  3. Hard to grab time and value sent from controller
20 Posts 3 Posters 7.5k Views 2 Watching
  • sundberg84S Offline
    sundberg84S Offline
    Hi!
    Im making a sketch where i ask for time and counter from the controller:
          gw.request(CHILD_ID, V_VAR1);
          Serial.println("Request pulsecount");
          gw.wait(3000);
          lastSend=currentTime;
          gw.process();
      if (message.type==V_VAR1) {
        hwPulseCounter = message.getULong();```
    What happens is that my sensor cant grab/get the answer sent out from the controller:
    send: 7-7-0-0 s=255,c=3,t=1,pt=0,l=0,sg=0,st=ok:
    sometimes it gets it right away, but sometimes it takes 50 sends before i get the recieve.
    I see in MYSController that its somewhere between the GW and the sensor. The controller is trying to send time and counter all of the times.
    Any ideas?
      sundberg84S Offline
      Anyone? (Sorry for bumping - but its really annoying!)
      • hekH Offline
        hekH Offline
        You didn't publish the full sketch.. Can't see any time request/pickup code above.
          sundberg84S Offline
          Its a rain / tip bucket sensor. I made it since the original sketch didnt work with domoticz, but thats another problem... well the code.
          #include <Time.h>
          // Running this in Domoticz stable version 2.5 will not work - upgrade to beta.
          #define DIGITAL_INPUT_SENSOR 3                  // The reed switch you attached.  (Only 2 and 3 generates interrupt!)
          #define INTERRUPT DIGITAL_INPUT_SENSOR-2        // Usually the interrupt = pin -2 (on uno/nano anyway)
          #define CHILD_ID 1                              // Id of the sensor child
          #define NODE_ID 7                               // or AUTO to let controller assign
          #define SKETCH_NAME "Rain Gauge"                // Change to a fancy name you like
          #define SKETCH_VERSION "1.7"                    // Your version
          unsigned long SLEEP_TIME = 18*60000;            // Sleep time (in milliseconds).
          //unsigned long SLEEP_TIME = 20000;             // use this instead for debug
          float hwRainVolume = 0;                         // Current rainvolume calculated in hardware.
          int hwPulseCounter = 0;                         // Pulsecount recieved from GW
          float fullCounter = 0;                           // Counts when to send counter
          float bucketSize = 0.5;                           // Bucketsize mm, needs to be 1, 0.5, 0.25, 0.2 or 0.1
          boolean pcReceived = false;                     // If we have recieved the pulscount from GW or not
          boolean reedState;                              // Current state the reedswitch is in
          boolean oldReedState;                           // Old state (last state) of the reedswitch
          unsigned long lastSend =0;                      // Time we last tried to fetch counter.
          byte lastHour;                                  // To know if we have a new hour and new day in this reading.
          byte currentHour = 0;                           // Value to store the current hour
          int maxTips = 0;                                // Int to avoid block time update due to heavy rain
          MyMessage volumeMsg(CHILD_ID,V_RAIN);
          MyMessage lastCounterMsg(CHILD_ID,V_VAR1);
          // BATTERY VOLTAGE DIVIDER SETUP
          #define VBAT_PER_BITS 0.003363075
          #define VMIN 1.9                                  //  Vmin (radio Min Volt)=1.9V (564v)
          #define VMAX 3.0                                  //  Vmax = (2xAA bat)=3.0V (892v)
          int batteryPcnt = 0;                              // Calc value for battery %
          int batLoop = 0;                                  // Loop to help calc average
          int batArray[3];                                  // Array to store value for average calc.
          int BATTERY_SENSE_PIN = A0;                       // select the input pin for the battery sense point
            analogReference(INTERNAL);             // For battery sensing
            pinMode(DIGITAL_INPUT_SENSOR, INPUT);  // sets the reed sensor digital pin as input
            reedState = digitalRead(DIGITAL_INPUT_SENSOR); // Read what state the reedswitch is in
            oldReedState = reedState; // Set startup position for reedswitch
            delay(500); // Allow time for radio if power used as reset
            //Begin (Change if you dont want static node_id! (NODE_ID to AUTO)
            gw.begin(incomingMessage, NODE_ID, false, 0);
            gw.sendSketchInfo(SKETCH_NAME, SKETCH_VERSION);
            // Register this device as Rain sensor (will not show in Domoticz until first value arrives)
            gw.present(CHILD_ID, S_RAIN);
            // Get time from controller
            getNewTime();
            Serial.print("Startup - Current hour: "); Serial.println(currentHour);
            Serial.println("Startup completed");
          gw.process();
          unsigned long currentTime = millis();
              //See if we have the counter/pulse from Domoticz - and ask for it if we dont.
