  3. 2 channel relais with 2 buttons sending strange values for on:off
18 Posts 5 Posters 9.3k Views 2 Watching
  • AndurilA
    AndurilA
    Anduril
    I have an 2 channel relais device with two buttons attached to controll them locally (to be integrated in wall light switch). Here is the sketch:
    #include <Bounce2.h>
    #define RELAY_1  6  // Arduino Digital I/O pin number for first relay (second on pin+1 etc)
    #define BUTTON1_ID 4
    #define BUTTON_PIN1  4  // Arduino Digital I/O pin for button/reed switch
    #define BUTTON2_ID 5
    #define BUTTON_PIN2  5  // Arduino Digital I/O pin for button/reed switch
    // Instantiate a Bounce object
    Bounce debouncer1 = Bounce();
    // Instantiate another Bounce object
    Bounce debouncer2 = Bounce();
    int oldValueB1 = -1;
    int oldValueB2 = -1;
    MyMessage msgB1(BUTTON1_ID, V_LIGHT);
    MyMessage msgB2(BUTTON2_ID, V_LIGHT);
    MyMessage msgR1(1, V_LIGHT);
    MyMessage msgR2(2, V_LIGHT);
      gw.begin(incomingMessage, 16, false);
      gw.sendSketchInfo("Relay with Button", "1.0");
      // Setup the first button with an internal pull-up :
      pinMode(BUTTON1_ID, INPUT_PULLUP);
      // After setting up the button, setup the Bounce instance :
      debouncer1.attach(BUTTON1_ID);
      debouncer1.interval(5); // interval in ms
      // Setup the second button with an internal pull-up :
      pinMode(BUTTON2_ID, INPUT_PULLUP);
      debouncer2.attach(BUTTON2_ID);
      debouncer2.interval(5); // interval in ms
      // Fetch relay status
      for (int sensor = 1, pin = RELAY_1; sensor <= NUMBER_OF_RELAYS; sensor++, pin++) {
        gw.present(sensor, S_LIGHT);
        pinMode(pin, OUTPUT);
        digitalWrite(pin, 0);
      gw.present(BUTTON1_ID, S_LIGHT);
      gw.present(BUTTON2_ID, S_LIGHT);
      // Update the Bounce instances :
      debouncer1.update();
      debouncer2.update();
      int value1 = digitalRead(4);//debouncer1.read();
      int value2 = debouncer2.read();
      if (value1 != oldValueB1) {
        Serial.print("Setze Button1 auf");
        Serial.println(value1);
        gw.send(msgB1.set(value1 == HIGH ? 1 : 0));
        oldValueB1 = value1;
        digitalWrite(6,value1);
        Serial.println("Schalte Relais");
        gw.send(msgR1.set(value1 == HIGH ? 1 : 0), true);
      if (value2 != oldValueB2) {
        Serial.print("Setze Button2 auf");
        Serial.println(value2);
        gw.send(msgB2.set(value2 == HIGH ? 1 : 0));
        oldValueB2 = value2;
        digitalWrite(7,value1);
        gw.send(msgR2.set(value2 == HIGH ? 1 : 0), true);
      gw.process();
      if (message.isAck())
        // Change relay state
        digitalWrite(message.sensor - 1 + RELAY_1, message.getBool() ? RELAY_ON : RELAY_OFF);
        // Store state in eeprom
        // Write some debug info
        Serial.print(message.sensor);
    At first everything is working fine. When using the pins 4 and 5 as local switch relais switches and state is send to gw. In MYSController I see the message with payload 1 or 0 as expected. After some time (few minutes) the payload changes to 1107296256 (instead of 0) and 1107296257 (instead of 1). Of course my controller (pimatic) can not interpret this and does not know what to do and does not set status of relais accordingly.
    But sending 0 or 1 from controller (both pimatic and MYSController) works all the time. Even manually contructing a message with payload 1107296256 or 1107296257 switches the relais to on and off.
    Does anyone see a problem in my sketch or knows that strange number?
    Best regards,
    Anduril
      Are you using an ESP8266? If so, this thread seems to discuss a similar problem.
      • AndurilA
        AndurilA
        Anduril
        @mfalkvidd thank you very much. I use a ESP as gateway and was following this thread, but must have missed that problem in the 200+ posts. I will try to use newest development branch and see if problem still exists.
