  3. 3 in 1 incl battery monitor
60 Posts 11 Posters 30.1k Views 12 Watching
  • the cosmic gateT Offline
    the cosmic gate
    I'am trying to build some 3 in 1 ( motion / temp / hum ) incl. battery monitor .
    At the moment i try to combine these sketches , as result
    #include <DHT.h>
    #define CHILD_ID_HUM 0
    #define CHILD_ID_TEMP 1
    #define CHILD_ID_MOT 2   // Id of the sensor child
    #define HUMIDITY_SENSOR_DIGITAL_PIN 4
    int oldBatteryPcnt = 0;
    DHT dht;
    float lastTemp;
    float lastHum;
    boolean metric = true;
    MyMessage msgMot(CHILD_ID_MOT, V_TRIPPED);
       analogReference(INTERNAL1V1);
    #else
       analogReference(INTERNAL);
      gw.begin();
      gw.sendSketchInfo("Humidity/Motion", "1.0");
      gw.present(CHILD_ID_MOT, S_MOTION);
      // get the battery Voltage
       #ifdef DEBUG
       Serial.println(sensorValue);
       float batteryV  = sensorValue * 0.003363075;
       #ifdef DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
         // Power up radio after sleep
         oldBatteryPcnt = batteryPcnt;
      // Read digital motion value
      Serial.println(tripped);
      gw.send(msgMot.set(tripped?"1":"0"));  // Send tripped value to gw
      if (isnan(temperature)) {
        lastTemp = temperature;
        if (!metric) {
        Serial.print("T: ");
        Serial.println(temperature);
      if (isnan(humidity)) {
          lastHum = humidity;
          Serial.print("H: ");
          Serial.println(humidity);
      gw.sleep(INTERRUPT,CHANGE, SLEEP_TIME);
    Would this work ? ( sketch verification is okay :) )
    There's more than meets the eye
    the cosmic gateT 1 Reply Last reply
    • the cosmic gateT the cosmic gate
      #include <DHT.h>
      DHT dht;
      float lastTemp;
      float lastHum;
      #else
        gw.begin();
         #ifdef DEBUG
         #ifdef DEBUG
          if (!metric) {
            lastHum = humidity;
      the cosmic gate
      I also moded the arduino pro mini 8 Mhz like : http://www.mysensors.org/build/battery
      are there more (sketch) mod's possible to make it run as long as possible on 2 x AA
      AWIA 1 Reply Last reply
      • sundberg84S Offline
        sundberg84S Offline
        Look here for more info about battery operations: http://forum.mysensors.org/topic/486/my-2aa-battery-sensor
          AWIA Offline
          AWIA Offline
          AWI
          @the-cosmic-gate What you can do is combine the radio actions (gw.send) in one burst at the end of the sketch. That way you avoid having the radio "on" during sensor reading. The sensebender sketch can be inspiring too.
          • AWIA AWI
            the cosmic gate
            @AWI
            If i remove the (gw.send) action, the code would be
            #include <DHT.h>
            DHT dht;
            float lastTemp;
            float lastHum;
            #else
              gw.begin();
               #ifdef DEBUG
               #ifdef DEBUG
                if (!metric) {
                  lastHum = humidity;
              @AWI
              #include <DHT.h>
              DHT dht;
              float lastTemp;
              float lastHum;
              #else
                gw.begin();
                 #ifdef DEBUG
                 #ifdef DEBUG
                  if (!metric) {
                    lastHum = humidity;
              AWIA Offline
              AWIA Offline
              AWI
              wrote on last edited by AWI
              @the-cosmic-gate That is true but you will lose the MySensors functionality ;-) which is probably not your intention.
              What I meant is that you combine the gw.send actions in one "burst" or at least don't have the radio on while waiting for a (DHT) sensor to complete.
              like this part of code from the sensebender sketch
              if (tx) {
                  measureCount = 0;
                  float temperature = (isMetric ? data.celsiusHundredths : data.fahrenheitHundredths) / 100.0;
                  int humidity = data.humidityPercent;
                  Serial.print("T: ");Serial.println(temperature);
                  Serial.print("H: ");Serial.println(humidity);
                  gw.send(msgTemp.set(temperature,1));
                  gw.send(msgHum.set(humidity));
                  lastTemperature = temperature;
                  lastHumidity = humidity;
                the cosmic gate
                So the code "must" be
                #include <DHT.h>
                DHT dht;
                float lastTemp;
                float lastHum;
                #else
                  gw.begin();
                   #ifdef DEBUG
                   #ifdef DEBUG
                    if (!metric) {
                      lastHum = humidity;
                  sundberg84S Offline
                  Dont know if im answring the question (or i understand it)...
