  3. Arduino Mega + sensor shield 2
7 Posts 2 Posters 6.5k Views 1 Watching
  • epierreE
    epierreE
    epierre
    I have tried to connect to the radio a Mega + shield, checked wiring numerous times...
    I was on 3.3V, moved to 5V with compensation...
    would there be a reason why a mega wouldn't work with mysensors?
    z-wave - Vera -> Domoticz
    • marceltrapmanM
      marceltrapmanM
      marceltrapman
      @epierre Look here: http://forum.mysensors.org/topic/66/unable-to-use-the-serialgateway-code/7
      It looks like the pins are different.
      Fulltime Servoy Developer
      • epierreE
        epierreE
        epierre
        ok so the post say this
        pin D8-----------CE (chip enable in)
        SS pin D53----------CSN (chip select in)
        SCK pin D52----------SCK (SPI clock in)
        MOSI pin D51----------SDI (SPI Data in)
        MISO pin D50----------SDO (SPI data out)
        Gateway gw(8, 53, INCLUSION_MODE_TIME, INCLUSION_MODE_PIN, 6, 5, 4);
        For a sensor I would translate it to :
        Sensor gw(8, 53);
        right ? --> but the serial debug is deaf when I do this... any idea ?
        • epierreE epierre
          Sensor gw(8, 53);
          marceltrapmanM
          marceltrapmanM
          marceltrapman
          wrote on last edited by marceltrapman
          @epierre I'm sorry I have one but never used it.
          So I would have to test that because I don't see any use for a mega as a sensor. I like them as small as possible :)
          epierreE 1 Reply Last reply
          • marceltrapmanM marceltrapman
            epierreE
            epierreE
            epierre
            @marceltrapman me too, but here this will be my hoe monitor : light, sound, pressure, and polluants, I already have5 nodes on it.
            • epierreE epierre
              epierreE
              epierreE
              epierre
              wrote on last edited by epierre
              I've found the SPI reference
              51: MOSI       Blue
              GND: GND       Black
              52: SCK        Green
              50: MISO       Violet
              48: CE         Orange
              49: CSN        Yellow
              3V: VCC        Red
              Sensor gw(48,49)
              OR alternative
              GND: GND
              52: SCK
              50: MISO
              9: CE
              49: CSN
              3V: VCC
              GND: GND
              Sensor gw(9,49)
              NOTE!! Most * problems with intermittent operation are because of electrical noise on the 3.3V Power supply. The MEGA is more of a problem with this. Solution: ADD bypass capacitors across GND and 3.3V ON the radio modules. One user said, "Just Solder a 100nF ceramic cap across the gnd and 3.3v pins direct on the nrf24l01+ modules!" Some have used a 1uF to 10uF capacitor.
              • epierreE
                epierreE
                epierre
                ok this time I plugged myself on the 5V and it works !
