the Arduino libraries, bad library name.
                                    Has anyone else come across this error before?
                                    Bluman
                                    I tried moving the Arduino-master folder in to the libraries folderArduino_IDE_Lib_error.png
                                      Move the content of library folder inside "Arduino-master" into libraries.
                                      • B
                                        B
                                        bluman
                                        Thanks Henk that worked.
                                        • B
                                          B
                                          bluman
                                          OK, I've just uploaded the new plugin files to Vera and restarted, all appears to be working. The new format is now shown in the devices view.
                                          I've hit a snag when trying to compile the serial gateway sketch where it's complaining about the avr/program.h file is missing.
                                          avr/progmem.h: No such file or directory
                                          I noticed the lib directory under Arduino-Master/AVR so I attempted to copy (merge and replace) this into the sketckbook/libraries folder. Unfortunately I'm getting two additional errors relating to the RF24 and SPI libraries.
                                          In file included from /home/hp2540p/sketchbook/libraries/RF24/RF24.h:788:0,
                                          from SerialGateway.ino:26:
                                          /home/hp2540p/sketchbook/libraries/RF24/RF24.c:27:21: fatal error: spi/spi.h: No such file or directory
                                          #include <spi/spi.h>
                                          I'm not in a good place and need to understand the difference with these different library locations.
                                          If others have felt my pain, how did you resolve this issue? HELP!
                                          bluman
