  3. Vera
  4. Arm / by-pass message not broadcast-ed to MySensor module
4 Posts 2 Posters 2.3k Views 1 Watching
  • BartEB
    BartEB
    BartE
    I was busy creating a security type of sensor which i needed to set in the arm and by-pass mode.
    However Vera showed the correct status (arm/by-pass) the sensor was not aware that it was by-passed.
    Looking trough the Vera: I_Arduino.lua code i did figure out the setArmed on caused a local variable update.
    Bij adding a sendCommand function call my mysensor gets an update on setArmed. This is the new code (MySensors version 1.4.1):
    -- Security commands
    function setArmed(device, newArmedValue)
       -- Line added by BartE
    	sendCommand(luup.devices[device].id,"ARMED",newArmedValue)
       -- Add ends
    	setVariableIfChanged(tVarTypes.ARMED[2], tVarTypes.ARMED[3], newArmedValue, device)
    end
    In a sketch running on an Arduino one can handle the setArmed like this
        if (message.type==V_ARMED) {
               bArmed = message.getBool();
               // Do something wise with the global bArmed boolean
      You might very well be the first one using the ARMED command. :)
      See my previous comment about creating a pull request for this change so others can use it as well.
      • BartEB
        BartEB
        BartE
        Nice :) I did make both pull requests
          Both merged! Thanks.
