  3. multiple DS18D20 does not report temperature
27 Posts 4 Posters 13.4k Views 2 Watching
  • Tomasz PazioT Offline
    Tomasz Pazio
    Hi all.
    I'm new so do nos scream too much ;-)
    I have working Gateway with Vera system, I would like to replace my current setup with OneWire network with 9 in line sensors connected to openwrt router.
    I used sketch from http://www.mysensors.org/build/temp with Nano but used two sensors (for now), For one sensor it was working fine, when added second, readings are gone from Vera.
    Setup looks correct because when uploading sketch from arduino libraty serial monitor shows two sensors with temperatures.
    Could You lease help?
    • hekH Offline
      hekH Offline
      Make sure both temp sensors has been created on Vera by starting inclusion mode on vera and restart the node a few times (5 seconds apart).
      Reload GUI on vera.
      Check debug log on sensor that communication is working.
        Tomasz Pazio
        made all accept debug log.
        unfortunately fail, next thing, last update time change only after re-plug arduino, it is not changing recurrently every 30000ms
          Tomasz Pazio
          and log
          sensor started, id 3
          send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=5,st=ok:1.4.1
          send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,st=ok:0
          read: 0-0-3 s=255,c=3,t=6,pt=0,l=1:M
          send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=18,st=ok:Temperature Sensor
          send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,st=ok:1.0
          send: 3-3-0-0 s=0,c=0,t=6,pt=0,l=5,st=ok:1.4.1
          send: 3-3-0-0 s=1,c=0,t=6,pt=0,l=5,st=ok:1.4.1
            Tomasz Pazio
            Today after vera update I do not have any readings from temp.sensors on onewire eaven one...
            when using "generic " example for arduino all sensors are reported.
            Something wrong with this example :(
            • hekH Offline
              hekH Offline
              From the log above it looks like at least 2 temp-sensors were found (and presented) to your controller.
                Tomasz Pazio
                so something wrong with presenting readings :( what to check on vera side?
                • hekH Offline
                  hekH Offline
                  If you continue monitoring the nodes log. Does it send anything after the log you posted above?
                    Tomasz Pazio
                    no, only this one, and nothing else.
                    • hekH Offline
                      hekH Offline
                      That seems wrong.
                      What if you update the libraries and sketch to latest on github. There was an update to the Onewire/Dallas library recently to make in none-blocking...
                        Tomasz Pazio
                        log is now different
                        send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
                        send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                        read: 0-0-3 s=255,c=3,t=6,pt=0,l=1,sg=0:M
                        sensor started, id=3, parent=0, distance=1
                        send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=18,sg=0,st=ok:Temperature Sensor
                        send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.1
                        send: 3-3-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                        send: 3-3-0-0 s=1,c=0,t=6,pt=0,l=0,sg=0,st=ok:
                        but still no readings on vera :(
                        • hekH Offline
                          hekH Offline
                          I cannot see any temp readings in the debug log...
                          Are you powering your 9 Dallas sensors directly from the Arduino or separately? I'm not sure how much they draw but 9 is quite much...
                            Tomasz Pazio
                            Now trying with one and two. No more.
                              Tomasz Pazio
                              There are two parts of issue:
                              problem with no data on vera was on this part:
                              #if COMPARE_TEMP == 1
                              #else
                              my reading is now -127.00
                              changed to -200 and now I can see the data on vera.
                              however this is not correct data because should be something like 27 Celsius.
                              so there is something with conversion as well :(
                              • hekH Offline
                                hekH Offline
                                -127 means something is wrong when reading your dallas sensors. It is a an error code. So you actually only have an issue with your temp sensors.
                                  Tomasz Pazio
                                  when I use Example for Dallas multiple sensors it works fine.
                                  when I use example for one-wire temperature sensor ds18.... it works fine as well
                                  so i can reed but can not use Mysensors sketch :(
                                  • hekH Offline
                                    hekH Offline
                                    Very strange. Are you using the same OneWire library in both cases?
                                      Tomasz Pazio
                                      yes the same.
                                        Tomasz Pazio
                                        any idea?
                                        • hekH Offline
                                          hekH Offline
                                          No, must be hundreds of users running Dallas sensors here. Trying to figure out if anything has changed in the library/dependencies but I don't see anything except the thing I mentioned earlier here.
                                          And you can get the sensor running without MySensors library loaded...
                                          Guess I have to hook up a Dallas sensor myself to check (tomorrow or so..)
