  3. [SOLVED] Gateway as a sensor node in v1.6
23 Posts 4 Posters 8.2k Views 4 Watching
  • ahmedadelhosniA Offline
    ahmedadelhosni
    wrote on last edited by ahmedadelhosni
    In the notes for ver 1.6 (or 2.00 beta now i guess) it is mentioned the following:
    Note's link: https://docs.google.com/document/d/1NKq5uuNdnxF5jWnum7VT32mbKLjuvqlx2A5D1qQ-H3Q/edit#heading=h.t5sdmpn6jz2i
    Gateway just another sensor node! So now you can have wired ethernet sensors and wireless ESP8266 sensors without any radio attach if you want.
    Does this mean that I can attach an esp8266 or another uno with ethernet in a very far place and it will act as a repeater if a radio is connnected ?
    DId anybody try this, cas this is awesome ?
    • mfalkviddM Online
      mfalkviddM Online
      It can either act as a repeater (repeating nrf24 or rfm radio signals to other nrf24/rfm nodes) or as a gateway (sending messages received from nrf24/rfm via wifi/ethernet to a controller). It can not be both repeater and gateway.
      Gateway as a sensor node means that sensors can be physically connected directly to the gateway node.
      ahmedadelhosniA 1 Reply Last reply
        ahmedadelhosni
        @mfalkvidd ohhh I see.
        I thought that I do have a Gateway already using Ethernet for example, and then I can add another uno with ethernet which has a radio and act as a sensor node also. So instead of sending data wirelessly they are sent through ethernet.
        Thank you.
        • mfalkviddM Online
          mfalkviddM Online
          You can have several gateways so yes that will work.
          ahmedadelhosniA DwaltD 2 Replies Last reply
            ahmedadelhosni
            @mfalkvidd ohhh again :) I have to try this soon.
            Great. Thank you.
              DwaltD Offline
              DwaltD Offline
              Dwalt
              @mfalkvidd I am curious to try this. Would I need to update my existing GW to 1.6 or just a new GW?
              • DwaltD Dwalt
                mfalkviddM Online
                mfalkviddM Online
                @Dwalt A gateway that has sensors directly connected to it needs to use 1.6 (=development version).
                You can have several gateways and the gateways don't need to use the same version. If the gateways have nrf24 radios, the radios need to be configured to use different channels though. But that's not an issue if you don't connect a radio to the new gateway.
                Sensor nodes do not need to use the same MySensor version as the gateway, they can use higher or lower version.
                I hope that answers your question :-)
                  ahmedadelhosni
                  @mfalkvidd if the second GW has another channel, by this it wont be communicating with the first GW ?
                  In another words. I am just thinking about having a main GW and sub GWs for large distance converage. So they shall be on the same channel, right ?
                  • mfalkviddM Online
                    mfalkviddM Online
                    There is no such thing as a sub gw. There can only be one gw per channel. Gws cannot communicate with eachother.
                    To me it sounds like you want repeater nodes.
                      ahmedadelhosni
                      Yeah i want to use them as repeater nodes but I just thought that if I can add a wires etheenet repeater 60m (for example) away from the gateway rather than adding 2 or 3 nodes as a repeater nodes to cover a distance of 60m.
                      • ahmedadelhosniA ahmedadelhosni
                        mfalkviddM Online
                        mfalkviddM Online
                        @ahmedadelhosni there is no such thing as an ethernet repeater in the MySensors world.
                        I'm sorry but I think I've run out of ways to explain this.
                          ahmedadelhosni
                          No I understood your answer from the beggining. Thanks a lot :)
                          I was just chatting about what I really wanted the library to support.
                          Thanks a lot for your time.
                          • mfalkviddM Online
                            mfalkviddM Online
                            From some of your posts, it sounds like you should just add a second gateway and you're done. But you keep calling it a repeater and I 'm unable to figure out how to proceed.
                            • mfalkviddM Online
                              mfalkviddM Online
                              https://www.mysensors.org/about/network might help a little bit
                                ahmedadelhosni
                                Yeah that was the answer for my question at the beginning.
                                After your answer - which is above - I understood that the concept which I need is not supported. I will draw a diagram showing why I called it a repeater sometimes.
                                • mfalkviddM Online
                                  mfalkviddM Online
                                  A picture would be great :-) Thanks for your patience.
                                    ahmedadelhosni
                                    0_1453657946793_upload-f848924b-d708-4d1b-bf58-b31fa3c3faf6
                                    I hope this explains my request :)
                                    First half shows the normal MYsensor library where S1 needs to pass through RC > RB > RA to reach GW1. Also it shows another example to use only one repeater so that S2 reached GW1 through RD. All of this needs several repeaters to be placed at different distances to conver a long distance.
                                    I guess we agree to this :)
                                    My question was about the second half in the picture. I have GW1 which is UNO + W5100 connected to a network switch. Then there is the Yellow and Blue thing. Imagine replacing all these repeater nodes by another UNO + W5100 which is the Yellow and Blue circle. Thus S1 needs to pass by this yellow and blue circle (2) to reach GW1. That's why I named it as a repeater, as it sends data from a long distance to the GW. Don't know what is the correct description for this :)
                                    Thus my thoughts were : The yellow and blue thing since it is connected to a network it can communicate with the ethernet gateway through network. ( Actually I found that this is implemented using ESP ) I guess the ESP itself can be used as a repeater node. So it can be placed in a far place and send data to the GW through the network. I didn't use the ESP with MYs but I guess it is a valid example :)
                                    Hope this simplifies my question.
                                    • mfalkviddM Online
                                      mfalkviddM Online
                                      Thanks for explaining. So if I understand you correctly, you want a simple way for Domoticz to reach S1?
                                      I hope this picture shows what the network would look like with a second gateway.
                                      0_1453660466990_1453657937893-upload-f848924b-d708-4d1b-bf58-b31fa3c3faf6_mfalkvidd.png
                                      That's it. You're done. No need for a new Yellow and Blue thing.
                                      I must be missing something.
                                      • mfalkviddM Online
                                        mfalkviddM Online
                                        Maybe this better describes how adding a second gateway would work
                                        0_1453662278625_1453657937893-upload-f848924b-d708-4d1b-bf58-b31fa3c3faf6_mfalkvidd2.png
                                          ahmedadelhosni
                                          Yeah you solved this issue now. That's exactly what I needed :)
                                          The second picture explains it all. I wasn't able to understand how will I have several GWs although you explained it above from the beginning, but I wasn't aware how to do it. I remembered now from your last picture that domoticz can support several hardware. Thus I can make another GW and add it to the hardware in Domoticz as you have explained in your last picture.
                                          Thanks a lot for your time. Now it is very clear :)
                                          11.8k
                                          113.2k