              if (!pcReceived && (currentTime - lastSend > 2500)) {
                gw.process();
                gw.wait(3000);
                gw.process();
                return;
              if (!pcReceived) {
                return;
          //Read if the bucket tipped over
          boolean tipped = oldReedState != reedState;
              //BUCKET TIPS!
              if (tipped==true) {
              Serial.println("The bucket has tipped over...");
              hwRainVolume = hwRainVolume + bucketSize;
              gw.send(volumeMsg.set((float)hwRainVolume,1));
              gw.wait(1000);
              fullCounter = fullCounter + bucketSize;
              maxTips++;
              Serial.println(bucketSize);
              Serial.println(fullCounter);
                //Count so we send the counter for every 1mm
                if(fullCounter >= 1){
                hwPulseCounter++;
                gw.send(lastCounterMsg.set(hwPulseCounter));
                gw.wait(1000);
                fullCounter = 0;
                  //If heavy rain, update time every X bucket tip
                   if (maxTips >= 6)
                   currentHour = 25;
                   getNewTime();
                   maxTips = 0;
              if (tipped==false) {
               //No bucket tipped over last sleep-period, check battery and ask the time then...
               batM();
               currentHour = 25;
               getNewTime();
          gw.sleep(INTERRUPT, CHANGE, SLEEP_TIME);
          //The interupt can be CHANGE or FALLING depending on how you wired the hardware.
          //Read if we have a incoming message.
              pcReceived = true;
              Serial.print("Received last pulse count from gw: ");
              Serial.println(hwPulseCounter);
          //Get the time from controller.
          void getNewTime() {
            gw.process();
            while (currentHour == 25)
              gw.process();
              gw.requestTime(receiveTime);
              Serial.println("Getting Time");
              gw.wait(3000); // call once per second
              gw.process();
             while (timeStatus() == timeNotSet)
              gw.process();
              Serial.println("Getting Time @ Startup");
              gw.process();
            if (currentHour == 0 && lastHour == 23)
              { //means currentHour = 0 and lasthour = 23
              Serial.println("New day!");
              hwRainVolume = 0; //New day
            lastHour = currentHour;
          void batM() //The battery calculations
             delay(500);
             // Battery monitoring reading
             delay(500);
             // Calculate the battery in %
             float Vbat  = sensorValue * VBAT_PER_BITS;
             int batteryPcnt = static_cast<int>(((Vbat-VMIN)/(VMAX-VMIN))*100.);
             Serial.print("Battery percent: "); Serial.print(batteryPcnt); Serial.println(" %");
             // Add it to array so we get an average of 3 (3x20min)
             batArray[batLoop] = batteryPcnt;
             if (batLoop > 1) {
               batteryPcnt = (batArray[0] + batArray[1] + batArray[2]);
               batteryPcnt = batteryPcnt / 3;
             if (batteryPcnt > 100) {
               batteryPcnt=100;
               Serial.print("Battery Average (Send): "); Serial.print(batteryPcnt); Serial.println(" %");
                 batLoop = 0;
               //Sends 1 per hour
               else
               batLoop++;
          //Read if we have a incoming time reading - set this if so.
          void receiveTime(unsigned long time)
          setTime(time);
          char theTime[6];
          currentHour = hour();
          Serial.print("Time received: ");Serial.println(hour());
          maxTips = 0;
          If you can find why it sometimes takes 1 shot and sometimes 50 shots before recieving the time and counter it would be great.
          • hekH Offline
            hekH Offline
            What's up with this? Does it even compile?
              sundberg84S Offline
              Hi!
              Yea - compiles with no problems.
              This part is "stolen" from the original raingauge sketch and not something im used to working with.
              timeNotSet is a variable in time.h
              How would you code this?
              • Ask for time/counter
              • Check if recieved
              • If not recieved - ask again
              • hekH Offline
                hekH Offline
                Have you looked at the TimeAwareSensor example?
                  sundberg84S Offline
                  Yea I did, and I dont see any difference from mine.
                  The thing is that I sleep my Sensor so i need a loop inside the void loop() to check if I recieved the time.
                  Maybe its hardware or the position of the sensor... ill try to relocate and load the sketch to another build
                  TheoLT 1 Reply Last reply
                  • sundberg84S sundberg84
                    TheoLT Offline
                    TheoLT Offline
                    TheoL
                    @sundberg84 I haven't looked at your code, but do you put the Arduino to sleep after you've received the time or after you made the timeRequest to the controller? I'm not sure, but if you do the latter that might be your problem. I'm guessing that the Node is not able to receive messages from the gateway, when it's in sleep mode.
                      sundberg84S Offline
                      Hi.
