Strange Node, only Present message
  • Hi,
    i have a node with NodeID in code. But in the last time i get only the presence message, after that nothing. What are happend here and how can i fix this?
    Log from Pimatic:
    <- I_LOG_MESSAGE  0;0;3;0;9;gateway started, id=0, parent=0, distance=0
    <- I_LOG_MESSAGE  0;0;3;0;9;read: 25-25-0 s=255,c=0,t=17,pt=0,l=3,sg=0:1.5
    <- Presented Node  [ '25', '255', '0', '0', '17', '1.5' ]
    Thanks for your help!
  • Admin
    Which sketch are you using?
  • I'ts a normal Lux sensor from my video lessions about Arduino save Power topic: https://www.youtube.com/playlist?list=PLYPTUTcLMTK4X3rSrr3FChxNeVwrH1Kmh
    I guess the problem are not enough power, the node send some data and the power go down, then fall in reset and after some seconds the battery go up and the node try to send again and so forth.
    At the weekend i'll test this with a new battery 🙂
11.3k
