  3. Battery sensor measure for li-ion cells?
20 Posts 5 Posters 12.1k Views 4 Watching
  • TmasterT
    TmasterT
    Tmaster
    wrote on last edited by Tmaster
    Hello. like i told on other topics , i'm finishing my first "mysensor" conected to vera lite ,battery powered (2xtermistor+light sensor) that i will present later on forum soon as its working. its all working except battery percentage.
    Second the example i follow,it says:
       float batteryV  = sensorValue * 0.003363075;
    this is part of "mysensor battery sensor example"
    Its a simple voltage divider and calculation of volt per bit and after that send percentage to my vera.
    BUT i'm using li-ion batteries , 3.6v cell, 2 cell=7.2v or +-8.2v on full charge.
    AND there comes my problem.
    Where this calculation make reference to what is 100%(8.2v) and what is 0%(6.4v)?
    it only will say 0% its a flat ...Dead...li-ion cell:/
    Thank you
    i'm a arduino fan .Even sometimes don't undestanding how to use it :P
      The reference tells the chip what should be regarded as maximum. So if you set 1.1V as reference, any voltage above 1.1V will result in a reading of 1023.
      You either need to adjust your voltage divider so the "middle" point is at 1.1V or below (with 8.2V you could use something like 1Mohm + 120kohm), or use a different method (like the "secret" method). You could also switch to using the "standard" reference (of 5V) and your 1M+470k voltage divider.
      Edit: The "secret" (stupid name!) method required that you don't use a voltage regulator, so it is not applicable in your case. Go for 1M+120k voltage divider or use the standard reference.
      • TmasterT
        TmasterT
        Tmaster
        Ok. I use vreg. Its waste less battery than stepup modules(second i read) .
        But what about Set the 0% .0 will be aa flat cell,right?
        I already use reference as default(3.3v on my promini)
        • m26872M
          m26872M
          m26872
          I've successfully used these calculations, resistors and voltage levels for different number of AAs in series with the 1.1V ref.
          Internal_ref=1.1V, res=10bit=2^10-1=1023, 2AA: Vin/Vbat=470e3/(1e6+470e3), 4AA: Vin/Vbat=1e6/(1e6+5e6), 3AA: Vin/Vbat=680e3/(2.5e6+680e3)
          Vlim = 1.1*Vbat/Vin = 6.6 V (Set to Vmax ?)
          Volts per bit = Vlim/1023 = 0.006452
          Vmin = 4.3V (Min input voltage to regulator according to datasheet. (?) )
          Vmax = 6.6V (Known or desired voltage of full batteries. If not, set to Vlim.)
          Vpercent = 100*(Vbat-Vmin)/(Vmax-Vmin)
          So if you use the 3.3V Arduino Pro Mini through its internal vreg, I'd set the Vmin (0%) ~1V above 3.3V i.e. 4.3V, by default. If your stuff supplied by this vreg-out is capable of going below 3.3V you could lower your Vmin, but then you have to use the 1.1V ref.
          Else, when using "high" voltages like in your case it's hard to optimize the resistors and then better to also use a higher reference, like 3.3 och 5V Vcc.
          I'd suggest you to use the 3.3V (default) reference and standard voltage divider (1M+470k). The calculation are then
          Vlim = 3.3*(1e6+470e3)/470e3 = 10.32 V
          Volts per bit = Vlim/1023 = 0.010089224434
          Vmin = 4.3V (Min input voltage to regulator)
          Vmax = 8.2V (+ some margin)
          And of course in your code, there will be something like...
          float batteryV  = sensorValue * 0.010089224434;
          int batteryPcnt = static_cast<int>(((batteryV-VMIN)/(VMAX-VMIN))*100);
          • TmasterT
            TmasterT
            Tmaster
             Vpercent = 100 x (Vbat-Vmin) / (Vmax-Vmin)    ! ! ! ! ! ! ! ! !
            THAT IS THE WINNER CALCULATION!! is just that what i'm locking for :) but i coldn't reach by my self
            Thank you very much.
            m26872M 1 Reply Last reply
            • m26872M
              m26872M
              m26872
              :thumbsup:
              Some people prefer to use the 'map()' function instead. It does the same job.
