  3. IR Record and Playback module
12 Posts 6 Posters 10.7k Views 7 Watching
  • BartEB
    BartEB
    BartE
    wrote on last edited by BartE
    On special request i've created a IR (InfraRed remote) record and playback sensor.
    This is based on the example IR sensor but now one can record a IR - signal from an remote and let your controller send the IR code on request. http://www.mysensors.org/build/ir
    Up to 10 codes can be recorded and playback
    Please note this plugin relies on a message type which is not yet available in the MySensors core (a pull request has been made)
    This Arduino library https://github.com/z3t0/Arduino-IRremote/releases is used for decoding and encoding:
     * Version 1.0 - Changed for MySensors usage by Bart Eversdijk
     * IRrecord: record and play back IR signals as a minimal
     * An IR detector/demodulator must be connected to the input RECV_PIN.
     * An IR LED must be connected to the output PWM pin 3.
     * A button must be connected to the input BUTTON_PIN; this is the
     * send button.
     * A visible LED can be connected to STATUS_PIN to provide status.
     * The logic is:
     * If the button is pressed, send the IR code.
     * If an IR code is received, record it.
     * Version 0.11 September, 2009
     * Copyright 2009 Ken Shirriff
     * http://arcfn.com
    #include <IRremote.h>  // https://github.com/z3t0/Arduino-IRremote/releases
    int RECV_PIN     = 8;
    #define NODEID   5
    #define CHILD_1  2  // childId
    #define MY_RAWBUF  50
    const char * TYPE2STRING[] = {
    		"UNKONWN",
    		"RC5",
    		"RC6",
    		"NEC",
    		"Sony",
    		"Panasonic",
    		"JVC",
    		"SAMSUNG",
    		"Whynter",
    		"AIWA RC T501",
    		"LG",
    		"Sanyo",
    		"Mitsubishi",
    		"Dish",
    		"Sharp",
    		"Denon"
    #define Type2String(x)   TYPE2STRING[x < 0 ? 0 : x]
    #define AddrTxt          F(" addres: 0x")
    #define ValueTxt         F(" value: 0x")
    #define NATxt            F(" - not implemented/found")
    // Raw or unknown codes requires an Arduino with a larger memory like a MEGA and some changes to store in EEPROM (now max 255 bytes)
    // #define IR_SUPPORT_UNKNOWN_CODES
    typedef union
      struct
        decode_type_t type;            // The type of code
        unsigned long value;           // The data bits if type is not raw
        int           len;             // The length of the code in bits
        unsigned int  address;         // Used by Panasonic & Sharp [16-bits]
      } code;
    #ifdef IR_SUPPORT_UNKNOWN_CODES
      struct
        unsigned int  codes[MY_RAWBUF];
        byte          count;           // The number of interval samples
      } raw;
    } IRCode;
    #define           MAX_IR_CODES     10
    IRCode            StoredIRCodes[MAX_IR_CODES];
    IRrecv            irrecv(RECV_PIN);
    IRsend            irsend;
    decode_results    ircode;
    #define           NO_PROG_MODE 0xFF
    byte              progModeId       = NO_PROG_MODE;
    MyMessage msgIrReceive(CHILD_1, V_IR_RECEIVE);
    MyMessage msgIrRecord(CHILD_1, V_IR_RECORD);
      gw.begin(incomingMessage, NODEID);
      gw.sendSketchInfo("IR Rec/Playback", "1.0");
      // Register a sensors to gw. Use binary light for test purposes.
