  3. Mysensor hang on gw.send.... (and possibly roasting radios)
4 Posts 3 Posters 1.9k Views 2 Watching
  • S Offline
    stevebus
    Hi all,
    Mylibrary version: 1.5
    Arduino Pro Mini (power LED cut to save battery)
    DHT11 temperature sensor
    3.3V FTDI USB cable
    I'm trying to build a battery powered temperatures sensor for my wife's green house. I have the device wake up every 15 minutes (will eventually do longer sleep times).
    However, I'm having trouble with the code 'locking up' (I'm assuming it's hitting one of the "while(1)" loops in the mysensor code). It seems to happen after somewhere between 12 and 14 hours of running fine. I've pasted the code below, as well as a debug trace. It seems to be locking up somewhere in the gw.send(tempF, 0) call, as it's sending the updated temperature. This has happened in the same place several times. Some of the transmits fail, but that may be due to the fact that my 'dev' laptop has been probably on the outer edge of the range for the radio. But the same behavior happens even well within range. It also doesn't matter if I have it battery powered (two AAs) or powered from my laptop and FTDI cable.
    When it hangs, the onboard "pin 13" LED remains lit (so presumably the SCK connected to pin 13) is held high at that point).
    What is the best method folks have for debugging/troubleshooting these hangs? Do you just go into the mysensor code and riddle it with Serial.prints? I can do that, just want to minimize the dev churn as it takes it between 12 and 24 hours to fail :-) ). Any other tips for troubleshooting this?
    it may be related, but maybe not. I also seem to have killed two radios while trying to figure this out. Some times, after a certain number of hitting the 'reset' button the mini, I start getting "radio init failed" messages. Swapping out for a new radio brings it back. This has happened twice. However, it does NOT correspond to the hang-ups (i.e. I can 'reset' after a hang up and have it work again fine for a while). So maybe related, maybe not. Everything is wired on a breadboard right now. I power the radio and DHT11 from the VCC pin of the Mini.
    Also, for the loop in the code below -- to try to improve a little of the accuracy of the DHT11, I read 10 values and calculate the average before sending the temps (eventually I'll be replacing the DHT with something more accurate). Just testing at this point.
    Anyway - the code
    #include "DHT.h"
    //#define DEBUG
    DHT dht;
    #define NUMSAMPLES 10
    int fTotal = 0.0;
    int iCount = 0;
    float humidity = 0.0;
    float temperature = 0.0;
    float averageTemp = 0.0;
    int BATTERY_SENSE_PIN = A0;
    int oldBatteryPcnt = 0;
    // 15 minutes
    #define SLEEP_TIME 900000   // in milliseconds
    MyMessage msg(0,V_TEMP);
       analogReference(INTERNAL1V1);
    #else
       analogReference(INTERNAL);
      gw.begin();
      gw.sendSketchInfo("Temperature Sensor/DHT/Battery", "1.0");
      gw.present(0, S_TEMP);
    //  Serial.begin(9600);
    #ifdef DEBUG
      Serial.println();
      Serial.println("Status\tHumidity (%)\tTemperature (C)\t(F)");
      dht.setup(2); // data pin 2
      // put your main code here, to run repeatedly:
        gw.process();
        bool isMetric = gw.getConfig().isMetric;
    //    bool isMetric = false;
     #ifdef DEBUG
        Serial.println("ismetric = " + String(isMetric));
        for(iCount = 0; iCount < NUMSAMPLES; iCount++)
            humidity = dht.getHumidity();
            temperature = dht.getTemperature();
    #ifdef DEBUG
            Serial.print(dht.getStatusString());
            Serial.print("\t");
            Serial.print(humidity, 1);
            Serial.print("\t\t");
            Serial.print(temperature, 1);
            Serial.println(dht.toFahrenheit(temperature), 1);
            fTotal += temperature;
        averageTemp = fTotal / (NUMSAMPLES * 1.0);
    #ifdef DEBUG
        Serial.print("average tempC: ");
        Serial.println(averageTemp);
        fTotal = 0.0;
        if(isMetric)
    #ifdef DEBUG
          Serial.println("Sending C data..." + String(averageTemp));
          gw.send(msg.set(averageTemp, 0));
        else
          float tempF = (averageTemp * 1.8) + 32.0;
    #ifdef DEBUG
          Serial.println("Sending F data..." + String(tempF));
          gw.send(msg.set(tempF, 0));
       // get the battery Voltage
       #ifdef DEBUG
       Serial.println(sensorValue);
       float batteryV  = sensorValue * 0.003363075;
       #ifdef DEBUG
       Serial.print(batteryV);
       Serial.println(" V");
       Serial.print(batteryPcnt);
       Serial.println(" %");
    #ifdef DEBUG
         Serial.println("Sending updated battery level");
         oldBatteryPcnt = batteryPcnt;
    #ifdef DEBUG
        Serial.println("nighty night...");
        gw.sleep(SLEEP_TIME);
    #ifdef DEBUG
      Serial.println("Good morning!");
    and the debug lines...