                  Do you mean @AWI that if you put the gw.*** together?
                  gw.begin();
                  put all the gw. *** together it will not cause the radio be on during DHT setup and readings like:
                  gw.begin();
                  • sundberg84S sundberg84
                    gw.begin();
                    gw.begin();
                    the cosmic gate
                    gw.begin();
                    gw.begin();
                    Now I'am getting confused :)
                    The thing i want to do is to make this 3in1 sketch , an 4 in 1 where the 4th is the battery sensors.
                    When i copy and paste this sketches together, i want to arrange one sketch who can run als long as possible on 2xAA batteries.
                    So if there are some tricks to make this sketch more battery friendle, so it runs longer on this 2 AA then it try to arrange is.
                    So As @AWI said i'll removed all the gw.send instructions, which gives me the result that the mysensors function is gone.
                    Then i tried again and put all the gw.send instructions "together".
                    But when i read you're reactien @sundberg84 this is not okay, or are there even more options to combine rules to make the sketch more battery friendly ?
                    Thnx for all the input
                      gw.begin();
                      gw.begin();
                      AWIA Offline
                      AWIA Offline
                      AWI
                      @the-cosmic-gate The reason to group all the "gw.send" instructions together (at the end of the sketch) is that the radio can "sleep" during the temperature and humidity readings. There are many ways (other than HW) to save battery power, like: only send values when a certain threshold is exceeded, decrease update frequency etc.
                      Just an example for a sensor which uses 11 uA in idle and sends updates only when needed (including a once in a hour 'heartbeat' of all sensors).
                       PROJECT: MySensors / Small battery sensor low power 1 mhz
                       PROGRAMMER: AWI
                       DATE: november 4, 2015/ last update: december 4, 2015
                       FILE: AWI small THM.ino
                       LICENSE: Public domain
                       Hardware: ATMega328p board w/ NRF24l01
                      	and MySensors 1.6 (Development)
                      Special:
                      	program with Arduino Pro 3.3V 1Mhz!!!
                      Summary:
                      	low power (battery)
                      	HTU21 Temp/Hum & Motion (interrupt)
                      	voltage meter for battery (internal)
                      Remarks:
                      	Fixed node-id
                      Change log:
                      20151204 - made it universal with respect to node id, only change   first 2 lines
                      #define MY_NODE_ID 19
                      #define NODE_TXT "THM 19"							// Text to add to sensor name
                      #define MY_RADIO_NRF24								// Enable and select radio type attached
                      #include <Wire.h> 									// I2C
                      #include <HTU21D.h>            						// temperature / humidity (i2c, HTU21D, SHT21)
                      #include <Vcc.h>									// library for internal reference Vcc reading
                      #undef MY_DEBUG										// turns of MySensors Serial debug (default on)
                      // Reference values for ADC and Battery measurements
                      const float VccMin        	= 1.0*2.5 ;    			// Minimum expected Vcc level, in Volts. Example for 1 rechargeable lithium-ion.
                      const float VccMax       	= 1.0*3.0 ;    			// Maximum expected Vcc level, in Volts.
                      //const float VccMin        = 2.0*0.6 ;  			// Minimum expected Vcc level, in Volts. for 2xAA Alkaline.
                      //const float VccMax        = 2.0*1.5 ;  			// Maximum expected Vcc level, in Volts.for 2xAA Alkaline.
                      const float VccCorrection 	= 3.30/3.42 ;			// Measured Vcc by multimeter divided by reported Vcc
                      Vcc vcc(VccCorrection); 							// instantiate internal voltage measurement lib
                      const float tempThreshold = 0.02 ; 					// send only if change > treshold (Celcius)
                      const float humThreshold = 0.05 ; 					// send only if change > treshold (% RG)
                      const float voltageThreshold = 0.01 ; 				// send only if change > treshold (Volt)
                      #define MOTION_CHILD_ID 		1
                      #define TEMP_CHILD_ID 			3
                      #define HUM_CHILD_ID 			4
                      #define VOLTAGE_CHILD_ID 		7
                      #define DIGITAL_INPUT_SENSOR 	3  					// motion sensor.  (Only 2 and 3 generates interrupt!)