      gw.present(CHILD_1, S_IR);
      // Tell MYS Controller that we're NOT recording
      gw.send(msgIrRecord.set(0));
      Serial.println(F("Recall EEPROM settings"));
      recallEeprom(sizeof(StoredIRCodes), (byte *)&StoredIRCodes);
      // Start the ir receiver
      irrecv.enableIRIn();
      Serial.println(F("Init done..."));
      gw.process();
      if (irrecv.decode(&ircode)) {
          dump(&ircode);
          if (progModeId != NO_PROG_MODE) {
             // If we are in PROG mode (Recording) store the new IR code and end PROG mode
             if (storeRCCode(progModeId)) {
                Serial.print(F("Stored "));
                // If sucessfull RC decode and storage --> also update the EEPROM
                storeEeprom(sizeof(StoredIRCodes), (byte *)&StoredIRCodes);
                // Tell MYS Controller that we're done recording
          } else {
             // If we are in Playback mode just tell the MYS Controll we did receive an IR code
             if (ircode.decode_type != UNKNOWN) {
                 if (ircode.value != REPEAT) {
                   // Look if we found a stored preset 0 => not found
                   byte num = lookUpPresetCode(&ircode);
                   if (num) {
                       // Send IR decode result to the MYS Controller
                       Serial.print(F("Found code for preset #"));
                       Serial.println(num);
                       gw.send(msgIrReceive.set(num));
        // Wait a while before receive next IR-code
        delay(500);
        // Start receiving again
        irrecv.resume();
        //Serial.print(F("New message: "));
        //Serial.println(message.type);
       if (message.type == V_IR_RECORD) { // IR_RECORD V_VAR1
          // Get IR record requets for index : paramvalue
          progModeId = message.getByte() % MAX_IR_CODES;
          // Tell MYS Controller that we're now in recording mode
          gw.send(msgIrRecord.set(1));
          Serial.print(F("Record new IR for: "));
          Serial.println(progModeId);
       if (message.type == V_IR_SEND) {
          // Send an IR code from offset: paramvalue - no check for legal value
          Serial.print(F("Send IR preset: "));
          Serial.print(message.getByte());
          sendRCCode(message.getByte() % MAX_IR_CODES);
       // Start receiving ir again...
    byte lookUpPresetCode (decode_results *ircode)
        for (byte index = 0; index < MAX_IR_CODES; index++)
          if ( StoredIRCodes[index].code.type  == ircode->decode_type &&
               StoredIRCodes[index].code.value == ircode->value       &&
               StoredIRCodes[index].code.len   == ircode->bits)      {
              // The preset number starts with 1 so the last is stored as 0 -> fix this when looking up the correct index
              return (index == 0) ? MAX_IR_CODES : index;
        // not found so return 0
        return 0;
    // Stores the code for later playback
    bool storeRCCode(byte index) {
      if (ircode.decode_type == UNKNOWN) {
          Serial.println(F("Received unknown code, saving as raw"));
          // To store raw codes:
          // Drop first value (gap)
          // As of v1.3 of IRLib global values are already in microseconds rather than ticks
          // They have also been adjusted for overreporting/underreporting of marks and spaces
          byte rawCount = min(ircode.rawlen - 1, MY_RAWBUF);
          for (int i = 1; i <= rawCount; i++) {
            StoredIRCodes[index].raw.codes[i - 1] = ircode.rawbuf[i]; // Drop the first value
          return true;
    #else
          return false;
      if (ircode.value == REPEAT) {
          // Don't record a NEC repeat value as that's useless.
