  3. Domoticz
  4. Domotiocz + Rain gauge
61 Posts 12 Posters 35.6k Views 12 Watching
  • sundberg84S Offline
    sundberg84S Offline
    Hi!
    Has anyone a sketch with a tipping bucket posting to domoticz?
    I have tried MySensors tippingbucket and also Water pulse meter sketch but cant figure it out...
    Thanx
    Andreas
      sundberg84S Offline
      This is my rainsensor/tipping bucket for MySensors that works with Domoticz.
      It uses 2xAA as power source, a Pro Mini 3.3v with a 0.9 to 3.3 booster.
      The bucket has a magnet which triggeras a reed switch which triggers an interrupt pin.
      I also use battery sensing with voltage divider.
      #define MY_NODE_ID 7
      // Running this in Domoticz stable version 2.5 will not work - upgrade to beta.
      #define DIGITAL_INPUT_SENSOR 3                  // The reed switch you attached.  (Only 2 and 3 generates interrupt!)
      #define INTERRUPT DIGITAL_INPUT_SENSOR-2        // Usually the interrupt = pin -2 (on uno/nano anyway)
      #define CHILD_ID 1                              // Id of the sensor child
      #define SKETCH_NAME "Rain Gauge"                // Change to a fancy name you like
      #define SKETCH_VERSION "1.1"                    // Your version
      unsigned long SLEEP_TIME = 18*60000;            // Sleep time (in milliseconds).
      //unsigned long SLEEP_TIME = 20000;             // use this instead for debug
      float hwRainVolume = 0;                         // Current rainvolume calculated in hardware.
      int hwPulseCounter = 0;                         // Pulsecount recieved from GW
      float fullCounter = 0;                           // Counts when to send counter
      float bucketSize = 0.5;                           // Bucketsize mm, needs to be 1, 0.5, 0.25, 0.2 or 0.1
      boolean pcReceived = false;                     // If we have recieved the pulscount from GW or not
      boolean reedState;                              // Current state the reedswitch is in
      boolean oldReedState;                           // Old state (last state) of the reedswitch
      unsigned long lastSend =0;                      // Time we last tried to fetch counter.
      MyMessage volumeMsg(CHILD_ID,V_RAIN);
      MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
      // BATTERY VOLTAGE DIVIDER SETUP
      #define VBAT_PER_BITS 0.003363075
      #define VMIN 1.9                                  //  Vmin (radio Min Volt)=1.9V (564v)
      #define VMAX 3.0                                  //  Vmax = (2xAA bat)=3.0V (892v)
      int batteryPcnt = 0;                              // Calc value for battery %
      int batLoop = 0;                                  // Loop to help calc average
      int batArray[3];                                  // Array to store value for average calc.
      int BATTERY_SENSE_PIN = A0;                       // select the input pin for the battery sense point
      void presentation() {
        // Register this device as Rain sensor (will not show in Domoticz until first value arrives)
        present(CHILD_ID, S_RAIN);
        analogReference(INTERNAL);             // For battery sensing
        pinMode(DIGITAL_INPUT_SENSOR, INPUT_PULLUP);  // sets the reed sensor digital pin as input
        reedState = digitalRead(DIGITAL_INPUT_SENSOR); // Read what state the reedswitch is in
        oldReedState = reedState; // Set startup position for reedswitch
        Serial.println("Startup completed");
      unsigned long currentTime = millis();
          //See if we have the counter/pulse from Domoticz - and ask for it if we dont.
          if (!pcReceived && (currentTime - lastSend > 5000)) {
            request(CHILD_ID, V_VAR1);
            lastSend=currentTime;
            return;
          if (!pcReceived) {
            return;
      //Read if the bucket tipped over
      boolean tipped = oldReedState != reedState;
          //BUCKET TIPS!
          if (tipped==true) {
          Serial.println("The bucket has tipped over...");
          hwRainVolume = hwRainVolume + bucketSize;
          send(volumeMsg.set((float)hwRainVolume,1));
          wait(1000);
          fullCounter = fullCounter + bucketSize;
            //Count so we send the counter for every 1mm
            if(fullCounter >= 1){
            hwPulseCounter++;
            send(lastCounterMsg.set(hwPulseCounter));
            wait(1000);
            fullCounter = 0;
          if (tipped==false) {
           //No bucket tipped over last sleep-period, check battery then...
           batM();
      sleep(INTERRUPT, CHANGE, SLEEP_TIME);
      //The interupt can be CHANGE or FALLING depending on how you wired the hardware.
      //Read if we have a incoming message.
      void receive(const MyMessage &msg) {
          if (msg.type==V_VAR1) {
          hwPulseCounter = msg.getULong();
          hwRainVolume = hwPulseCounter;
          pcReceived = true;
          Serial.print("Received last pulse count from gw: ");
          Serial.println(hwPulseCounter);
      void batM(){  //The battery calculations
         delay(500);
         // Battery monitoring reading
         delay(500);
         // Calculate the battery in %
         float Vbat  = sensorValue * VBAT_PER_BITS;
         int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
         Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
         // Add it to array so we get an average of 3 (3x20min)
         batArray[batLoop] = batteryPcnt;
         if (batLoop > 1) {
           batteryPcnt = (batArray[0] + batArray[1] + batArray[2]);
           batteryPcnt = batteryPcnt / 3;
         if (batteryPcnt > 100) {
           batteryPcnt=100;
           Serial.print("Battery Average (Send): "); Serial.print(batteryPcnt); Serial.println(" %");
             batLoop = 0;
           //Sends 1 per hour as a heartbeat.
           else
           batLoop++;
      M 1 Reply Last reply
        sundberg84S Offline
        This is great!