    send: 3-3-0-0 s=255,c=0,t=17,pt=0,l=3,sg=0,st=ok:1.5
    send: 3-3-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,st=ok:0
    read: 0-0-3 s=255,c=3,t=6,pt=0,l=1,sg=0:I
    sensor started, id=3, parent=0, distance=1
    send: 3-3-0-0 s=255,c=3,t=11,pt=0,l=25,sg=0,st=ok:Temperature Sensor/DHT/Ba
    send: 3-3-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,st=ok:1.0
    send: 3-3-0-0 s=0,c=0,t=6,pt=0,l=0,sg=0,st=ok:
    Status Humidity (%) Temperature (C) (F)
    gw config= 0
    OK 34.0 23.0 73.4
    OK 33.0 23.0 73.4
    OK 33.0 23.0 73.4
    OK 33.0 23.0 73.4
    OK 32.0 23.0 73.4
    OK 33.0 23.0 73.4
    OK 33.0 23.0 73.4
    OK 33.0 23.0 73.4
    OK 33.0 23.0 73.4
    OK 32.0 23.0 73.4
    average tempC: 23.00
    Sending F data...73.40
    send: 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:73
    1023
    Battery Voltage: 3.44 V
    Battery percent: 102 %
    send: 3-3-0-0 s=255,c=3,t=0,pt=1,l=1,sg=0,st=ok:102
    night night...
    Good morning!
    gw config= 0
    OK 33.0 23.0 73.4
    TIMEOUT nan nan nan
    OK 33.0 22.0 71.6
    OK 33.0 22.0 71.6
    OK 33.0 22.0 71.6
    OK 33.0 22.0 71.6
    OK 33.0 22.0 71.6
    OK 34.0 22.0 71.6
    OK 34.0 22.0 71.6
    OK 33.0 22.0 71.6
    average tempC: 17.60
    Sending F data...63.68
    send: 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:64
    1023
    night night...
    Good morning!
    gw config= 0
    OK 33.0 22.0 71.6
    OK 32.0 21.0 69.8
    OK 34.0 22.0 71.6
    OK 32.0 22.0 71.6
    OK 32.0 21.0 69.8
    OK 31.0 22.0 71.6
    OK 33.0 22.0 71.6
    OK 33.0 22.0 71.6
    OK 33.0 22.0 71.6
    OK 33.0 22.0 71.6
    average tempC: 21.80
    Sending F data...71.24
    send: 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:71
    1023
    night night...
    Good morning!
    gw config= 0
    OK 33.0 21.0 69.8
    OK 34.0 21.0 69.8
    OK 33.0 21.0 69.8
    OK 33.0 21.0 69.8
    OK 33.0 21.0 69.8
    OK 33.0 21.0 69.8
    OK 33.0 21.0 69.8
    OK 33.0 21.0 69.8
    OK 33.0 21.0 69.8
    OK 33.0 21.0 69.8
    average tempC: 21.00
    Sending F data...69.80
    send: 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:70
    1023
    night night...