          Serial.println(F("repeat; ignoring."));
          return false;
       StoredIRCodes[index].code.type      = ircode.decode_type;
       StoredIRCodes[index].code.value     = ircode.value;
       StoredIRCodes[index].code.address   = ircode.address;      // Used by Panasonic & Sharp [16-bits]
       StoredIRCodes[index].code.len       = ircode.bits;
       Serial.print(F(" value: 0x"));
       Serial.println(ircode.value, HEX);
       return true;
    void sendRCCode(byte index) {
       if(StoredIRCodes[index].code.type == UNKNOWN) {
          // Assume 38 KHz
          irsend.sendRaw(StoredIRCodes[index].raw.codes, StoredIRCodes[index].raw.count, 38);
          Serial.println(F("Sent raw"));
          return;
       Serial.print(F(" - sent "));
       Serial.print(Type2String(StoredIRCodes[index].code.type));
       if (StoredIRCodes[index].code.type == RC5) {
           // For RC5 and RC6 there is a toggle bit for each succesor IR code sent alway toggle this bit
           StoredIRCodes[index].code.value ^= 0x0800;
           irsend.sendRC5(StoredIRCodes[index].code.value, StoredIRCodes[index].code.len);
        else if (StoredIRCodes[index].code.type == RC6) {
           StoredIRCodes[index].code.value ^= 0x10000;
           irsend.sendRC6(StoredIRCodes[index].code.value, StoredIRCodes[index].code.len);
       else if (StoredIRCodes[index].code.type == NEC) {
           irsend.sendNEC(StoredIRCodes[index].code.value, StoredIRCodes[index].code.len);
        else if (StoredIRCodes[index].code.type == SONY) {
           irsend.sendSony(StoredIRCodes[index].code.value, StoredIRCodes[index].code.len);
        else if (StoredIRCodes[index].code.type == PANASONIC) {
           irsend.sendPanasonic(StoredIRCodes[index].code.address, StoredIRCodes[index].code.value);
           Serial.print(AddrTxt);
           Serial.println(StoredIRCodes[index].code.address, HEX);
        else if (StoredIRCodes[index].code.type == JVC) {
           irsend.sendJVC(StoredIRCodes[index].code.value, StoredIRCodes[index].code.len, false);
        else if (StoredIRCodes[index].code.type == SAMSUNG) {
           irsend.sendSAMSUNG(StoredIRCodes[index].code.value, StoredIRCodes[index].code.len);
        else if (StoredIRCodes[index].code.type == WHYNTER) {
           irsend.sendWhynter(StoredIRCodes[index].code.value, StoredIRCodes[index].code.len);
        else if (StoredIRCodes[index].code.type == AIWA_RC_T501) {
           irsend.sendAiwaRCT501(StoredIRCodes[index].code.value);
        else if (StoredIRCodes[index].code.type == LG || StoredIRCodes[index].code.type == SANYO || StoredIRCodes[index].code.type == MITSUBISHI) {
           Serial.println(NATxt);
           return;
        else if (StoredIRCodes[index].code.type == DISH) {
           irsend.sendDISH(StoredIRCodes[index].code.value, StoredIRCodes[index].code.len);
        else if (StoredIRCodes[index].code.type == SHARP) {
           irsend.sendSharp(StoredIRCodes[index].code.address, StoredIRCodes[index].code.value);
        else if (StoredIRCodes[index].code.type == DENON) {
           irsend.sendDenon(StoredIRCodes[index].code.value, StoredIRCodes[index].code.len);
        else {
          // No valid IR type, found it does not make sense to broadcast
          return;
        Serial.print(" ");
        Serial.println(StoredIRCodes[index].code.value, HEX);
    // Dumps out the decode_results structure.
    void dump(decode_results *results) {
        int count = results->rawlen;
        Serial.print(F("Received : "));
        Serial.print(results->decode_type, DEC);
        Serial.print(F(" "));
        Serial.print(Type2String(results->decode_type));
        if (results->decode_type == PANASONIC) {
          Serial.print(results->address,HEX);
          Serial.print(ValueTxt);
        Serial.print(results->value, HEX);
        Serial.print(F(" ("));
        Serial.print(results->bits, DEC);
        Serial.println(F(" bits)"));
        if (results->decode_type == UNKNOWN) {
          Serial.print(F("Raw ("));
          Serial.print(count, DEC);
          Serial.print(F("): "));
          for (int i = 0; i < count; i++) {
            if ((i % 2) == 1) {
              Serial.print(results->rawbuf[i]*USECPERTICK, DEC);
            else {
              Serial.print(-(int)results->rawbuf[i]*USECPERTICK, DEC);
            Serial.print(" ");
          Serial.println("");
    // Store IR record struct in EEPROM
    void storeEeprom(byte len, byte *buf)
        gw.saveState(0, len);
        for (byte i = 1; i < min(len, 100); i++, buf++)
           gw.saveState(i, *buf);
    void recallEeprom(byte len, byte *buf)
        if (gw.loadState(0) != len)
           Serial.print(F("Corrupt EEPROM preset values and Clear EEPROM"));
               *buf = 0;
               storeEeprom(len, buf);
           return;
           *buf = gw.loadState(i);
      @BartE
      You are the king!
