  3. 'MySensoring' a GE Washer
5 Posts 4 Posters 4.6k Views 6 Watching
  • RJ_MakeR
    RJ_MakeR
    RJ_Make
    This is another very simple "Wash Cycle Completed" sensor. It's design uses the same Optocoupler sensing design I used in the Kiddie Smoke Detector project. The only difference is that I'm using 1 AC to DC transformer, and a boost module to boost the washer speaker power to fire the Optocoupler.
    Parts:
    1. 1 Cheap AC/DC converter
    2. 1 Optocoupler
    3. 1 Step up Regulator
    4. 1 Small Proto Board.
    5. Some wire
    Highlights:
    Use the Washers .5vdc Signal Piezo to interface with the Pro-Mini. The voltage to the Piezo is to low to drive the Optocoupler so I had to use a boost module to boost the voltage to the Optocoupler. I'm not sure what the long term effect will be on washers control board Piezo drive circuit, so I will follow up if I encounter a problem.
    Again Uses the same sketch as the Kiddie Smoke Project, with the only change being to CYCLE_INTERVAL (For my dryer 3 works well)
    Sketch:
    // Based on Author: Patrick 'Anticimex' Fallberg Interrupt driven binary switch example with dual interrupts
    #define SKETCH_NAME "Washer End Cycle"
    #define SKETCH_MAJOR_VER "1"
    #define SKETCH_MINOR_VER "1"
    #define CHILD_ID 3
    #define SIREN_SENSE_PIN 3   // Arduino Digital I/O pin for optocoupler for siren
    unsigned int SLEEP_TIME			= 32400; // Sleep time between reads (in seconds) 32400 = 9hrs?
    long CYCLE_COUNTER					= 3;  // This is the number of times we want the Audio Counter to reach before triggering a signal to controller.
    unsigned long CYCLE_INTERVAL		= 3; // How long do we want to watch once first detected (in seconds)
    											//Adjust for your smoke detector, you want to pick up the siren signal at least 3 time to help stop false alarms.
    unsigned long CYCLE_RATE			= 90; // How fast do we want to move checking the Pin state in the Status Check (in Millis) Adjust for your smoke detector
    unsigned long CYCLE_TIME_OKSTATUS	= 8; // How long do we want to watch for "all clear" once we have confirmed an Alarm (in seconds)
    unsigned long CYCLE_RATE_OKSTATUS	= 500; // How fast do we want to move checking the Pin state when checking for an OK status (in Millis)
    int oldValue=1;
    int value=0;
    MySensor sensor_node;
    	sensor_node.begin();
    	// Setup the Siren Pin HIGH
    	pinMode(SIREN_SENSE_PIN, INPUT_PULLUP);
    	sensor_node.sendSketchInfo(SKETCH_NAME, SKETCH_MAJOR_VER"."SKETCH_MINOR_VER);
    	sensor_node.present(CHILD_ID, S_SMOKE);
    	//Send the state -- Always send Alarm state on power up.
    	sensor_node.send(msg.setSensor(CHILD_ID).set("1"), true);
    	// Check to see if we have a alarm. I always want to check even if we are coming out of sleep for heartbeat.
    	AlarmStatus();
    	// Sleep until we get a audio power hit on the optocoupler or 9hrs
    	sensor_node.sleep(SIREN_SENSE_PIN-2,FALLING, SLEEP_TIME * 1000UL);
    void AlarmStatus()
    // We will check the status now, this could be called by an interrupt or heartbeat
    int siren_audio_count	=0;
    long cycle_time			=0;
    unsigned long startedAt = millis();
    	Serial.println("Status Check");
    	//Read the Pin
    	value = digitalRead(SIREN_SENSE_PIN);
        // If Pin return a 0 (LOW), then we have a Alarm Condition
    	if (value != 1) {
    		 //We are only going to check for status for CYCLE_INTERVAL time I think this should help stabilize Siren Sensing
    		  while(millis() - startedAt < CYCLE_INTERVAL * 1000)
    			  //We are going to check CYCLE_RATE fast
    			  if(millis() - cycle_time > CYCLE_RATE ) {
    				  // save the last time you Checked
    				  cycle_time = millis();
    				    //We will count each time SIREN_SENSE_PIN is 0 (Alarm - LOW) for the above time and at the above rate.
    						if (value != 1)
    							siren_audio_count++;
    							Serial.print("Audio Count: ");
    							Serial.println(siren_audio_count);
    				// Eval siren audio hit count against our limit. If we are => then CYCLE_COUNTER then lets start a loop for "All Clear" reset
    				// If we continue to return an audio power hit, then we will continue to send to the controller.
    				if (siren_audio_count>=CYCLE_COUNTER)
    					Serial.println("Alarm Detected");
    					do
    					  //update gateway with bad news.
    					  //sensor_node.send(msg.set("1"));
    					  Serial.println("Alarm Detected Sent to gateway");
    					} while (IsAlarmAllClear()!=1);
    	//Pin returned a 1 (High) so there is no alarm.
    	else
    	  IsAlarmAllClear();
    int IsAlarmAllClear()
    // We are looking for an gap in time that we no longer see an audio power hit to the optocoupler.
     int alarmOn				=0;
     long cycle_time			=0;
    	//We are only going to check for status for CYCLE_TIME_OKSTATUS time
    	while(millis() - startedAt < CYCLE_TIME_OKSTATUS * 1000)
    		//We are going to check CYCLE_RATE_OKSTATUS fast
    		if(millis() - cycle_time > CYCLE_RATE_OKSTATUS) {
    			int value = digitalRead(SIREN_SENSE_PIN);
    			if (value != 1) //We are still in an alarm state
    				alarmOn++;
    			if (alarmOn < 1)
    				// We don't have any sign that we are still in an alarm status
    				//Send all clear msg to controller
    				//sensor_node.send(msg.set("0"));
    				sensor_node.send(msg.setSensor(CHILD_ID).set("0"), true);
    				// Used to update the node - NOT used for battery check.
    				sensor_node.sendBatteryLevel(random(1, 100) );
    				Serial.println("All Clear");
    				return 1;
    			else
    				// We are still in an alarm status
    				//The calling function will handle sending NOT CLEAR to controller
    				Serial.println("NOT CLEAR");
    				return 0;
    Here a some Pictures:
    RJ_Make
      You've been busy this weekend ;)
      RJ_MakeR 1 Reply Last reply
        RJ_MakeR
        RJ_MakeR
        RJ_Make
        @hek More like a busy week.. :sweat:
        RJ_Make
        • A
          A
          arcidodo
          Thanks! i updated it to version 2.0 but it's working perfectly
          //#define MY_REPEATER_FEATURE
          #define MY_NODE_ID 17
          #define CHILD_ID 1
          int oldValue=1;
          int value=0;
          //MySensors sensor_node;
            sendSketchInfo("Washer End Cycle", "1.1");
            AlarmStatus();
          void AlarmStatus()
          long cycle_time     =0;
            //Read the Pin
            if (value != 1) {
                      if (value != 1)
                    do
            else
              IsAlarmAllClear();
           int alarmOn        =0;
           long cycle_time      =0;
                  alarmOn++;
                if (alarmOn < 1)
                  return 1;
                else
                  return 0;
          • TmasterT
            TmasterT
            Tmaster
            wrote on last edited by Tmaster
            why not connect the buzzer signal direct to arduino analog read? optocoupter for a 80cents arduino?
            i'm a arduino fan .Even sometimes don't undestanding how to use it :P