              • TmasterT
                TmasterT
                Tmaster
                one more function that i din't know:P
                long map(long x, long in_min, long in_max, long out_min, long out_max)
                  return (x - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
                For now it will stay with voltage regulator and 7,2v (2 cells battery), but in case I want save even more battery I can use only 1 cell (3.7v) and connect it directly to vcc on my 8mhz pro mini and remove led and 3.3v regulator.
                My question is , atmel326p handle up to 5v directly on Vcc,even my 8mhz one, but what happens to my analog reference ,if i set analog reference( default ), as it is right now, and my battery fluctuate between 4.2V and 3.2V when start discharge? Reference will fluctuate as well and affect my battery measure ,right? how they handle that problem?
                • TmasterT Tmaster
                  m26872M
                  m26872M
                  m26872
                  @Tmaster
                  Whenever you connect your battery straight to Vcc, I can't see any reason not use the internal voltage monitoring method (as @mfalkvidd linked to above).
                  Last I heard was that 3.7V ment a high risk to kill the nRF radio module. You might want to look up how people have handled that before you proceed.
                  • TmasterT
                    TmasterT
                    Tmaster
                    ah! i was so focus on arduino that i forgot the radio. but i know about 3.3 v from nrf24.
                    When its powered by transformer ,i use 5v arduinos and this module for the nrf24. is v reg :
                    http://www.ebay.com/itm/New-Sale-Socket-Adapter-Module-Board-for-8PIN-NRF24L01-Wireless-Module-/191353332066?hash=item2c8d8c2162:g:QnUAAOxyBotTX0mW
                    • L
                      L
                      LastSamurai
                      wrote on last edited by LastSamurai
                      Great information here! I was building my own method for getting battery percentage for my 2AA battery powered node and tried to understand the calculations. Here is my piece of code. What do you guys think? Everything's right?
                      // define values for the battery measurement
                      #define R1 = 1e6;
                      #define R2 = 470e3;
                      #define VMIN = 1.8;
                      #define VMAX = 3;
                      #define ADC_PRECISION = 1023;
                      int getBatteryPercentage() {
                        // read analog pin value
                        int inputValue = analogRead(BATTERY_SENSE_PIN);
                        // calculate the max possible value and therefore the range and steps
                        float voltageDividerFactor = (R1 + R2) / R2;
                        float maxValue = voltageDividerFactor * VMAX;
                        float voltsPerBit = maxValue / ADC_PRECISION;
                        float batteryVoltage = voltsPerBit * inputValue;
                        //int batteryPercentage = ((batteryVoltage-VMIN)/(VMAX-VMIN))*100;
                        int batteryPercentage = map(batteryVoltage, 0, maxValue, 0, 100);
                        return batteryPercentage;
                      The 2 lines for the batteryPercentage should do exactly the same. Prefer the 2nd one though, it's more readable for me.
                      • L LastSamurai
                        #define R1 = 1e6;
                        #define R2 = 470e3;
                        #define VMIN = 1.8;
                        #define VMAX = 3;
                        m26872M
                        m26872M
                        m26872
                        @LastSamurai
                        About this line:
                        You should use your Adc reference voltage here, not VMAX. If it's a 2AA node you probably use 1.1V internal ref.
                        • L
                          L
                          LastSamurai
                          Thanks! I updated the code (had some errors in the define statements and now got this:
                          #include <DHT.h>
                          #define CHILD_ID_HUM 0
                          #define CHILD_ID_TEMP 1
                          #define R1 1e6
                          #define R2 470e3
                          #define VMIN 1.8
                          #define VMAX 3
                          #define ADC_PRECISION 1023
                          #define VREF 1.1
                          DHT dht;
                          unsigned long SLEEP_TIME = 300000; // Sleep time between reads (in milliseconds)
                          float lastTemp;
                          float lastHum;
                          boolean metric = true;
                          int oldBatteryPcnt = 0;
                          int BATTERY_SENSE_PIN = A0;
                               analogReference(INTERNAL1V1);
                            #else
                               analogReference(INTERNAL);
                            gw.begin();
                            gw.sendSketchInfo("Humidity", "1.0");
                             int batteryPcnt = getBatteryPercentage();
                             Serial.print(batteryPcnt);
                             Serial.println(" %");
                               // Power up radio after sleep
                               oldBatteryPcnt = batteryPcnt;
                            // totally random test values
                            gw.send(msgTemp.set(42, 1));
                            gw.send(msgHum.set(42, 1));
                            gw.sleep(SLEEP_TIME); //sleep a bit
                            float maxValue = voltageDividerFactor * VREF;
                            float batteryPercentage = ((batteryVoltage-VMIN)/(VMAX-VMIN))*100;
                            //int batteryPercentage = map(batteryVoltage, 0, maxValue, 0, 100);
                          I am using 2 1.5V aa batteries, but somehow I get a percentage of 136%. Whats wrong there?
