Hi @edoardoo
I actually stumbled on your post a couple of weeks ago! Great writeup!
We certainly need contributors. We need help with everything from the visualisation of sensordata in the frontend (considering using d3.js) to mqtt/node.js backend for receiving and processing sensor data.
Please contact me or Johan for further discussions.
Hi @Prohi, can you provide more information about your heating system?
When searching about AirMax on the internet, I found this: https://www.airmaxhvac.com/ and this https://airmaxsc.com/ and this https://airmaxop.com/ and ...
Is your heating system an hvac based system?
With remote controls for each room?
@monte said in Best choise for a controller:
@neverdie but isn't Docker more efficient and simple solution compared to a VM? Considering it will be used for single process anyway.
Yes, I think you're right.
Hi dzairo,
Just wondering if you still monitor this thread. If so would love to know how to install the ComPort component so I can modify and use your terminal code. For some reason I don't have any luck with adding it to the IDE.
thanks, Andy.
