  3. Vera
  4. Vera Lite U17 - Serial Can't Detect Device
cant detectserial gatewayvera liteu17
13 Posts 7 Posters 12.4k Views 2 Watching
  • G Offline
    G Offline
    gbfromhb
    wrote on last edited by gbfromhb
    I have had my serial gateway working for a while, but a while ago it stopped working. It is now saying Can't Detect Device. I'm pretty sure it may have been something I did, but that was months ago, and I'm now back at it. I also need to say I have a USB Hub, and my Insteon USB connection is working fine. I have done the following and have not been able to get past this:
    Created a whole new gateway with a new Nano and radio using the links provided in the MySensors Store.
    Double checked the wiring many times.
    Reinstalled all the MySensors files on the Vera
    Ran ClearEepromConfig
    Removed the Insteon configuration and plugged the Serial Gateway directly into the Vera
    Tried a couple of different USB cables.
    Reinstalled Arduino IDE and MySensors software, and uploaded the sketch into the gateway again.
    In Serial Port configuration made sure the Used by device, baud rate, data bite, and stop bite and parity are correct.
    I'm not sure what the name parameter represents, they were the same and I've tried making that name different.
    I'm not sure what the "Device number" represents and have tried to poke around using Putty to figure this out, but have not figured this out.
    Here is my Serial Port configuration:
    upload-1efdaa2b-5af9-42db-ac44-f70bcb0db98d
    Anyway the adventures continue any ideas would be appreciated.
    • hekH Offline
      hekH Offline
      Weird. It sure looks like it is connected from the config screen dump.
      How does the "Advanced" tab (or equivalent in UI7) look like for the MySensors Gateway device?
      • G Offline
        G Offline
        gbfromhb
        Here are screen captures of three of the four tabs in the advanced section. There was nothing under the commands tab.
        upload-d9eebe87-e432-4dbe-9289-436b1e6fe276
        upload-3d016ba4-72a3-4f02-b452-3cfc269d2dd2
        upload-c5f3c9ec-e19a-49e5-aee2-26d156efd2df
        • hekH Offline
          hekH Offline
          Try setting ComFailure to 0 and save device/reload.
          greglG B 2 Replies Last reply
          • G Offline
            G Offline
            gbfromhb
            @Hek - That did it. It is now working, thanks.
              greglG Offline
              greglG Offline
              gregl
              @hek Do you know why this fixes it?
              Does vera not retry if ComFailure >0 ??
              On my UI7 test box and test g/w, if I turn off the g/w for whatever reason I find I need to restart luup on Vera to get it to re-establish connection to the g/w.
              So I wonder if it does retry after a period ( which ive never been patient enough for )
              • hekH Offline
                hekH Offline
                I have no idea why it works. As you say.. it probably doesn't retry if this number is larger than 0. I had the same problem with my Alarm system.
                • C Offline
                  C Offline
                  CaptainZap
                  To fix that error someone, needs to update the plugin and include this line:
                  luup.set_failure(false)
                  This way the can't detect message won't be displayed anymore.
                  • hekH Offline
                    hekH Offline
                    Hmm.. the UI7 branch already have this in place:
                    https://github.com/mysensors/Vera/blob/UI7/L_Arduino.lua#L572
                    • TmasterT Offline
                      TmasterT Offline
                      Tmaster
                      wrote on last edited by Tmaster
                      i had the same issue and it was the serial chip was not apropriate and won't comunicate. ch340,fake ftdi... that kinds won't comunicate propely and cause problems. after change to a FTDI chip all works good
                      i'm a arduino fan .Even sometimes don't undestanding how to use it :P
                      • G Offline
                        G Offline
                        gbfromhb
                        Thank you @Tmaster. I put this project away a while ago, and just recently realized after some unrelated reading what the issue must be with this adventure. I'm pretty sure this is what is going on and just have not had the time to get back to it.
                          B Offline
                          B Offline
                          bgriffith87
                          @hek Thank you so much! That solved the problem for me!!! :)
                          • I Offline
                            I Offline
                            itbeyond
                            @hek This fix worked for me today using Plugin 1.5 Version 2.1.1 on UI7 1.7.2607
                            Thanks.