                          Using the map part instead I get 100%, so some values is way to big somehow.
                          • L LastSamurai
                            #include <DHT.h>
                            #define R1 1e6
                            #define R2 470e3
                            #define VMIN 1.8
                            #define VMAX 3
                            #define VREF 1.1
                            DHT dht;
                            float lastTemp;
                            float lastHum;
                              #else
                              gw.begin();
                            m26872M
                            m26872M
                            m26872
                            @LastSamurai
                            If I were you I would:
                            a. Measure battery voltage to know what to expect.
                            b. Debug by printing out the raw sensor value 'inputValue'. (0 or 1023 likely means a hw issue).
                            c. Change VMAX to 3.2, 3.3 or maxValue.
                            d. Change the line
                            to
                              int batteryPercentage = static_cast<int>(((batteryVoltage-VMIN)/(VMAX-VMIN))*100);
                            • L
                              L
                              LastSamurai
                              Ok I added the change, removed everything but the battery/voltage code and tried it out. Using a serial to usb adapter I got the right values.
                              Then I readded the network and sleep stuff and suddenly I am getting these 136% percent again. Any idea why? Could sleeping or the network somehow interfere with the measurements?
                              AWIA 1 Reply Last reply
                              • L LastSamurai
                                AWIA
                                AWIA
                                AWI
                                @LastSamurai Everything is related to VMAX in your case. Have you measured the actual voltage of the batteries..? The type of battery used can explain the 136% upload-24c946fc-3ac4-4897-9bc2-b8203650a0ac
                                Using the calculation below you will never get an above 100% reading ;)
                                int batteryPcnt = constrain(map(batteryVoltage, VccMin, VccMax, 0, 100),0,100); // and map to the 0-100% range
                                • L
                                  L
                                  LastSamurai
                                  The actual voltage was about 2.7-2.8V. So my values should be right?! I will do some more testing soon.
                                  Are you sure about constrain and map? I am pretty sure the map call already maps the values to 0..100. So no constrain needed.
                                  Is it possible that
                                  #define VMAX 3
                                  // has to be
                                  #define VMAX 3.0
                                  • L LastSamurai
                                    Is it possible that
                                    #define VMAX 3
                                    // has to be
                                    #define VMAX 3.0
                                    m26872M
                                    m26872M
                                    m26872
                                    @LastSamurai
                                    I think you should note what the map() reference says about constrain and integer math. Try to use mV instead.
                                    • L
                                      L
                                      LastSamurai
                                      @m26872 Thanks! For me thats strange behaviour but it seems you guys are absolutely right!
                                      What do you mean mV? Using VMAX 3000 instead of 3?
                                      • L LastSamurai
                                        m26872M
                                        m26872M
                                        m26872
                                        @LastSamurai
                                        As input to map(), yes. And that goes for Vbat and Vmin as well of course.
                                        • TmasterT Tmaster
                                          m26872M
                                          m26872M
                                          m26872
                                          @Tmaster
                                          I'd like to add a few things about the settings a Vmin and Vmax.
                                          If you get a Vbat value outside of [Vmin Vmax] the calculation would give a negative result. Since it's then sent as an uint8_t, it'll not be easy read or meaningful. Due to this it's sometimes a good advice to make the interval wider, use a constraint or handle the exceptions.
                                          Vmin 4.3V is a conservative limit. The APM internal vreg (ldo?) is probably working a lot lower depending on the load. You have to find out yourself.
