  3. RELAY 433MHZ + KEYPAD 4x4 COMANDER (vera-domoticz)
3 Posts 2 Posters 6.0k Views 1 Watching
  • Michel - ItM
    Michel - ItM
    Michel - It
    wrote on last edited by Michel - It
    Hello everyone , I'm trying to create a gateway with the following modules ;
    433 sender
    4x4 keypad
    Arduino mini / nano
    NRF24L01
    10uf Capacitor
    he project is in development I'm stuck in the insertion of the keypad would use 4 -pin analog and 4 digital pins . I welcome suggestions on code.
    link where it started my idea: http://forum.mysensors.org/topic/1557/combined-mysensor-gateway-with-433mhz-transmitter-homeeasy-klik-aan-klik-uit
    link original code which I then edited: https://github.com/meijeren/MySensors-RF433-Node
    https://codebender.cc/sketch:209936
    • BartEB
      BartEB
      BartE
      @Michel-It There is an Adruino module for scanning 4x4 key matrixs. You can find it here: http://playground.arduino.cc/Main/KeypadTutorial
      • Michel - ItM
        Michel - ItM
        Michel - It
        I have one better, but how to implement it in code mysensor?Schematic-Keypad.png
        New Code > sketch + Library > https://codebender.cc/sketch:183503
        Original Code
        #include <MyTransportNRF24.h>
        #include <MyHwATMega328.h>
        #include <Wire.h>
        #include <RCSwitch.h>
        RCSwitch mySwitch = RCSwitch();
        #define NODE_ID          165
        #define NODE_VERSION     "1.1"
        #define NODE_DESCRIPTION "MikRelay"
        #define NUMFLAKES 10
        #define XPOS 0
        #define YPOS 1
        #define DELTAY 2
        #define RADIO_TX_PIN 2
        #define NUMBER_OF_RELAYS 11 // Total number of attached relays
        typedef struct
          unsigned long address;
          unsigned char unit;
          bool dimmer;
        } MikParams;
        MikParams Mik_PARAMS[NUMBER_OF_RELAYS] =
          {87311, 24, false},
          {87500, 24, false},
          {87491, 24, false},
          {87359, 24, false},
          {87539, 24, false},
          {87548, 24, false},
          {87536, 24, false},
          {87356, 24, false},
          {87503, 24, false},
          {4011779, 24, false},
          {4011968, 24, false}
        //MyTransportRFM69 radio;
        //MySigningNone signer;
        MyHwATMega328 hw;
        MySensor gw(radio, hw);
          mySwitch.enableTransmit(RADIO_TX_PIN);
          // init done
          // Show image buffer on the display hardware.
          // Since the buffer is intialized with an Adafruit splashscreen
          // internally, this will display the splashscreen.
          gw.begin(incomingMessage, NODE_ID, false);
          delay(2000);
          gw.sendSketchInfo(NODE_DESCRIPTION, NODE_VERSION);
          // Fetch relay status
          for (int sensor = 1; sensor <= NUMBER_OF_RELAYS; sensor++) {
            gw.present(sensor, S_LIGHT);
          gw.process();
          if ((message.sensor < 1) && (message.sensor >= NUMBER_OF_RELAYS))
            return;
          if (message.type == V_LIGHT)
            mySwitch.send(Mik_PARAMS[message.sensor - 1].address, Mik_PARAMS[message.sensor - 1].unit);
            // Store state in eeprom
            // Write some debug info
            Serial.print(message.sensor);
            Serial.print(", Miks: ");
            Serial.print(Mik_PARAMS[message.sensor - 1].address);
            Serial.print(Mik_PARAMS[message.sensor - 1].unit);
          else if (message.type == V_DIMMER)
        I know that not everyone. but there is some kind soul can help me?
        I see you do not laugh!
