  3. Mysensors 1.5 and NRF24L01 without +
radio initwithout +nrf24l01
5 Posts 3 Posters 2.5k Views 2 Watching
  • F
    F
    Floca
    OS: Windows 7 64bit
    Arduino IDE: 1.6.7
    MySensors: 1.5 (transfer set to 1MBPS)
    Arduino: Nano CH340
    Radio: NRF24L01 (without +)
    Ethernet IF: W5100 (red) (softspi set in myconfig)
    i have Problems with my nrf24l01 without the plus, because i can't get it to work and new Radio's with plus are ordered but take about 3 weeks until they arrive.
    I have seen some ideas here in the Forum to set the Datarate to 1MBPS but i get "radio init fail" error.
    I tried an extarnal power supply but there is no change.
    Is there Someone who can help me with my bad nrf24l01 without +?
    Regards
      Setting speed to 1Mbps and removing the "sanity check" here should work:
      https://github.com/mysensors/Arduino/blob/master/libraries/MySensors/MyTransportNRF24.cpp#L35-L37
      • F
        F
        Floca
        Hi Hek,
        that is a great solution, thanks, the gateway is starting without problems (Serial Monitor).
        I have the problem, that the W5100 is not working correctly. I have two of them with the 5v input. The Modules in the mysensors Shop are the same as mine (red PCB).
        They are blinking on tx and link, but i cant get them working with my FritzBox Router. I have added the IP from the Script (192.168.178.65) and the MAC byte TCP_MAC[] = { 0x00, 0x24, 0x8D, 0x3E, 0x29, 0x1C }; 00:24:8D:3E:29:1C but it isn't working :(
        Any Solutions?
        regards
          how did you choose that mac address? It is for a Sony product. The mac address needs t be unique in your local network. The ip address also needs to be unique and it needs to be in the same range as your local network.
          • F
            F
            Floca
            Yes its for an Sony Product, because i tested around a bit. The IP is unique and the mac was also tested with DE:AD:BE:EF:FE:ED with no results :(
