  3. Local sensor (no radio)
6 Posts 4 Posters 4.4k Views 4 Watching
  • S Offline
    shabba
    I have a RPi 2 controller connected to a uno that has the radio (serial GW). I also have a arduino mega that controls all my heating zones in the house (11). Right now the mega is just spewing out debug on the serial port but I would love to connect it to the RPi and integrate it into my mysensors network. Is there any libraries for doing this or has anyone done similar? I don't want to add a radio to the mega as it is sitting right beside the controller.
    Thanks!
    • T Offline
      T Offline
      tbowmo
      @shabba
      Depending on how curious you are, and how advanced a setup you want, You could make a mockup that emulates the serialport protocol, it should be pretty easy to do. Or you could make a nodered flow, that picks up data from your mega, and remaps it to mysensor protocol, and then inject that into the data stream in to you controller of choice.
      • S Offline
        shabba
        Yeah - I guess I was hoping someone else had pioneered it :-)
        It is interesting though. I'll try and send the wife and kids away for a week!
        • H Offline
          H Offline
          wrote on last edited by hek
          You should have a look at the "gateway-refactoring" branch. Over there it is possible to create a node without radio.
          A serially attached gateway motion sensor would look like this:
          // Enable serial gateway
          #define MY_GATEWAY_SERIAL
          #define CHILD_ID 1
            sendSketchInfo("Motion Sensor", "1.0");
            pinMode(DIGITAL_INPUT_SENSOR, INPUT);
            present(CHILD_ID, S_MOTION);
            send(msg.set(tripped?"1":"0"));  // Send tripped value to gw
            sleep(INTERRUPT,CHANGE, SLEEP_TIME);
          M 1 Reply Last reply
          • H hek
            #define CHILD_ID 1
            M Offline
            M Offline
            MarkV
            @hek
            And what or how do you register this sensor in domoticz?
            • H Offline
              H Offline
              Sorry, haven't used Domoticz myself.
              12.2k