      It's a bit late here now so I'll merge this things tomorrow.
      • blaceyB
        blaceyB
        blacey
        @BartE, awesome! Your sketch should work perfectly with the IR Blaster. Perhaps you would be a good beta tester - where are you located?
        • BartEB
          BartEB
          BartE
          @blacey this i've though about that too. (the IR-led i've tested with has a poor broadcast range)
          I'm living in the Netherlands
          • BartEB
            BartEB
            BartE
            Adding some Vera screenshots
            upload-89cc6ee3-ce20-44d0-a53c-79305c023d6c
            upload-1d15bc07-5e6d-46ce-87df-cae8adbb5159
            P 1 Reply Last reply
            • BartEB BartE
              P
              P
              pete1450
              @BartE As I'm already using a sensor that I just control with light switch buttons in vera, I'd like to not have to add a IR receiver to the current board. Does this have the ability to let me just add the hex codes I already have?
              Either way this is awesome.
              • BartEB
                BartEB
                BartE
                @pete1450 i've added your feature request in version 1.1 of my plug in sketch You can add up to 240 RC HEX commands, from line 111, if you use an Arduino with enough memory. 40 will do with an Arduino UNO
                 * Version 1.0 - Changed for MySensors useage by Bart Eversdijk
                 * Version 1.1 - Added option to record manual presets up to 240
                 * send button.
                 * The logic is:
                 * http://arcfn.com
                int RECV_PIN     = 8;
                #define NODEID   5
                //#define NODEID   NULL
                		"UNKONWN",
                		"RC5",
                		"RC6",
                		"NEC",
                		"Sony",
                		"Panasonic",
                		"JVC",
                		"SAMSUNG",
                		"Whynter",
                		"AIWA RC T501",
                		"LG",
                		"Sanyo",
                		"Mitsubishi",
                		"Dish",
                		"Sharp",
                		"Denon"
                typedef union
                  struct
                  } code;
                  struct
                  } raw;
                } IRCode;
                #define           MAX_STORED_IR_CODES     10
                IRCode            StoredIRCodes[MAX_STORED_IR_CODES];
                IRsend            irsend;
                // Manual Preset IR values
                // VERA call: luup.call_action("urn:schemas-arduino-cc:serviceId:ArduinoIr1", "SendIrCode", {Index=15}, <device number>)
                // One can add up to 240 preset codes (if your memory lasts) to see to correct data connect the Arduino with this plug in and
                // look at the serial monitor while pressing the desired RC button
                IRCode PresetIRCodes[] = {
                    { { RC5, 0x01,       12, 0 } },  // 11 - RC5 key "1"
                    { { RC5, 0x02,       12, 0 } },  // 12 - RC5 key "2"
                    { { RC5, 0x03,       12, 0 } },  // 13 - RC5 key "3"
                    { { NEC, 0xFF30CF,   32, 0 } },  // 14 - NEC key "1"
                    { { NEC, 0xFF18E7,   32, 0 } },  // 15 - NEC key "2"
                    { { NEC, 0xFF7A85,   32, 0 } },  // 16 - NEC key "3"
                    { { NEC, 0xFF10EF,   32, 0 } },  // 17 - NEC key "4"
                    { { NEC, 0xFF38C7,   32, 0 } },  // 18 - NEC key "5"
                    { { RC6, 0x800F2401, 36, 0 } },  // 19 - RC6 key "1" MicroSoft Mulitmedia RC
                    { { RC6, 0x800F2402, 36, 0 } }   // 20 - RC6 key "2" MicroSoft Mulitmedia RC
                #define MAX_PRESET_IR_CODES  (sizeof(PresetIRCodes)/sizeof(IRCode))
                #define MAX_IR_CODES (MAX_STORED_IR_CODES + MAX_PRESET_IR_CODES)
                  gw.sendSketchInfo("IR Rec/Playback", "1.1");
                  gw.process();
                      dump(&ircode);
                      } else {
                               if (num) {
                    delay(500);
                    irrecv.resume();
                      progModeId = message.getByte() % MAX_STORED_IR_CODES;
                      byte code = message.getByte() % MAX_IR_CODES;