    Good morning!
    gw config= 0
    OK 33.0 21.0 69.8
    OK 29.0 17.0 62.6
    OK 31.0 18.0 64.4
    OK 31.0 17.0 62.6
    OK 32.0 17.0 62.6
    OK 30.0 17.0 62.6
    OK 30.0 17.0 62.6
    OK 32.0 17.0 62.6
    OK 40.0 20.0 68.0
    OK 31.0 17.0 62.6
    average tempC: 17.80
    Sending F data...64.04
    1023
    night night...
    Good morning!
    gw config= 0
    OK 30.0 17.0 62.6
    OK 35.0 17.0 62.6
    OK 35.0 17.0 62.6
    OK 35.0 17.0 62.6
    OK 35.0 17.0 62.6
    OK 35.0 17.0 62.6
    OK 35.0 17.0 62.6
    OK 35.0 17.0 62.6
    OK 35.0 17.0 62.6
    OK 35.0 17.0 62.6
    average tempC: 17.00
    Sending F data...62.60
    send: 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:63
    1023
    night night...
    << some of the rounds cut out for brevity.........>>
    Good morning!
    gw config= 0
    OK 22.0 22.0 71.6
    OK 23.0 22.0 71.6
    OK 23.0 22.0 71.6
    OK 22.0 22.0 71.6
    OK 22.0 22.0 71.6
    OK 22.0 22.0 71.6
    OK 22.0 22.0 71.6
    OK 22.0 22.0 71.6
    OK 22.0 22.0 71.6
    OK 22.0 22.0 71.6
    average tempC: 22.00
    Sending F data...71.60
    send: 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=ok:72
    1023
    night night...
    Good morning!
    gw config= 0
    OK 22.0 22.0 71.6
    OK 23.0 21.0 69.8
    OK 22.0 21.0 69.8
    OK 22.0 21.0 69.8
    OK 22.0 21.0 69.8
    OK 22.0 21.0 69.8
    OK 22.0 21.0 69.8
    OK 25.0 21.0 69.8
    OK 22.0 21.0 69.8
    OK 25.0 21.0 69.8
    average tempC: 21.10
    Sending F data...69.98
    send: 3-3-0-0 s=0,c=1,t=0,pt=7,l=5,sg=0,st=fail:70
    1023
    night night...
    Good morning!
    gw config= 0
    OK 22.0 21.0 69.8
    OK 22.0 21.0 69.8
    OK 22.0 21.0 69.8
    OK 22.0 21.0 69.8
    OK 22.0 21.0 69.8
    OK 22.0 21.0 69.8
    OK 22.0 21.0 69.8
    OK 22.0 21.0 69.8
    OK 22.0 22.0 71.6
    OK 22.0 22.0 71.6
    average tempC: 21.20
    Sending F data...70.16
    you can see that it dies when trying to send the temperature data.
    Any thoughts?
    --Steve
    Vera Edge/UI7; mysensors; Arduino's and RPIs; data posted to Azure for an IoT 'dashboard' of my house
    Opinions expressed here are my own and do not necessarily reflect Microsoft's feelings on a given topic :-)
    • B Offline
      B Offline
      BartE
      @stevebus looking at your code i would move this line
      to the setup() part and make isMetric a global variable each getConfig call is message to the gateway
      And secondly you could add a
      gw.wait(500);
      after sending the temperature message to the gateway followed by an extra
       gw.proccess();
      to process any acknowledges from the gw
      • mfalkviddM Offline
        This wouldn't solve the entire problem, but have you tried pulling the power instead of pressing the reset button? Your radio problem might be related to http://forum.mysensors.org/topic/2738/are-we-initializing-the-nrf24l01-correctly and switching the radios causes a "proper" re-initialization, thus making the radio work again. Maybe your old radios work just fine.
        • S Offline
          stevebus
          @BartE - thanks for the tips. are you suggesting these may fix my hanging issue? or just generally good mysensors coding practices and can't hurt? :-)
          @mfalkvidd - Certainly could be my problem. Pulling power doesn't reset the radio, but I've only tried that after the radio won't re-initialize with the reset. So maybe I should always restart by power cycling? Any way to 'recover' the bad radios, they don't work even after a power cycle. Has anyone added the code to properly re-initialize the radio yet?
          12.1k
