  3. Help with 2 LED Dimmer Sketch. Can't compile, not sure why exactly
5 Posts 2 Posters 2.7k Views
  • D
    D
    drock1985
    I'm trying to duplicate the LED dimmer sketch, and have one dimmer on pin 3 and the second on pin 4. So far, from what I can see, everything should work but of course, it's not and I can't compile. I'm getting an error about an int not being defined, even though it is.
    Could someone take a second look at this please and see if I went wrong somewhere?
    Thanks!
     * Version 1.0 - 6-December-2015, Derrick Rockwell
     *This sketch uses two 30 bulb, 3mm LED holiday light strings. These
     *can usually be found in most dollar stores/hardware stores and are
     *battery powered. This sketch uses digital pins 3 and 4 to power two
     *a string of lights each. Ex, one can control white lights the other
     *could control multi-colour lights.
    #define SN "HolidayLEDDeskLights"
    #define SV "1.0"
    #define MLED_PIN 3      // Pin Multi-Coloured LED's will attached to
    #define WLED_PIN 4      // Pin White-Coloured LED's will attached to
    #define FADE_DELAY 10  // Delay in ms for each percentage fade up/down (10ms = 1s full-range dim)
    #define CHILD_ID0 3
    #define CHILD_ID1 4
    static int currentLevelM = 0;  // Current dim level...
    static int currentLevelW = 0;  // Current dim level...
    MyMessage dimmerMsgM(MLED_PIN, V_DIMMER);
    MyMessage lightMsgM(MLED_PIN, V_LIGHT);
    MyMessage dimmerMsgW(WLED_PIN, V_DIMMER);
    MyMessage lightMsgW(WLED_PIN, V_LIGHT);
     * Dimmable LED initialization method
      Serial.println( SN );
      Serial.println( SV );
      gw.begin( incomingMessage );
      // gw.begin( incomingMessageW );
      gw.present( MLED_PIN, S_DIMMER );
      gw.present( WLED_PIN, S_DIMMER );
      gw.sendSketchInfo(SN, SV);
      // Pull the gateway's current dim level - restore light level upon sendor node power-up
      gw.request( MLED_PIN, V_DIMMER );
      gw.request( WLED_PIN, V_DIMMER );
     *  Dimmable LED main processing loop
      gw.process();
    //For Multi Coloured Lights
    if (message.type == V_LIGHT || message.type == V_DIMMER) {
          if (message.sensor <= 2){
              //0: All Dimmers
              //1: LED 1
              //2: LED 2
              requestedLevel *= ( message.type == V_LIGHT ? 100 : 1 );
              if ((message.sensor == CHILD_ID0) || (message.sensor == 0)){
                fadeToLevelM ( requestedLevel, MLED_PIN );
                gw.send(lightMsgM.set(requestedLevel > 0 ? 1 : 0));
                gw.send(dimmerMsgM.set(requestedLevel) );
              if ((message.sensor == CHILD_ID1) || (message.sensor == 0)){
                fadeToLevelW( requestedLevel, WLED_PIN );
                gw.send(light2Msg.set(requestedLevel > 0 ? 1 : 0));
                gw.send(dimmer2Msg.set(requestedLevel) );
     *  This method provides a graceful fade up/down effect
     // For Multi Coloured Lights
    void fadeToLevelM( int toLevel ) {
      int delta = ( toLevel - currentLevelM ) < 0 ? -1 : 1;
      while ( currentLevelM != toLevel ) {
        currentLevelM += delta;
        analogWrite( MLED_PIN, (int)(currentLevelM / 100. * 255) );
        delay( FADE_DELAY );
    void fadeToLevelW( int toLevel ) {
      int delta = ( toLevel - currentLevelW ) < 0 ? -1 : 1;
      while ( currentLevelW != toLevel ) {
        currentLevelW += delta;
        analogWrite( WLED_PIN, (int)(currentLevelW / 100. * 255) );
    My Projects
    2 Door Chime Sensor
    Washing Machine Monitor
    • BartEB
      BartEB
      BartE
      @drock1985
      There where a couple of errors try this code
      #define SV "1.0"
      #define CHILD_ID0 3
      #define CHILD_ID1 4
        gw.process();
                //0: All Dimmers
                //1: LED 1
                //2: LED 2
                  fadeToLevel ( requestedLevel, MLED_PIN, &currentLevelM );
                  fadeToLevel( requestedLevel, WLED_PIN, &currentLevelW );
                  gw.send(lightMsgW.set(requestedLevel > 0 ? 1 : 0));
                  gw.send(dimmerMsgW.set(requestedLevel) );
      void fadeToLevel( int toLevel, int pin, int *currentLevel ) {
        int delta = ( toLevel - (*currentLevel) ) < 0 ? -1 : 1;
        while ( (*currentLevel) != toLevel ) {
          (*currentLevel) += delta;
          analogWrite( pin, (int)((*currentLevel) / 100. * 255) );
      • D
        D
        drock1985
        Hi @BartE
        Thanks for your help. The code compiles, and I think I see what was preventing it (as to the why i'm still not sure). The devices show up in domoticz, and they seem to try and communicate but there is no interaction from the lights (no one/off/dimming). And when I switch one or the other off, it affects the other.
        Will keep looking into this, thanks again!
        My Projects
        2 Door Chime Sensor
        • D
          D
          drock1985
          wrote on last edited by drock1985
          Huh, I think I just got it. Had to remove the if (message.sensor <=2) string, compiled, and works great.
          Thanks again @BartE , major creds to you.
          Final Code (Or, so far final)
          #define SV "1.0"
          #define CHILD_ID0 3
          #define CHILD_ID1 4
            gw.process();
                // if (message.sensor <= 2)
          EDIT: II always speak too soon. The Multi-coloured lights are dimming, just not the white ones. It's all or nothing.
          My Projects
          2 Door Chime Sensor
          • D
            D
            drock1985
            Ok, figured out and it's my stupid. Didn't put the second LED on a PWM pin, therefore, no modulation!
            My Projects
            2 Door Chime Sensor