                      if (code == 0) {
                        code = MAX_IR_CODES;
                      Serial.print(code);
                      sendRCCode(code);
                    // Get rit of the RC5/6 toggle bit when looking up
                    if (ircode->decode_type == RC5)  {
                        ircode->value = ircode->value & 0x7FF;
                    if (ircode->decode_type == RC6)  {
                        ircode->value = ircode->value & 0xFFFF7FFF;
                    for (byte index = 0; index < MAX_STORED_IR_CODES; index++) {
                          return (index == 0) ? MAX_STORED_IR_CODES : index;
                    for (byte index = 0; index < MAX_PRESET_IR_CODES; index++) {
                      if ( PresetIRCodes[index].code.type  == ircode->decode_type &&
                           PresetIRCodes[index].code.value == ircode->value       &&
                           PresetIRCodes[index].code.len   == ircode->bits)      {
                          return ((index == 0) ? MAX_PRESET_IR_CODES : index) + MAX_STORED_IR_CODES;
                    return 0;
                      return true;
                #else
                      return false;
                       return false;
                   // Get rit of the toggle bit when storing RC5/6
                   if (ircode.decode_type == RC5)  {
                        ircode.value = ircode.value & 0x07FF;
                   if (ircode.decode_type == RC6)  {
                        ircode.value = ircode.value & 0xFFFF7FFF;
                   return true;
                   IRCode *pIr = ((index <= MAX_STORED_IR_CODES) ? &StoredIRCodes[index % MAX_STORED_IR_CODES] : &PresetIRCodes[index - MAX_STORED_IR_CODES - 1]);
                   if(pIr->code.type == UNKNOWN) {
                      // Assume 38 KHz
                      irsend.sendRaw(pIr->raw.codes, pIr->raw.count, 38);
                      return;
                   Serial.print(Type2String(pIr->code.type));
                   if (pIr->code.type == RC5) {
                       // For RC5 and RC6 there is a toggle bit for each succesor IR code sent alway toggle this bit, needs to repeat the command 3 times with 100 mS pause
                       pIr->code.value ^= 0x0800;
                       for (byte i=0; i < 3; i++) {
                         if (i > 0) { delay(100); }
                         irsend.sendRC5(pIr->code.value, pIr->code.len);
                    else if (pIr->code.type == RC6) {
                       if (pIr->code.len == 20) {
                              pIr->code.value ^= 0x10000;
                         irsend.sendRC6(pIr->code.value, pIr->code.len);
                   else if (pIr->code.type == NEC) {
                       irsend.sendNEC(pIr->code.value, pIr->code.len);
                    else if (pIr->code.type == SONY) {
                       irsend.sendSony(pIr->code.value, pIr->code.len);
                    else if (pIr->code.type == PANASONIC) {
                       irsend.sendPanasonic(pIr->code.address, pIr->code.value);
                       Serial.println(pIr->code.address, HEX);
                    else if (pIr->code.type == JVC) {
                       irsend.sendJVC(pIr->code.value, pIr->code.len, false);
                    else if (pIr->code.type == SAMSUNG) {
                       irsend.sendSAMSUNG(pIr->code.value, pIr->code.len);
                    else if (pIr->code.type == WHYNTER) {
                       irsend.sendWhynter(pIr->code.value, pIr->code.len);
                    else if (pIr->code.type == AIWA_RC_T501) {
                       irsend.sendAiwaRCT501(pIr->code.value);
                    else if (pIr->code.type == LG || pIr->code.type == SANYO || pIr->code.type == MITSUBISHI) {
                       return;
                    else if (pIr->code.type == DISH) {
                      // need to repeat the command 4 times with 100 mS pause
                      for (byte i=0; i < 4; i++) {
                           irsend.sendDISH(pIr->code.value, pIr->code.len);
                    else if (pIr->code.type == SHARP) {
                       irsend.sendSharp(pIr->code.address, pIr->code.value);
                    else if (pIr->code.type == DENON) {
                       irsend.sendDenon(pIr->code.value, pIr->code.len);
                    else {