        • AndurilA
          AndurilA
          Anduril
          ok tested that again, installed a fresh mysensors lib (stable master, downloaded 11.01.16) and first test ran fine. Relay gives 1 or 0 as status, worked even for hours.
          But after powering another node it starts again. Sad that I have no third one here at the moment to test if its a general problem with more than one node or specific to this one. I also reflashed the problematic node (with dht and switch), but nothing changed. Is it possible that a message from the DHT-node brings the ESP to a special mode/error state that makes it misinterprete 0 and 1 readings to 1107296257?
          • AndurilA
            AndurilA
            Anduril
            Did some further tests. As it seems to be related with the ESP gateway maybe @Yveaux has a hint for me.
            When starting the relay node it works fine, until the first message of the DHT node is received. After that it starts to get strange. I already tried to recompile all sketches with newest MS 1.5.1 and cleared all eeproms (except the gw, is that neccesary?)
            just for completeness the sketch of my DHT node. If someone finds something strange in there please let me know.
            #include <DHT.h>
            #define CHILD_ID 3
            #define BUTTON_PIN  3  // Arduino Digital I/O pin for button/reed switch
            #define CHILD_ID_HUM 1
            #define CHILD_ID_TEMP 2
            #define HUMIDITY_SENSOR_DIGITAL_PIN 5
            unsigned long SLEEP_TIME = 1000; // Sleep time between reads of switch (in milliseconds)
            unsigned int debounce_nr = 10; // No of cycles doing button test
            unsigned int cycle_min = 10; // No of cycles min for DHT read
            unsigned int cycle_max = 60; // No of cycles max for DHT read (must be cycle_min*n)
            float Temp_dif =0.3; // change in Temp to trigger send
            float Hum_dif =3; // change in Hum to trigger send
            DHT dht;
            float lastTemp;
            float lastHum;
            boolean sendNow = true;
            Bounce debouncer = Bounce();
            int oldValue=-1;
            unsigned int debouncecycle=0;
            unsigned int cycle=0;
            unsigned int cycle_multiplier = 1;
            float temperature;
            float humidity;
              gw.begin();
              gw.sendSketchInfo("DHT with Switch", "1.0");
             // Setup the button
              pinMode(BUTTON_PIN,INPUT);
              // Activate internal pull-up
              debouncer.attach(BUTTON_PIN);
              debouncer.interval(5);
              gw.present(CHILD_ID, S_DOOR);
              delay(10);
              delay(10);
              debouncer.update();
              // Get the update value
              int value = debouncer.read();
              if (value != oldValue) {
                 // Send in the new value
                 gw.send(msg.set(value==HIGH ? 1 : 0));
                 oldValue = value;
              if (cycle >= cycle_min * cycle_multiplier) {
              cycle_multiplier=cycle_multiplier+1;
              temperature = dht.getTemperature();
              //Serial.print("Temp: ");
              //Serial.print(temperature);
              //Serial.print("LastTemp: ");
              //Serial.println(lastTemp);
              if (isnan(temperature)) {
              } else if ((temperature < lastTemp - Temp_dif) or (temperature > lastTemp + Temp_dif)) {
                sendNow=true;
                Serial.println("SendNow set by Temp");
              humidity = dht.getHumidity();
              //Serial.print("Hum: ");
              //Serial.print(humidity);
              //Serial.print("LastHum: ");
              //Serial.println(lastHum);
              if (isnan(humidity)) {
              } else if ((humidity < lastHum - Hum_dif) or (humidity > lastHum + Hum_dif)) {
                  sendNow=true;
                  Serial.println("SendNow set by Hum");
              if (cycle >= cycle_max){
                sendNow=true;
                Serial.println("SendNow set by cycle_max");
              if (debouncecycle>debounce_nr){
              gw.sleep(SLEEP_TIME); //sleep a bit
              debouncecycle=0;
              cycle=cycle+1;
              //Serial.print("Anzahl Zyklen: ");
              Serial.println(cycle);
              debouncecycle=debouncecycle+1;
              Serial.print(debouncecycle);
              if (sendNow){
                sendNow = false;
                cycle=0;
                cycle_multiplier=1;
                Serial.println("Zyklen zurueckgesetzt, Daten gesendet.");
                lastTemp = temperature;
                lastHum = humidity;
            YveauxY 1 Reply Last reply
            • AndurilA Anduril
              #include <DHT.h>
              #define CHILD_ID 3
              DHT dht;
              float lastTemp;
              float lastHum;
              int oldValue=-1;
              float temperature;
              float humidity;
                gw.begin();
               // Setup the button
                delay(10);
                delay(10);
                debouncer.update();
                   oldValue = value;
                  sendNow=true;
                    sendNow=true;
                  sendNow=true;
                debouncecycle=0;
                cycle=cycle+1;
                if (sendNow){
                  sendNow = false;
                  cycle=0;
                  cycle_multiplier=1;
                  lastHum = humidity;
              YveauxY
              YveauxY
              @Anduril is the second node running the same MySensors version as the other node and gateway?