                      HTU21D SHT21;										// Hum/Temp (SHT12)
                      const unsigned long SLEEP_TIME = 60000UL;			// 60 sec sleep time between reads (seconds * 1000 milliseconds)
                      const int heartbeat = 60 ;							// heartbeat every hour (x times SLEEP_TIME)
                      unsigned long lastHeartbeat = 0 ;
                      float lastHumidity = 0 ;
                      float lastTemperature = 0 ;
                      float lastVoltage = 0 ;
                      boolean lastTripped = false ;
                      // flags to indicate if transmission is needed, heartbeat and/or changes > treshold
                      boolean txHumidity = true ;							// flags to indicate if transmit is needed (time & change driven)
                      boolean txTemperature = true ;
                      boolean txVoltage = true ;
                      boolean txTripped = true ;
                      // standard messages
                      MyMessage temperatureMsg(TEMP_CHILD_ID, V_TEMP);	// SHT temp
                      MyMessage humidityMsg(HUM_CHILD_ID, V_HUM);			// SHT hum
                      MyMessage voltageMsg(VOLTAGE_CHILD_ID, V_VOLTAGE);	// Node voltage
                      MyMessage motionMsg(MOTION_CHILD_ID, V_TRIPPED);	// Motion/ door contact
                      	analogReference(INTERNAL);						// use the 1.1 V internal reference for voltage measurement
                      	//begin(NULL, nodeId);  						// fixed node
                      	Serial.begin(9600);								// reset baud rate for 1 mhz clock rate
                      	sendSketchInfo("AWI small " NODE_TXT, "1.0");
                      	present(TEMP_CHILD_ID, S_TEMP, "Temperature SHT " NODE_TXT);
                      	present(HUM_CHILD_ID, S_HUM, "Humidity SHT " NODE_TXT);
                      	present(VOLTAGE_CHILD_ID, S_MULTIMETER, "Battery " NODE_TXT);
                      	present(MOTION_CHILD_ID, S_MOTION, "Motion " NODE_TXT);
                      	Wire.begin();									// init I2C
                      	SHT21.begin();									// initialize temp/hum
                      	// first read all sensors before possible transmission (save battery)
                          readTempHum();
                      	boolean tripped = false ;//digitalRead(DIGITAL_INPUT_SENSOR) == HIGH;
                      	if (lastTripped != tripped){
                      		lastTripped = tripped ;
                      		txTripped = true ;
                      	// read battery Voltage
                          float voltage = vcc.Read_Volts() ;
                      	if ( abs(voltage - lastVoltage) >= voltageThreshold ){ // update only if threshold exceeded
                      		lastVoltage = voltage ;
                      		txVoltage = true ;
                      	sendSensors() ;											// send sensors (== radio) at the end
                      	sleep(INTERRUPT, CHANGE , SLEEP_TIME );					// sleep and wait for time and motion
                      void readTempHum(void)
                          // SHT2x sensor
                      	// Temperature and Humidity
                      	float humidity = SHT21.readHumidity();
                      	float temperature = SHT21.readTemperature();			// save battery by sending changes only & reading SHT first (>50ms)
                      	if ( abs(humidity  - lastHumidity) >= humThreshold ){	// update only if threshold exceeded
                      		lastHumidity = humidity ;
                      		txHumidity = true ;
                      	if ( abs(temperature - lastTemperature) >= tempThreshold ){
                      		lastTemperature = temperature ;
                      	// Serial.print("SHT_ temp: ");
                      	// Serial.print(temperatureSHT);
                      	// Serial.print(" SHT_ hum: ");
                      	// Serial.println(humidity);
                      // send to gateway depending on tx.. settings
                      void sendSensors()
                      	lastHeartbeat++ ;										// update Heartbeatcount every call
                      	if ( lastHeartbeat > heartbeat) {						// if heartbeat update all sensors & battery status
                      		txTemperature = txHumidity = txVoltage = true ;
                      	    sendBatteryLevel(vcc.Read_Perc(VccMin, VccMax, true));
                      		lastHeartbeat = 0 ;
                      	if (txTemperature){
                      		send(temperatureMsg.set(lastTemperature, 2));		// Send in deg C
                      		txTemperature = false ;
                      	if (txHumidity){
                      		send(humidityMsg.set(lastHumidity, 2));  			// Send in %RH
                      		txHumidity = false ;
                      	if (txVoltage){
                      		send(voltageMsg.set(lastVoltage,2));				//send battery in Volt
                      		txVoltage = false ;
                      	if (txTripped){
                      		send(motionMsg.set(lastTripped?"1":"0"));  			// Send tripped value to gw
                      		txTripped = false ;
                        the cosmic gate
                        I'am not getting this clear / working :(
                        Could somebody help me to complete this 3in1 incl battery monitoring sketch working? Thnx
                          sundberg84S Offline
                          What does your serial or error log tell you when you upload the sketch you have? And which sketch/code do you use at this point?