                      return;
                    Serial.print(" ");
                    Serial.println(pIr->code.value, HEX);
                        if ((i % 2) == 1) {
                        } else {
                        Serial.print(" ");
                      Serial.println("");
                    for (byte i = 1; i < min(len, 100); i++, buf++) {
                    if (gw.loadState(0) != len) {
                           *buf = 0;
                       return;
                I will update the Vera code as well in git
                With Vera this luup code controlls the extra presets:
                Vera UI5 Screen shot:
                upload-0bb76cf0-b984-4b30-b9b3-cfb03ffe9648
                  240 RC-commands ought to be enough for anybody...
                  • clio75C
                    clio75C
                    clio75
                    :joy_cat: :+1:
                    • BartEB BartE
                       * send button.
                       * The logic is:
                       * http://arcfn.com
                      int RECV_PIN     = 8;
                      #define NODEID   5
                      		"UNKONWN",
                      		"RC5",
                      		"RC6",
                      		"NEC",
                      		"Sony",
                      		"Panasonic",
                      		"JVC",
                      		"SAMSUNG",
                      		"Whynter",
                      		"AIWA RC T501",
                      		"LG",
                      		"Sanyo",
                      		"Mitsubishi",
                      		"Dish",
                      		"Sharp",
                      		"Denon"
                      typedef union
                        struct
                        } code;
                        struct
                        } raw;
                      } IRCode;
                      IRsend            irsend;
                        gw.process();
                            dump(&ircode);
                            } else {
                                     if (num) {
                          delay(500);
                          irrecv.resume();
                            if (code == 0) {
                            Serial.print(code);
                            sendRCCode(code);
                          return 0;
                            return true;
                      #else
                            return false;
                             return false;
                         return true;
                            // Assume 38 KHz
                            return;
                             return;
                          else {
                            return;
                          Serial.print(" ");
                              if ((i % 2) == 1) {
                              } else {
                              Serial.print(" ");
                            Serial.println("");
                                 *buf = 0;
                             return;
                      P
                      P
                      pete1450
                      @BartE Wow that's great. Thanks!
                      • rabeliyoR
                        rabeliyoR
                        rabeliyo
                        I get this error in UI7
                        Arduino:1.6.7 (Windows 7), Placa:"Arduino Nano, ATmega328"
                        WARNING: Category '' in library UIPEthernet is not valid. Setting to 'Uncategorized'
                        D:\Users\Colosus\Desktop\ir_prueba\ir_prueba.ino: In function 'void setup()':
                        ir_prueba:141: error: 'msgIrRecord' was not declared in this scope
                        D:\Users\Colosus\Desktop\ir_prueba\ir_prueba.ino: In function 'void loop()':
                        ir_prueba:168: error: 'msgIrRecord' was not declared in this scope
                        D:\Users\Colosus\Desktop\ir_prueba\ir_prueba.ino: In function 'void incomingMessage(const MyMessage&)':
                        ir_prueba:197: error: 'V_IR_RECORD' was not declared in this scope
                        • BartEB
                          BartEB
                          BartE
                          This sketch has been updated to MySensors 2.0 and added example library https://www.mysensors.org/build/ir