        1 year - times fly by, but my rainsensor is going strong!
        I just wanted to celebrate 1 year for my Rainsensor on batteries, reporting every hour (or less when it rains). Still going strong and 81% battery left! Except for some range issues in the beginning you can see its working as it should:
        Also It will be my (almost) 1000th post so thank you all for making MySensors such a great community. I just love every minute here!
        mrwombleM F 2 Replies Last reply
        • sundberg84S sundberg84
          This is great!
          mrwombleM Offline
          mrwombleM Offline
          mrwomble
          @sundberg84 Wow, that is impressive! What type of batteries are you using?
          I'm waiting for parts to come in to start building some battery powered and external sensors.
          • mrwombleM mrwomble
            sundberg84S Offline
            sundberg84S Offline
            @mrwomble - 2xAA
            • Q Offline
              Q Offline
              Qu3Uk
              Thats impressive, out of interest are you doing anything with this data in domotiocz?
              • Q Qu3Uk
                sundberg84S Offline
                sundberg84S Offline
                @Qu3Uk nope, just monitoring. I could probably use it for watering if I made some actuators... but not that garden interested.
                • sinczeS Offline
                  sinczeS Offline
                  sincze
                  MySensors Evangelist
                  @sundberg84 , very nice. I would say.. I want that as well ;-)
                  any suggestions for a shopping and modification list?
                  As I don't have a 3D printer to print the thing myself.
                  sundberg84S TheoLT 2 Replies Last reply
                  • sinczeS sincze
                    sundberg84S Offline
                    sundberg84S Offline
                    @sincze - its not a 3d printed box, its an old 433mhz tip sensor.
                    There is something similar on mysensors shop :http://www.ebay.com/itm/misol-Spare-part-for-weather-station-to-measure-the-rain-volume-for-rain-meter-/271862662076?hash=item3f4c4703bc:g:IGsAAOSwq7JT8vJY&rmvSB=true
                    TheoLT 1 Reply Last reply
                      TheoLT Offline
                      TheoLT Offline
                      TheoL
                      @sundberg84 Just playing with your sketch, because it's easier for my to understand than the one one the build page. I'm curious about how domoticz handles these values. I don't see you reset the hwRainVolume variable. So does this mean that this is an ever increasing value that must be send to Domoticz?
                      • TheoLT TheoL
                        sundberg84S Offline
                        sundberg84S Offline
                        @TheoL - Correct.
                        There is a countervalue and Domoticz calculates the value from midnight each night.
                          @TheoL - Correct.
                          TheoLT Offline
                          TheoLT Offline
                          TheoL
                          @sundberg84 Thanx for your fast reply. So what happens when the float resets to 0?
                          • sinczeS sincze
                            TheoLT Offline
                            TheoLT Offline
                            TheoL
                            @sincze Hello my friend, just curious how many sensors you've got hooked up at the moment?
                            • TheoLT TheoL
                              sundberg84S Offline
                              sundberg84S Offline
                              @TheoL - Just to add what we discussed in chat for future questions - If float would hit the maximum value (which is hugh so lets hope its not a problem) im not sure what will happen...
                                TheoLT Offline
                                TheoLT Offline
                                TheoL
                                @sundberg84 It's also not a concern of the MySensors node. This should be handled by Domoticz. I really like your sketch, it works like a charm. I modified it to my needs so that I can run the node without the sleep. Still need to think of an hourly heart beat. But almost there.
                                • TheoLT TheoL
                                  sundberg84S Offline
                                  sundberg84S Offline
                                  @TheoL - If you modify the sketch with a heartbeat() please post it :) Im interested as well!
                                  • TheoLT Offline
                                    TheoLT Offline
                                    TheoL
                                    @AWI do you happen to know if the pulse counter in Domoticz is a 1mm pulse counter? Or is it a real tip pulse counter? Right know where checking whenever the rain fall exceeds 1mm and send a pulse ++ in that case. Meaning we miss some pulse counts when we reset the node.
                                    AWIA 1 Reply Last reply
                                    • TheoLT TheoL
                                      AWIA Offline
                                      AWIA Offline
                                      AWI
                                      @TheoL My rain meter counts in 1 mm resolution but I am sending actual total (in mm) from the start of sensor and keep totals in EEPROM.
                                      • AWIA AWI
                                        TheoLT Offline
                                        TheoLT Offline
                                        TheoL
                                        @AWI (Glad that your back, hope you're doing allright) So, if I understand your setup correctly you don't send the pulse count to Domoticz? I kind of like it, because that way I can reset the rain sensor many times and still keep the rain fall log in sync, without using the EPROM.
                                        And my rain sensor did reset a couple of times. I had to put a diode (Dutch name is blus diode) between the two wires coming out from the rain gauge to prevent this.
                                        • TheoLT TheoL
                                          AWIA Offline
                                          AWIA Offline
                                          AWI
                                          @TheoL (i'm fine, thank you) That is what i'm doing. The only thing what I need to do after a reset is delete the miscalculation in Domoticz (easy). My sensor (oregon) uses a 'reed' switch (no induction). I MySensoriz'ed it without losing the original circuitry and function. (so in parallel).
                                          0_1475422212074_upload-82d166bf-a999-4d76-b3e3-8c010fa5f427
                                          11.9k
                                          113.3k
