  3. Stable battery PIR Sensor
7 Posts 3 Posters 3.9k Views 2 Watching
  • F Offline
    F Offline
    Fredrik Carlsson
    Hello
    I am busy building an burglar alarm for my home.
    Because of this its important its a wireless system (to not go down during electrical failure in the house).
    I wonder is there any stable good PIR sensor that works with battery?
    I have sourced the forum but not really found anything. I have a couple of Sensebender micro boads lying around that I would prefer to use for this.
    Its off course also important that there is no false triggers, because then it would be a very unreliable system.
    • mfalkviddM Offline
      http://forum.mysensors.org/topic/1088/battery-powered-pir and http://forum.mysensors.org/topic/2715/slim-node-as-a-mini-2aa-battery-pir-motion-sensor are battery powered pir sensors.
      Here is the open hardware for the slim node.:
      https://www.openhardware.io/view/10/My-Slim-2AA-Battery-Node
      m26872M 1 Reply Last reply
        m26872M Offline
        m26872M Offline
        m26872
        I've been away from home two weeks now and my two Slim Node Mini PIRs have delivered heartbeat messages every second day and no false trig.
        F 1 Reply Last reply
        • F Offline
          F Offline
          Fredrik Carlsson
          Wonderful!
          Maybe I will try this design then. But I dont need them so small so will probably use the bigger PIR sensor in mine.
          I will revert when I'm done
          • m26872M m26872
            F Offline
            F Offline
            Fredrik Carlsson
            @m26872 Hello, have you not used any voltage regultator for the pir sensor? You just give it direct connection to the batterypack?
            • F Fredrik Carlsson
              m26872M Offline
              m26872M Offline
              m26872
              @Fredrik-Carlsson Yes, for power economy (efficiency and dropout voltage). Whole node worked at 1.6V, as stable as before.
              I think you should read about other PIR setups as well, I haven't yet tried the standard sized one myself.
              • F Offline
                F Offline
                Fredrik Carlsson
                I will try tomorrow to do it without any voltage regulators together with a sensebender micro. I have the bigger pir sensor though, but I dont think its much difference on thoose. We will see.