                      No i recieve the time, check if its a new day and then sleep the node.
                      This is done every sleep cycle (20min),. (Im aware about the failure margin here).
                      I do not sleep the sensor until i got the new time so that should not be a problem.
                        sundberg84S Offline
                        Looking at MysController i get this when i get into the bad loop:
                        2015-10-16 16:27:20	INFO	Reply time request
                        2015-10-16 16:27:20	TX	7;255;3;0;1;1445012841
                        2015-10-16 16:27:20	RX	7;255;3;0;1;
                        2015-10-16 16:27:24	INFO	Reply time request
                        2015-10-16 16:27:24	TX	7;255;3;0;1;1445012844
                        2015-10-16 16:27:24	RX	7;255;3;0;1;
                        2015-10-16 16:27:28	INFO	Reply time request
                        2015-10-16 16:27:28	TX	7;255;3;0;1;1445012848
                        2015-10-16 16:27:28	RX	7;255;3;0;1;
                        2015-10-16 16:27:28	RX	5;0;1;0;4;1020
                        2015-10-16 16:27:31	INFO	Reply time request
                        2015-10-16 16:27:31	TX	7;255;3;0;1;1445012852
                        2015-10-16 16:27:31	RX	7;255;3;0;1;
                        2015-10-16 16:27:35	INFO	Reply time request
                        2015-10-16 16:27:35	TX	7;255;3;0;1;1445012855
                        2015-10-16 16:27:35	RX	7;255;3;0;1;
                        2015-10-16 16:27:38	INFO	Reply time request
                        2015-10-16 16:27:38	TX	7;255;3;0;1;1445012859
                        2015-10-16 16:27:38	RX	7;255;3;0;1;
                        @hek
                        Its like its working one way (Sensor -> Repteter -> Controller) but not the other way around. Is it not using the repeater and thats why the request with time is not getting back?
                          sundberg84S Offline
                          Or its a bad NRF batch i got... AGAIN :(
                          Notised its a new batch im on... have to try some other nrf in that patch. Works one way though...
                          • hekH Offline
                            hekH Offline
                            Also make sure you're running the latest in master branch on gw/repeater. There was a bug there earlier affecting outgoing messages through repeaters.
                              sundberg84S Offline
                              I run 1.4 gw and updated repeaters after bug was reporter (bad routing causing à loop). Its à bit job to update gw to 1.5. Do you think it can make any difference @hek ?
                              • hekH Offline
                                hekH Offline
                                I doubt it would change anything. It's the intermittent failure behaviour that is weird.
                                  sundberg84S Offline
                                  I have ordered new nrf radios. Let's hope the makey the difference.
                                    sundberg84S Offline
                                    New radio, pro mini and still the same problems :(
                                    I cant get it.
                                    Looking at the gw leds the recieve led blinks when the node sends out the request. 1 second later the controller and gw responds accoring to MYSController and i see the transmit and error led blink.
                                    i have the node right beside the gw now and no repeaters.
                                    Any clues, anyone???
                                    • hekH Offline
                                      hekH Offline
                                      wrote on last edited by hek
                                      And how does the node log look like?
                                      Did you upgrade to 1.5?
                                        sundberg84S Offline
                                        No i did not upgrade the gw since i had so much problems with the connections...
                                        Nod serial as before:
                                        (From startup)
                                        send: 7-7-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
                                        send: 7-7-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
                                        sensor started, id=7, parent=0, distance=1
                                        send: 7-7-0-0 s=255,c=3,t=11,pt=0,l=10,sg=0,st=ok:Rain Gauge
                                        send: 7-7-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.7
                                        send: 7-7-0-0 s=1,c=0,t=10,pt=0,l=0,sg=0,st=ok:
                                        Startup completed
                                        send: 7-7-0-0 s=1,c=2,t=24,pt=0,l=0,sg=0,st=ok:
                                        Request pulsecount
                                        Request pulsecount
                                        Request pulsecount
                                        read: 0-0-7 s=1,c=2,t=24,pt=0,l=2,sg=0:52
                                        Received last pulse count from gw: 52
                                        Getting Time
                                        Getting Time
                                        read: 0-0-7 s=255,c=3,t=1,pt=0,l=10,sg=0:1446829805
                                        Time received: 17
                                        • hekH Offline
                                          hekH Offline
                                          DI you have a similar serial log for the gateway? Think you should try to upgrade to be aligned with 1.5. Don't remember what problems you had earlier...
