  3. Pirate Chest with Secret Knock Sensor
12 Posts 5 Posters 6.4k Views 2 Watching
  • S Offline
    Sparkman
    wrote on last edited by Sparkman
    Hi all,
    My youngest son and I converted his toy pirate chest to include the secret knock sensor. Pictures are below. The chest we used is perfect as it already contained a false bottom which now hides the electronics. It would be relatively easy to add a false bottom into other chests. The only thing we still want to do is change the blue and red "crystal" eyes in the skull to LEDs that would flash with the secret knock sensor. The sample sketch was modified to only unlock for 5 seconds, otherwise the solenoid gets pretty hot, and also modified to not unlock at power up.
    Components Used:
    • Melissa & Doug Pirate Chest
    • Arduino Nano
    • Nano Breakout Board
    • Sound Detection Sensor Module
    • 12V Solenoid
    • Voltage Regulator
    • Relay Module
    • NRF24L01+ Radio Module
    • Piezo Buzzer from the parts bin
    • Momentary Switch from the parts pin
    • 470uF 35V Electrolytic Capacitor from the parts bin
    • Power Supply Barrel Jack connector
    • 12V Wall Wart from the parts bin
    Build Notes:
    • We used the Nano with the breakout board so that it would be easier to mount to the wood bottom. Any other Arduino should work as well.
    • We used the voltage regulator module to protect the Nano (as much as possible) in case the kids plugged the wrong wall wart into it.
    • We had to add the 470uF capacitor as about 50% of the time when the solenoid activated, the power fluctuations would cause the Nano to reset. With the capacitor added, there has been no issue with resets.
    • You need a fairly beefy wall wart. Although the specs indicate the solenoid is .35A, it seems to draw more than that. I haven't measured the actual usage yet.
    • We were planning to use a TIP120 Darlington Transistor to switch the solenoid on and off, but I was worried that it would get fairly hot so went with a relay instead.
    • Given the current draw of the solenoid we went with a wall-wart rather than with batteries.
    • Some parts (Nano and Voltage Regulator) were screwed down to the bottom, but most have a small dollop of hot glue to hold them down.
    • Total build cost, not including the pirate chest (which was a gift), was about US $20.
    Cheers
    Al
    B 1 Reply Last reply
    • S Sparkman
      Hi all,
      Components Used:
      • Arduino Nano
      • 12V Solenoid
      • Voltage Regulator
      • Relay Module
      Build Notes:
      Cheers
      Al
      B Offline
      B Offline
      BulldogLowell
      @Sparkman
      cool. Is it MySensor'ed to open or otherwise control remotely?
      S 1 Reply Last reply
      • B BulldogLowell
        @Sparkman
        Sparkman
        @BulldogLowell Thanks. Yes it's mysensored. The radio is in the bottom right hand corner. I don't expect to get good range the way it's positioned so I may need to reposition it a bit.
        Cheers
        Al
        • greglG Offline
          greglG Offline
          gregl
          Nice one! - great project to get your kid into electronics and programming!
          • S Sparkman
            Cheers
            Al
            B Offline
            B Offline
            BulldogLowell
            @Sparkman
            A great project to get my (10yr old) son excited about technology & science and working on a project together with me! Thanks for posting!
            :+1:
            :+1:
            (two thumbs up!)
            • P Offline
              P Offline
              petewill
              Cool! I can't wait until my son is old enough to do this. At 3 he's still a little too distracted :)
              • S Offline
                Sparkman
                Thanks for all the kind words everyone. I'm not sure what my son was more excited about. Building it, or seeing it posted on the internet and others commenting on it.:smiley:
                Cheers
                Al
                • S Offline
                  Sparkman
                  I've updated the original post with a parts list and some build notes.
                  Cheers
                  Al
                  • Moshe LivneM Offline
                    Moshe Livne
                    cool project! I am waiting for my sound sensors from China. Patience comes to those who wait, or so they say. I was wondering if the same hardware and software can detect a clap sequence?
                    • Moshe LivneM Moshe Livne
                      Sparkman
                      @Moshe-Livne Thanks. Yes it should be usable for claps as well as you can adjust the sensitivity on those sound sensors.
                      I know the frustration of waiting for shipments from China, especially if one gets lost. By the time they resend and it finally arrives can be over 3 months from the original order. I think for the cheaper parts, I'm going to order the same item at the same time from a couple of different sellers to improve the chances of them arriving in a reasonable time. The inconsistency is what's most annoying. Some packages arrive within a couple of weeks and some take 2 months, although I think Canada customs is to blame in some instances for my shipments.
                      Cheers
                      Al
                      • S Sparkman
                        Cheers
                        Al
                        B Offline
                        B Offline
                        BulldogLowell
                        • B BulldogLowell
                          Sparkman
                          @BulldogLowell LOL, eh!
                          12.0k