              What Arduino core version are you using for ESP support?
              AndurilA 1 Reply Last reply
              • V
                V
                vampircik
                Used: C:\Users\vampircik\Documents\Arduino\libraries\Bounce2
                Not used: C:\arduino-1.6.3\libraries\Bounce2
                I tried to upload a sketch, an error says no such library
                • YveauxY Yveaux
                  AndurilA
                  AndurilA
                  Anduril
                  @Yveaux yeah I compiled all 2 nodes and the gw just yesterday with the same MySensors version. With Arduino core version you mean the version of Arduino IDE? 1.6.6
                  Is it necessary/usefull/possible to do a eeprom reset on the gw?
                  Btw sometimes MYSController does not recognice all presentation messages. Is that somehow a problem? I don't know why this happens as all my nrf are equiped with 4.7µF (node in question also tried with 2 caps).
                    This is how to check esp core version http://forum.mysensors.org/topic/2708/soft-wdt-reset-on-esp8266/13
                    • AndurilA
                      AndurilA
                      Anduril
                      • V
                        V
                        vampircik
                        these relays your sketch works well, but is not displayed correctly in the controller
                        http://ru.aliexpress.com/item/2-channel-New-2-channel-relay-module-relay-expansion-board-5V-low-level-triggered-2-way/1617727658.html
                        and with these relay failures. why is that? although "RelayWithButtonActuator" in truth it works with one group
                        http://ru.aliexpress.com/item/10PCS-LOT-New-original-solid-state-relay-G3MB-202P-DC-AC-PCB-SSR-In-5VDC-Out/32339505849.html
                        • AndurilA
                          AndurilA
                          Anduril
                          @vampircik I don't realy understand what you tried to say. At the moment I have no real relays connected but simply LEDs for testing purposes.
                          @Yveaux I updated the ESP8266 definitions to ver 2.0.0. But now I can't upload a sketch. I get this message:
                          warning: espcomm_sync failed
                          error: espcomm_open failed
                          Do you know what that means?
                          • AndurilA Anduril
                            YveauxY
                            YveauxY
                            Did you select the right target board & settings? They did make some changes there with 2.0.0
                            • AndurilA
                              AndurilA
                              Anduril
                              I just left them on standard as before...
                              just found one option named " reset mothode" which was ck and now I set it to nodemcu (only option that seems reasonable to me by it's name). Just worked to upload the sketch. I will do further tests and report back.
                              • AndurilA
                                AndurilA
                                Anduril
                                Still getting those strange numbers for relay status on or off. I will build another node to test this new constellation.
                                • AndurilA
                                  AndurilA
                                  Anduril
                                  Now I tested with a third node the check. Also after node 3 sending data my 0 and 1 from the relay node become large numbers. One thing that seems strange to me is the behavior during reboot of the temp/hum node. First this node is active and sending temp and hum data. Readings from relay are strange as usual. When rebooting the relay signals turn to be 0 and 1 after the temp/hum node has presented itself to the gateway. But after sending the first data for temp/hum it is again receiving those large numbers. Does this make any sense for you @Yveaux?
                                  • AndurilA
                                    AndurilA
                                    Anduril
                                    I updated my gateway to newest dev version and now my nodes are communicating correctly (not updated, still 1.5.3). So the problem seems to be gone in 2.0, but I think it would still be nice to know what caused it for those not willing to upgrade to dev branch.
                                    For @netram and @kr0815 (and maybe others) who had similiar problems: dev branch fixes this issue.
                                    • N
                                      N
                                      netram
                                      Sweet! Thanks for the feedback @Anduril .
