  3. Can not reply on the forum or Locked
forumfirefox
9 Posts 3 Posters 4.1k Views 1 Watching
  • D Offline
    daulagari
    I tried to post something on the forum from my Linux machine using Firefox or Konqueror but that is not working out.
    • In Firefox 30 I can type a reply and press submit but nothing happens and no reply is added. Same problem trying Firefox and WinXP.
    • In Konqueror I see an orange line above all threads saying "This thread has been deleted. Only users with thread management privileges can see it." is displayed but I can still see the thread although every items is Locked (Blue box)
    Eventually installed Chromium and that works but ... I am the only one having problem access the forum using Firefox?
    • M Offline
      M Offline
      marceltrapman
      When you see this reply it means I was able to submit it (Firefox on Mac though and used only for this test).
      Fulltime Servoy Developer
      • D Offline
        daulagari
        Still using Chromium I enable "Live HTTP header" while trying using Firefox and I see:
        http://forum.mysensors.org/socket.io/1/?t=1405886010035
        GET /socket.io/1/?t=1405886010035 HTTP/1.1
        Host: forum.mysensors.org
        User-Agent: Mozilla/5.0 (X11; Linux i686; rv:30.0) Gecko/20100101 Firefox/30.0
        Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
        Accept-Language: en-US,en;q=0.5
        Accept-Encoding: gzip, deflate
        Cookie: express.sid=s%3AomLCnc8o2jWjEhxQxplyLt9HFWZwqLOR.5R8%2B4xVScOLLt2D9cAs2BVn%2Bspl3kIGOIop1Ie5sr1U; _ga=GA1.2.1667585123.1404853555
        Connection: keep-alive
        HTTP/1.1 502 Bad Gateway
        Server: nginx/1.4.1 (Ubuntu)
        Date: Sun, 20 Jul 2014 19:53:30 GMT
        Content-Type: text/html
        Content-Length: 181
        I think this has to do with the problems but do not know what to conclude based on it.
        • hekH Online
          hekH Online
          The forum is utilizing websockets. Is your webbroswer complient? If not it should fallback to plain ajax (or long pull dito).
          • hekH Online
            hekH Online
            Hmm.. Searching around for similar issues I found:
            http://stackoverflow.com/questions/3704626/nginx-502-bad-gateway-error-only-in-firefox
            But the ngnix log does not show any "upstream sent too big header while...".
            Instead I see a lot of "upstream prematurely closed connection while reading response header from upstream" in the log. Which leads to believe it has something to do with:
            https://github.com/NodeBB/NodeBB/issues/692
            But this seem to be an issue in all browsers.
            I might try increasing ngnix cookie buffers anyway like suggesten in first link later. I'll contact you @daulagari again when it has been done.
            • hekH Online
              hekH Online
              Buffers has been increased. Could you test with your firefox again?
              • D Offline
                daulagari
                Tried once more with Firefox but same behavior as before:
                • I press Reply and the normal editor pops up in the bottom of the screen
                • Type the message left and the preview right looks fine
                • Press Submit and in the top of the screen a turning progress circle is displayed for five seconds and after that it changes into a V
                • But the editor window in the bottom remains open and no message posted
                Made a capture using Wireshark and see quite some 502 Bad Gateway coming by.
                See the site is running nginx and I am running that also on my Cubieboard2 and also had 502 Bad Gateway problems and solved them eventually, see https://domotiga.nl/projects/domotiyii/wiki/Installation#If-things-go-wrong
                The stackoverflow link is for a very old version of Firefox; I doubt if that is still relevant. I this article, http://stackoverflow.com/questions/10470109/error-502-in-nginx-php5-fpm, two year old ;-) maybe helpful?
                • hekH Online
                  hekH Online
                  The forum is node.js based (not php). I doubt it's right related. The forum runs inside a dockers container with a ngnix proxy (which has websocket proxying enabled) in front of everything.
                  • D Offline
                    daulagari
                    Tried again with Firefox and now things are working.
                    Problems solved!
