  3. OpenHAB
  4. The best way to connect to OpenHAB
24 Posts 6 Posters 37.2k Views 1 Watching
  • K
    K
    kolaf
    In parallel with trying to get the radio library to work with my hardware, I started trying to connect this up to my openHAB installation. I will be connecting the Arduino gateway unit directly to a computer through USB, so a solution has to be able to talk to it through the serial port. As far as I can see there are two options for me:
    1. Use one of the MQTT gateway libraries available (which one?).
    2. Use the place and gateway Web server implementation created for openHAB implementation posted by someone a few months ago.
    Are there any other options I have missed and should be looking at?
    I already have a mqtt broker running on my server, so there is no overhead there. However, it seems a bit like overkill to put a mqtt client, a broker, and the mqtt binding between the serial gateway and openhab. Also, I'm not quite sure what kind of management functionality this offers as far as assigning IDs and so on.
    What do you guys suggest I do?
    DammeD YveauxY 2 Replies Last reply
    • K kolaf
      DammeD
      DammeD
      Damme
      Code Contributor
      wrote on last edited by Damme
      @kolaf Imo : mqttgateway (arduino + nrf24 + ethernet) (runs as a broker) and openhab mqtt client on a server :)
      K 1 Reply Last reply
      • DammeD Damme
        K
        K
        kolaf
        wrote on last edited by kolaf
        @Damme Thanks, but hardly surprising from you, I believe ;)
        The problem is that I really don't want to hassle with connecting an ethernet shield when I can just plug the thing into my USB port. I'm more of a software guy than a hardware guy, so the less soldering, the better.
        YveauxY 1 Reply Last reply
        • K kolaf
          YveauxY
          YveauxY
          Take the Arduino UNO in one hand, the Ethernet shield in the other and plug them together. Done!
          It's really that hard ;-)
          Even a software guy (like me) can do it!
          • K
            K
            kolaf
            Hehe, but what about the radio? You need to connect that, too.
            • K kolaf
              YveauxY
              YveauxY
              @kolaf you need to connect the radio anyway, right ;-)
              • YveauxY Yveaux
                This topic was split off http://forum.mysensors.org/topic/301/the-best-way-to-connect-to-openhab to discuss tips and hints specific to using MySensors together with MQTT middleware and OpenHAB.
                If you made something nice using this combination or have some questions/issues please post them in here!
                @kolaf I just started experimenting with openhab and find it quite hard to get started. There's some documentation ( far from complete, especially when you're just starting) but the general impression is that it's very powerful, mainly due to all the programming options. I'm quite sure you could directly talk to a mysensors gateway using the serial protocol, using e.g. rules, if you want.
                I doubt however if you want to write your own protocol handler...
                Anyway, I'm currently using an Ethernet gateway which tasks to a Perl script I wrote (https://github.com/Yveaux/MySensors_MQTTGateway) that does the conversion to and from MQTT. This script is a MQTT client that runs on the same server I run openhab and the mosquitto broker on. This is the only difference compared to @Damme solution who runs a broker on the gateway.
                I like the flexibility of storing & accessing all data through an MQTT broker which makes up for the apparent overkill going through MQTT just to connect mysensors to openhab.
                As long as your server has enough resources to run it all its not really worth the effort to directly talk to my sensors or create an openhab binding for it.
                K
                K
                kolaf
                @Yveaux I saw that earlier and it is one of the options I have been considering. But why do you use an ethernet gateway instead of a serial?
                • YveauxY Yveaux
                  K
                  K
                  kolaf
                  Not if you're lazy like me and buy moteinos or anarduinos where everything comes in one nice, compact package :-)
                  • K kolaf
                    YveauxY
                    YveauxY
                    @kolaf my gateway is located downstairs an my server is in the attic. They're only connected using Ethernet, so for me it is the most logic solution.
                    • K
                      K
                      kolaf
                      The anarduino with RF 69HW combined as up to only $15 which seems to me to be a reasonable price. Of course you need some headers as well, and an antenna, but still...
                      • K kolaf
                        YveauxY
                        YveauxY
                        @kolaf touché
                        • YveauxY Yveaux
                          K
                          K
                          kolaf
                          @Yveaux makes sense. Can your gateway speak the serial protocol?
