  3. Soil Moisture analog input question
soil moisture
3 Posts 2 Posters 3.8k Views 1 Watching
  • G
    G
    GRB
    I have created a sketch based on the analog light sensor sketch for a soil moisture sensor. It incorporates voltage monitor because I am using a 9v battery as a source, using Arduino Nano, sensor is connected to 5vdc regulated.This is connected via a serial gateway to vera. I am having trouble with the sketch if I include the analog ref voltage code from the voltage monitoring code, I do not see a change in the analog value from the soil moisture sensor.
    analogReference(INTERNAL);
    I have verified that that the voltage output is changing on the sensor. If I omit this code I am able to see the value of the moisture sensor change, however as the sensor detects more moisture and changes the value in Vera I notice that the battery level indicator changes. I do not have the 0.1uf cap connected from voltage tap to analog input, could this create the issue? I believe since I am not using the 1.1v reference code, I need to recalculate the ADCmax and also V/bit ratio in order to get an accurate percentage battery voltage. How does setting the analog reference impact other analog inputs? At this moment I don't have the sketch with me but will upload it later.
    • epierreE
      epierreE
      epierre
      Have a look here:
      Leaf wetness is close to what you are using for the sensor can do both. Again I recommend the immersion gold for all other will erote too quickly... take good notice of the offline/sleep process to save your battery. I would recommend here a rechargeable LiOn such as CR123...
      https://github.com/empierre/arduino/blob/master/LeafWetnessSensor.ino
      This second one is for a more complex one using a sensirion sensor that mesures groud temp + humidity digitally:
      https://github.com/empierre/arduino/blob/master/SoilMoistSensorSHT1x.ino
      The last I've not finished yet is about gyspum captors someone here has done yet. Since current is not polarized, there is less oxydation, and the captor inside the gypsum avoids humidity contact.
      z-wave - Vera -> Domoticz
      • G
        G
        GRB
        Here is the sketch if anyone can help out.
        #define CHILD_ID_LIGHT 0
        #define LIGHT_SENSOR_ANALOG_PIN 1
        #define NODE_ID 9
        int BATTERY_SENSE_PIN = A2; // select the input pin for the battery sense point
        int lastLightLevel;
        int oldBatteryPcnt = 0;
        //analogReference(INTERNAL);
        gw.begin(NULL, NODE_ID, false);
        gw.sendSketchInfo("Soil_Moist_Sensor_grb", "1.15");
        gw.present(CHILD_ID_LIGHT, S_LIGHT_LEVEL);
        int lightLevel = (1023-analogRead(LIGHT_SENSOR_ANALOG_PIN))/10.23;
        Serial.println(lightLevel);
        gw.send(msg.set(lightLevel));
        lastLightLevel = lightLevel;
        // get the battery Voltage
        Serial.println(sensorValue);
        // 3.44/1023 = Volts per bit = 0.003363075 - changed without ref volt
        float batteryV = sensorValue * 0.00305734;
        Serial.print(batteryV);
        Serial.println(" V");
        Serial.print(batteryPcnt);
        Serial.println(" %");
        // Power up radio after sleep
        oldBatteryPcnt = batteryPcnt;
        gw.sleep(SLEEP_TIME);
