  3. Enhanced Dallas Temperature example with permanent sensor index
3 Posts 2 Posters 2.7k Views 5 Watching
  • L Offline
    L Offline
    LeoDesigner
    wrote on last edited by LeoDesigner
    Hi everyone,
    I have made some improvements to the Dallas Temperature Sensors example.
    • made for non blocking main loop (useful for repeater and busy nodes)
      block time max 15ms for sensor read procedure
    • it will remember a sensor index in EEPROM (2 bytes per sensor)
      in case if you need to replace or add a new sensor to the 1Wire bus - all other sensors will keep own sensor index
    You are welcome to use it:
    https://github.com/leodesigner/mysensors-arduino/tree/master/DallasTemperatureSensor_Recall
    • R Offline
      R Offline
      redvoodoochild
      Thanks a lot !
      You make my day !
      L 1 Reply Last reply
      • R redvoodoochild
        Thanks a lot !
        You make my day !
        L Offline
        L Offline
        LeoDesigner
        @redvoodoochild
        You welcome, I hope it will be useful for you too.
        11.8k
        113.2k