                          • K kolaf
                            YveauxY
                            YveauxY
                            It currently connects using sockets, but the protocol is identical, so it shouldn't be hard to use a serial connection.
                            • T
                              tboha
                              For testing basic functions there exists another (rather crude) way - the serial binding offerd by OpenHAB. Adding :
                                 String Arduino   "Arduino [%s]"    {serial="COM6"}
                              to an "items" file will do the trick. Accordingly a "rules" file should be expanded by something like :
                                 rule SplitMessage
                                 when
                              Item Arduino changed
                                then
                               <do some relevant processing>
                              Using MySensors 1.4b (proMini, Uno, Mega.Leonardo) and OpenHab 1.5 (Windows 7 Notebook) produced very reliable results with SerialGateway connected via USB.
                              You have to compile the sketches with Baudrate set to 9600 because OpenHAB deals only with this Baudrate (mentioned somewhere in the OpenHAB Documentation).
                              So in Mysensors.h replace :
                              #define BAUD_RATE 115200
                              with
                              #define BAUD_RATE 9600
                              Because OpenHAB is not prepared to distribute NODE_IDs, you should hardcode this NODE-IDs. This decreases flexibility, but it is acceptable to some degree.
                              This approach works well for reading sensordata as for writing to actuators. Currently I am using eigth Nodes (including Repeater) with serveral children (e.g. multiple DS18B20, multiple Door contacts, Motionsensor, DHT22 etc). Until now I haven´t enconterd serious problems.
                              • T tboha
                                   rule SplitMessage
                                   when
                                  then
                                with
                                K
                                K
                                kolaf
                                @tboha Thanks, that was very helpful. Do you have some more details for the mystical "do some processing"?
                                @Yveaux how do you use the mqtt binding to talk to the sensors? I have looked into it, and must admit I have no idea on how to achieve this. It's apparent that you need some kind of transformation, but my understanding ends there. Specifically, I would like to implement a toggle switch, a switch that toggles a light every time it is activated instead of having a specific on and off state.
                                • YveauxY
                                  YveauxY
                                  @hek or @marceltrapman can you please split this topic starting at the openhab/mqtt examples into something like "OpenHAB & MQTT examples" please?
                                  Thanks!
                                  • YveauxY Yveaux
                                    Thanks!
                                    marceltrapmanM
                                    marceltrapmanM
                                    marceltrapman
                                    Starting from which post do you suggest the split?
                                    Fulltime Servoy Developer
                                    • marceltrapmanM marceltrapman
                                      YveauxY
                                      YveauxY
                                      Can you also join to an existing topic? In that case I'll create one -- that will make a clearer topic than just start in the middle of a discussion.
                                      • K
                                        K
                                        kolaf
                                        For the record there is also this initiative where a smart guy has created a Python Web application to interface between the serial connection and openhab. He has even built in the functionality for handling node IDs.
                                        https://github.com/wbcode/ham
                                        It seems like there are three quite usable options for interfacing with openhab:
                                        1. The MQTT gateway
                                        2. Using the serial binding in openhab
                                        3. Using the python openhab gateway.
                                        The serial binding seems the best option for quick prototyping with its low implementation cost (no additional software) and high flexibility. One of the two other options seems to be a better long-term choice since they will be easier to manage on the configuration size as the network grows, I think. I like the concept behind the python gateway, but using the httpbinding to communicate with it seems a bit cumbersome. Ideally I would like to see this incorporated as an openhab binding, but I do not think it is possible to do the node ID assignment this way since the binding should be stateless.
                                        This leaves the MQTT solution which leverages technology that seems to grow in popularity. An additional benefit is that the author of the software is still around the forums as opposed to the case with the python gateway. The downside is that the item configurations seems a bit complex (at least to me), it is much easier to understand the serial binding or HTTP binding usage.
                                        It is a tough choice.
                                        • YveauxY
                                          YveauxY
                                          @hek made me a forum moderator, so now I did the split myself ;-)
                                          Moved the topics regarding specific MQTT & Openhab usage to http://forum.mysensors.org/topic/302/openhab-mqtt-tips-hints
                                          There we can post some OpenHAB code and stuff, and this thread continues to discuss different ways to connect to OpenHAB.
                                          Still have to clean up the new thread a little, though...