                            AWIA Offline
                            AWIA Offline
                            AWI
                            @the-cosmic-gate
                            I changed your original sketch a little. It now includes a conditional send for the "tripped" values and groups the conditional sends for all values.
                            I was not able to test as I'm using a different library for the DHT.
                            Have fun..
                            #include <DHT.h>
                            unsigned long SLEEP_TIME = 30000UL; // Sleep time between reads (in milliseconds)
                            DHT dht;
                            float lastTemp = 0 ;
                            float lastHum = 0 ;
                            #else
                              gw.begin();
                              dht.setup(HUMIDITY_SENSOR_DIGITAL_PIN. DHT22);
                               #ifdef DEBUG
                               #ifdef DEBUG
                              if (tripped != lastTripped ) {
                                if (!metric) {
                                  lastHum = humidity;
                              the cosmic gate
                              Thnx a lot @AWI
                              there was 1 verification error,
                              changed it, to :
                              #include <DHT.h>
                              DHT dht;
                              float lastHum = 0 ;
                              #else
                                gw.begin();
                                 #ifdef DEBUG
                                 #ifdef DEBUG
                                  if (!metric) {
                                    lastHum = humidity;
                              uploading now
                                the cosmic gate
                                working nice for 2 day's now !
                                Thnx a lot @AWI !!!
                                  the cosmic gate
                                  Something strange: when I look in the IDE console the battery % is displayed. But using Domoticz there's no battery % display / selectable ? What's wrong , or do I forget something ?
                                  • icebobI Offline
                                    icebobI Offline
                                    icebob
                                    In Domoticz you can see the battery level in Setup->Devices.
                                    If you would like to see on a chart, you have to send the battery level or voltage to the controller as a sensor value too. After it, you can see as this:
                                    • icebobI icebob
                                      T Offline
                                      T Offline
                                      Tronix
                                      @icebob
                                      Hi, I'm a newbee just started with MySensors. I built the first temp/hum sensor, and I'm trying to plot the battery level in a graph too. In this discussion you mention that I need to send the battery level to the controller as sensor value. Can you please share with me the code which I should use? Thanks a lot.
                                      Marco
                                      • icebobI Offline
                                        icebobI Offline
                                        icebob
                                        Yes, I can.
                                        This is the definition of message for battery level:
                                        // Battery sensor (A0)
                                        #define CHILD_ID_BATTERY 199
                                        #define BATTERY_SENSOR_ANALOG_PIN 0
                                        MyMessage msgBattery(CHILD_ID_BATTERY, V_VOLTAGE);
                                        And this is the sender function:
                                        #define VBAT_PER_BITS 0.003363075
                                        #define VMIN 1.9  // Battery monitor lower level. Vmin_radio=1.9V
                                        #define VMAX 3.00  // Vmin<Vmax<=3.44
                                        #define VCC_CORRECTION (3.4 / 3.33)
                                        int lastBatteryLevel;
                                        bool sendBatteryLevel(bool force = false) {
                                          int value = analogRead(BATTERY_SENSOR_ANALOG_PIN);
                                          float batVoltage  = value * VBAT_PER_BITS / VCC_CORRECTION;
                                          int batLevel = static_cast<int>(((batVoltage-VMIN)/(VMAX-VMIN))*100.);
                                          if (batLevel != lastBatteryLevel || force) {
                                            gw.sendBatteryLevel(batLevel);
                                            gw.send(msgBattery.set(batVoltage, 2));
                                            lastBatteryLevel = batLevel;
                                          return true;
                                        • T Offline
                                          T Offline
                                          Tronix
                                          Great, thanks for your quick response. Implementing now. Looks good.
